Supervivi on S29AL016MB (NOR Flash ID: 0x22490001)
Posted: Fri Apr 27, 2018 3:24 am
I need to back up NAND memory.
For this I need the SuperVivi, because I have only the parallel port Jtag, and it is very slow, it will take many hours to save the 256MB with a speed of 10 to 15KB / s.
I used a Pentium 4 computer with a parallel port so the H-Jtag (v3.0) could write to the bootloader's SuperVivi ROM, but it did not work.
Even following all the boot boot manuals, nothing appears through the serial port.
H-Jtag successfully completes the ROM scan that was written to the NOR memory.
Does anyone know what I need to do to get the SuperVivi bootloader menu to appear, I've already tried to press the spacebar when powering up.
Note: H-Jtag v3.0 can read the memories too!
Thank you.
Thank you.
