I have 3 x new M3, 1 x Neo2, Neo2+, and 2 other brand Pi and I always use Etcher to burn image to TF card (I have wide range of TF like Sandisk, Toshiba and Sony, and all can write and boot successful. Other brand and my Neos already in production (as my NAS, personal Web server...etc)
I am building my first new M3 for a heavier traffic web and I use DietPi, after configuration, I bring back home. After a day, it hang during boot, I though my the TF corrupt and change to a new one, and burn Ubuntu image 20170619 into 2 other TF (1 sandisk, 1 toshiba) but both show below message via console. After 1 to 2 mins, it powered off itself. And I can press power button to have it on again...
I re-download the image and burn again, still same situation. I can try Debian but I would prefer Ubuntu (as I a bit more familiar)
Can anyone tell me what's going wrong ? ( I will try my 2nd M3 tmr)
[ 2.092000] dw_mmc dw_mmc.1: Version ID is 250a
[ 2.096000] dw_mmc dw_mmc.1: DW MMC controller at irq 76, 32 bit host data width, 32 deep fifo hw timeout 500 ms
[ 2.108000] usbcore: registered new interface driver usbhid
[ 2.112000] usbhid: USB HID core driver
[ 2.116000] snd pcm: register sound platform 'nxp-pcm'
[ 2.124000] snd i2s: ch 0, master, iis mode, 48000(47999)hz, 32 FBITs, MCLK=12287880hz, RFS=256
[ 2.140000] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[ 2.144000] mmc0: new high speed SDHC card at address 59b4
[ 2.152000] mmcblk0: mmc0:59b4 USD00 15.0 GiB
[ 2.156000] mmcblk0: p1 p2
[ 2.180000] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 400000Hz, actual 396825HZ div = 63)
[ 2.248000] asoc: ES8316 HiFi <-> nxp-i2s.0 mapping ok
[ 2.252000] spdif-tx: 48000(47999)Hz, MCLK=12287880hz HDMI out
[ 2.260000] asoc: dit-hifi <-> nxp-spdif-tx mapping ok
[ 2.264000] GACT probability NOT on
[ 2.268000] Mirror/redirect action on
[ 2.272000] u32 classifier
[ 2.272000] Actions configured
[ 2.276000] Netfilter messages via NETLINK v0.30.
[ 2.280000] nf_conntrack version 0.5.0 (13625 buckets, 54500 max)
[ 2.288000] ctnetlink v0.93: registering with nfnetlink.
[ 2.292000] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 2.300000] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 2.304000] xt_time: kernel timezone is -0000
[ 2.308000] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 2.316000] arp_tables: (C) 2002 David S. Miller
[ 2.320000] TCP: cubic registered
[ 2.324000] Initializing XFRM netlink socket
[ 2.328000] NET: Registered protocol family 10
[ 2.332000] Mobile IPv6
[ 2.336000] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 2.340000] IPv6 over IPv4 tunneling driver
[ 2.344000] NET: Registered protocol family 17
[ 2.348000] NET: Registered protocol family 15
[ 2.352000] NET: Registered protocol family 35
[ 2.356000] Registering the dns_resolver key type
[ 2.360000] Registering SWP/SWPB emulation handler
[ 2.368000] axp22_dcdc5: incomplete constraints, leaving on
[ 2.372000] axp22_dcdc4: incomplete constraints, leaving on
[ 2.380000] axp22_dcdc3: incomplete constraints, leaving on
[ 2.384000] axp22_dcdc2: incomplete constraints, leaving on
[ 2.392000] axp22_dcdc1: incomplete constraints, leaving on
[ 2.396000] axp22_dc5ldo: incomplete constraints, leaving on
[ 2.404000] axp22_eldo2: incomplete constraints, leaving on
[ 2.408000] axp22_eldo1: incomplete constraints, leaving on
[ 2.416000] axp22_dldo1: incomplete constraints, leaving on
[ 2.420000] axp22_aldo3: incomplete constraints, leaving on
[ 2.424000] axp22_aldo2: incomplete constraints, leaving on
[ 2.428000] axp22_aldo1: incomplete constraints, leaving on
[ 2.436000] axp22_ldo1: incomplete constraints, leaving on
[ 2.440000] otg_wakelock_init: No USB transceiver found
[ 2.444000] nxp-rtc nxp-rtc.0: setting system clock to 2016-01-01 08:08:40 UTC (1451635720)
[ 2.456000] tmu[0] = trim 49:0, ret 1
[ 2.456000] TMU: register tmu.0 to hwmon (max 1400000khz)
[ 2.464000] ALSA device list:
[ 2.464000] #0: I2S-ES8316
[ 2.468000] #1: SPDIF-Transciever
[ 2.472000] Freeing init memory: 220K
[ 2.476000] Write protecting the kernel text section c0008000 - c07c1000
[ 2.484000] rodata_test: attempting to write to read-only section:
[ 2.488000] write to read-only section trapped, success
