RTC battery for NanoPi Fire3
Hi! I would like to purchase RTC battery for NanoPI Fire3. I could not find it in FriendlyELEC shop. Could you please recommend me a compatible battery for purchase? A link to AliExpress would be very appreciated.
You need something like this with the connector. I use similar with the NANOPC T3 Plus
https://www.aliexpress.com/item/Free-sh ... 97120.html
Thank you!
Could you please take a look at this battery:
https://www.aliexpress.com/store/produc ... 74308.html
Is it the same? I just do not need 100 pcs, 10 would be much better for me!
Looks good. Just double check the pin for + when you get them. Easy enough to swap them but most likely will be correct.
Thank you!
In total there are 22 users online :: 0 registered, 0 hidden and 22 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 22 guests
