Overclocking
Posted: Sat Dec 03, 2016 7:54 am
by kaotika
I find the M3 to be very very quick. For parallel work in particular. But is it possible to do a bit overclocking?
Re: Overclocking
Posted: Fri Dec 09, 2016 3:01 am
by lawrence
Because of heat, do not recommend you overclock
Re: Overclocking
Posted: Fri Dec 09, 2016 6:32 am
by kaotika
I know that it's not recommended, but that was not the question.
By the way, I have mine running with a little custom cooler made of GPU memory coolers at 7 cores between 62°C and 66°C. All without an active cooling. The cooler can be improved, so I think there is much room for potential overclocking.
Re: Overclocking
Posted: Fri Jan 06, 2017 4:43 pm
by kaotika
Anything new about this topic?
Re: Overclocking
Posted: Tue May 09, 2017 6:15 am
by cowboy36289
I'm finally able to have temps way lower than the throttle temp at full tilt 8-cores. Does anyone have knowledge on overclocking the M3? I have ample power supply to do so for a moderate OC.
Re: Overclocking
Posted: Thu May 11, 2017 12:28 pm
by kaotika
No idea about overclocking. What kind of cooling solution did you used?
