I'd like to ask you a question because I haven't been able to find a solution.
I have a Nanopi Neo core 2 card, with FriendlyElec on the emmc. My SD card reader is out of order.
I've plugged an SD card reader into a USB port, with an SD including a linux OS.
I've tried going to npi-config, then boot, then boot from USB, but nothing works. The nanopi still boots on the emmc.
What I'm trying to do is replace the contents of the emmc with my SD card. I usually do this with nand-sata-install or the dd.... command.
but when the card boots on the emmc, over the network if I try to do a dd if ... well it crashes the card, and the card don't initilize (red led only)
Do you have a method that works?
Many thanks in advance.
Nicolas
