Mini2440 & enable uda134x first microphone input
Posted: Mon Jun 12, 2017 1:01 pm
by Francois
I've been trying to use the first microphone input for quite a long time now on the FriendlyARM2440 board (the 3 pin connector) instead of the built-in one on the board.
After going through the uda134x codec documentation it turns out that the default configuration for the microphone input is differential mode.
I was able to change that mode to enable the first microphone input by writing the settings into the right uda134x registry.
To get more info about this you may want to search for UDA1341TS.pdf on Google. Here is the first link that comes out: http://www.nxp.com/documents/data_sheet/UDA1341TS.pdf
You'll find the registry address on page 19 and the different mixer modes on page 20.
We want to write the value 01 (0x01) into the registry at the address 010 (0x03) in extended mode.
To do so open up the file ./sound/soc/codecs/uda134x.c. Now edit the function uda134x_startup.c.
On the bottom right before the return statement you must add the following line of code.
uda134x_write(codec, UDA134X_EA010, 0x01);
This will enable the first micorphone input only. 0x02 will enable the second one and 0x03 both.
There may be a better way of doing this as I am not too sure if this is the best place where to add new hardware parameters.
Also, I am not too familiar with how ALSA SoC works but I would expect the ALSA framework to give us some means to control the hardware instead of editing the codec driver.
I hope it helps!
Re: Mini2440 & enable uda134x first microphone input
Posted: Tue May 23, 2023 9:10 am
by ClaraClayton
To get more info about this you may want to search for UDA1341TS.pdf on Google. Here is the first link that comes out: http://www.nxp.com/documents/data_sheet/UDA1341TS.pdf cubes 2048
I hope it helps!
Although this post is old, I have the same issue now. Have you solve it? Can you share your solution?
Re: Mini2440
Posted: Mon Jun 12, 2023 8:38 am
by Meher
Is anybody using mini2440 now? is it obsolete or Still available ?
If available then where to get it?
If not then what is the right replacement for this SBC with embedded linux?
can anybody help?
Posted: Fri Jun 21, 2024 7:48 am
by wadu
How can I configure the FriendlyARM2440 board to use the first microphone input (the 3-pin connector) instead of the built-in microphone on the board, based on the UDA134X codec documentation?
Posted: Fri Jun 28, 2024 7:34 am
by wadu
I am trying to use the 3-pin mic input on my FriendlyARM2440 board instead of the built-in one. I changed the default differential mode on the UDA134x codec to enable the first mic input by editing the uda134x.c file and adding a line to write to the codec's registry. Is there a better way to do this without directly modifying the driver?
