Hello, I am having problems to be able to perform the transmission (read / write) of data via I2C on the NanoPC-T2 with android.
I open the I2C port and set the slave with the following commands.
 devFD = HardwareControler.open("/dev/i2c-0", FileCtlEnum.O_RDWR);
        if (devFD < 0) {
             Toast.makeText(getApplicationContext(), "Fail to open I2C device",
                                Toast.LENGTH_LONG).show();
        } else {
            if (HardwareControler.setI2CSlave(devFD, 0x48) < 0) {
                Toast.makeText(getApplicationContext(), "Fail to open I2C Slave",
            } else {
                Toast.makeText(getApplicationContext(), "Ready " + String.valueOf(devFD),
But when transmitting data if I see it with the oscilloscope, the clock does not work continuously and the same data is sent repeatedly ((I only send a data for example "1", but I see that it is sent up to 6 times) .).
   private void sendData() {
        new Thread() {
            @Override
            public void run() {
                while (true){
                    try {
                        sleep(100);
                        HardwareControler.I2CWriteByte(devFD,(byte) (0x01 << 4) ,0);
                        Log.d("I2C","SENT");
                        sleep(5000);
                    } catch (InterruptedException e) {
                        e.printStackTrace();
        }.start();
