FriendlyARM Releases a GPS module for NanoPi2
FriendlyARM released a GPS module for the NanoPi2.
Please refer to the following link for more details:
http://www.friendlyarm.com/index.php?ro ... duct_id=93
Hi ,
I am using NANO PI R1.
https://www.friendlyarm.com/index.php?r ... uct_id=248
I need to setup matrix GPS-01 with nano pi R1,
Please guide on installation on 4.19.38-sunxi.
Thanks you
Bharat
friendluff wrote:
bharatdhuri wrote:
Hi ,
https://www.friendlyarm.com/index.php?r ... uct_id=248 basketball legends
Thanks you
Bharat
I also hope someone can give me detailed instructions on how to install on 4.19.38-sunxi.
I am also learning about how to install this app. Hope someone knowledgeable will help
Hey, I totally get where you're coming from.
I was in your exact shoes last year when we started hiring in Manchester. At first, I also thought setting up a local branch would be the smarter move long-term. But once I started digging into the admin side—corporate tax registration, opening local bank accounts, setting up payroll, appointing directors—it became clear that the legal and operational load was way too much for just one or two hires.
We ended up going with an Employer of Record (EOR) instead, and honestly, it took a huge weight off our shoulders. They manage all the local employment stuff—contracts, taxes, benefits, compliance—so we could just focus on building the actual team.
If you're still exploring options, this page really helped me understand the UK setup better: https://theemployerofrecord.com/payroll-services-in-the-uk. It lays out what EORs do and what you can expect. The cost per employee is a bit higher than doing it yourself, sure, but the time and stress saved made it totally worth it for us during the early stages.
Hope that helps a bit!
bharatdhuri wrote:
Hi ,
https://www.friendlyarm.com/index.php?r ... ct_id=248_cookie clicker
Thanks you
Bharat
This is likely a standard GPS module that communicates via UART (serial) and outputs NMEA 0183 sentences. It typically has VCC (power), GND (ground), TX (transmit), and RX (receive) pins.
Dr. Michael White stands as a towering figure in the realm of New Orleans jazz. This highly respected individual is not only a virtuosic clarinetist and bandleader but also a prolific composer, insightful musicologist, dedicated jazz historian, and influential educator. He's widely recognized as a preeminent authority on traditional New Orleans jazz, with his commitment to preserving and advancing this rich musical heritage evident through a vast discography of over 50 recordings and countless international performances. For more, please visit.
oliviawilde168 wrote:
bharatdhuri wrote:
Hi ,
https://www.friendlyarm.com/index.php?r ... ct_id=248_Curve Rush
Thanks you
Bharat
yes, the wire is the GPS module that allows to locate and determine the position of each transmission line and it usually has VCC, GND, TX and RX pins
