I use a JNI to do this. Here is the serial port file for you to see how it's done.
* Copyright 2009-2011 Cedric Priscal
* Licensed under the Apache License, Version 2.0 (the "License");
* you may not use this file except in compliance with the License.
* You may obtain a copy of the License at
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software
* distributed under the License is distributed on an "AS IS" BASIS,
* WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
* See the License for the specific language governing permissions and
* limitations under the License.
#include <termios.h>
#include <unistd.h>
#include <sys/types.h>
#include <sys/stat.h>
#include <fcntl.h>
#include <string.h>
#include <jni.h>
#include "serial_port.h"
#include "android/log.h"
static const char *TAG="serial_port";
#define LOGI(fmt, args...) __android_log_print(ANDROID_LOG_INFO, TAG, fmt, ##args)
#define LOGD(fmt, args...) __android_log_print(ANDROID_LOG_DEBUG, TAG, fmt, ##args)
#define LOGE(fmt, args...) __android_log_print(ANDROID_LOG_ERROR, TAG, fmt, ##args)
static speed_t getBaudrate(jint baudrate)
switch(baudrate) {
case 0: return B0;
case 50: return B50;
case 75: return B75;
case 110: return B110;
case 134: return B134;
case 150: return B150;
case 200: return B200;
case 300: return B300;
case 600: return B600;
case 1200: return B1200;
case 1800: return B1800;
case 2400: return B2400;
case 4800: return B4800;
case 9600: return B9600;
case 19200: return B19200;
case 38400: return B38400;
case 57600: return B57600;
case 115200: return B115200;
case 230400: return B230400;
case 460800: return B460800;
case 500000: return B500000;
case 576000: return B576000;
case 921600: return B921600;
case 1000000: return B1000000;
case 1152000: return B1152000;
case 1500000: return B1500000;
case 2000000: return B2000000;
case 2500000: return B2500000;
case 3000000: return B3000000;
case 3500000: return B3500000;
case 4000000: return B4000000;
default: return B19200;
static tcflag_t getDatabits(jint databits)
switch(databits) {
case 5: return CS5;
case 6: return CS6;
case 7: return CS7;
case 8: return CS8;
default: return CS8;
static tcflag_t getParity(jint parity)
switch(parity) {
case 1: return PARODD | PARENB;
case 2: return PARENB;
default: return IGNPAR;
* Class: android_serialport_SerialPort
* Method: open
* Signature: (Ljava/lang/String;II)Ljava/io/FileDescriptor;
JNIEXPORT jobject JNICALL Java_com_axon_ax9100dg5000_SerialPort_open
(JNIEnv *env, jobject thiz, jstring path, jint baudrate, jint bits, jint parity, jint stop, jint flags)
int fd;
speed_t speed;
jobject mFileDescriptor;
/* Check arguments */
speed = getBaudrate(baudrate);
if (speed == -1) {
/* TODO: throw an exception */
LOGE("Invalid baudrate");
return NULL;
/* Opening device */
jboolean iscopy;
const char *path_utf = (*env)->GetStringUTFChars(env, path, &iscopy);
LOGD("Opening serial port %s with flags 0x%x", path_utf, O_RDWR | flags);
LOGD("baudrate = %d, databits = %d, parity = %d, stop = %d", baudrate, bits, parity, stop);
fd = open(path_utf, O_RDWR | flags);
LOGD("open() fd = %d", fd);
(*env)->ReleaseStringUTFChars(env, path, path_utf);
if (fd == -1)
/* Throw an exception */
LOGE("Cannot open port");
return NULL;
/* Configure device */
struct termios cfg;
LOGD("Configuring serial port");
if (tcgetattr(fd, &cfg))
LOGE("tcgetattr() failed");
close(fd);
return NULL;
cfmakeraw(&cfg);
cfg.c_iflag = 0;
cfsetispeed(&cfg, speed);
cfsetospeed(&cfg, speed);
// Set the databits and parity
cfg.c_cflag &= ~CSIZE;
cfg.c_cflag |= getDatabits(bits); // Set bits
if(parity > 0)
cfg.c_cflag |= getParity(parity);
LOGD("parity selected");
else
cfg.c_cflag &= ~(PARENB | PARODD); // Clear them
LOGD("No parity options");
// Set the stop bits
if(stop == 2)
cfg.c_cflag |= CSTOPB; // 2 stops bits
LOGD("2 stop bit set");
else
cfg.c_cflag &= ~CSTOPB; // 1 stop bit
LOGD("1 stop bit set");
if (tcsetattr(fd, TCSANOW, &cfg))
LOGD("tcsetattr() failed");
close(fd);
return NULL;
/* Create a corresponding file descriptor */
jclass cFileDescriptor = (*env)->FindClass(env, "java/io/FileDescriptor");
jmethodID iFileDescriptor = (*env)->GetMethodID(env, cFileDescriptor, "<init>", "()V");
jfieldID descriptorID = (*env)->GetFieldID(env, cFileDescriptor, "descriptor", "I");
mFileDescriptor = (*env)->NewObject(env, cFileDescriptor, iFileDescriptor);
(*env)->SetIntField(env, mFileDescriptor, descriptorID, (jint)fd);
return mFileDescriptor;
* Class: cedric_serial_SerialPort
* Method: close
* Signature: ()V
JNIEXPORT void JNICALL Java_com_axon_ax9100dg5000_SerialPort_close
(JNIEnv *env, jobject thiz)
jclass SerialPortClass = (*env)->GetObjectClass(env, thiz);
jclass FileDescriptorClass = (*env)->FindClass(env, "java/io/FileDescriptor");
jfieldID mFdID = (*env)->GetFieldID(env, SerialPortClass, "mFd", "Ljava/io/FileDescriptor;");
jfieldID descriptorID = (*env)->GetFieldID(env, FileDescriptorClass, "descriptor", "I");
jobject mFd = (*env)->GetObjectField(env, thiz, mFdID);
jint descriptor = (*env)->GetIntField(env, mFd, descriptorID);
LOGD("close(fd = %d)", descriptor);
close(descriptor);
