Bluetooth In NanoPC-T3 board doesn't work with hcitool scan?
Posted: Sun Apr 23, 2017 7:43 am
by huyle
How to bluetooth work on Nano-PC T3, not see the device. ?
I'm refer at site:
http://wiki.friendlyarm.com/wiki/index.php/NanoPC-T3 but that's not work? why?
Attatchment the log:
root@nano:~# hcitool scan
Device is not available: No such device
root@nano:~#
root@nano:~# hcitool dev
Devices:
root@nano:~#
Regards,
HuyLe
Re: Bluetooth In NanoPC-T3 board doesn't work with hcitool scan?
Posted: Sun Apr 23, 2017 8:06 am
by huyle
Seeing the boot log to login
Debian GNU/Linux 8 nano ttySAC0
nano login: [ 24.192000] Bluetooth: RFCOMM socket layer initialized
[ 24.192000] Bluetooth: RFCOMM ver 1.11
[ 25.272000] bt_bcm: rfkill set_block Off GPIOB.8
Debian GNU/Linux 8 huyle ttySAC0
huyle login: root
Password:
Last login: Sun Apr 23 15:56:37 CST 2017 on ttySAC0
Linux nano 3.4.39-s5p6818 #4 SMP PREEMPT Wed Mar 1 11:51:02 HKT 2017 armv7l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
root@nano:~# dmesg | grep Blue
[ 5.164000] Bluetooth: Core ver 2.21
[ 5.168000] Bluetooth: HCI device and connection manager initialized
[ 5.176000] Bluetooth: HCI socket layer initialized
[ 5.180000] Bluetooth: L2CAP socket layer initialized
[ 5.184000] Bluetooth: SCO socket layer initialized
[ 5.200000] Bluetooth: HCI UART driver ver 2.3
[ 5.200000] Bluetooth: HCI UART protocol H4 registered
[ 5.200000] Bluetooth: HCI UART protocol BCM registered
[ 5.200000] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 5.200000] Bluetooth: BNEP filters: protocol multicast
[ 5.200000] Bluetooth: BNEP socket layer initialized
root@nano:~# dmesg | grep bt_bcm
[ 0.704000] bt_bcm: rfkill initialized
[ 5.044000] bt_bcm: rfkill set_block Off GPIOB.8
[ 16.124000] bt_bcm: rfkill set_block Off GPIOB.8
[ 16.200000] bt_bcm: rfkill set_block On GPIOB.8
root@nano:~#
Devices:
root@nano:~#
root@nano:~# rfkill unblock 0
[ 499.368000] bt_bcm: rfkill set_block On GPIOB.8
[ 500.164000] bt_bcm: rfkill set_block On GPIOB.8
[ 501.008000] bt_bcm: rfkill set_block On GPIOB.8
Devices:
root@nano:~#
--Regards,
HuyLe
Posted: Wed Apr 26, 2017 11:00 am
by davef
I am not sure if you have solved this. Is hcitool installed on your system?
I noticed here
https://packages.debian.org/search?searchon=contents&keywords=hcitool&mode=path&suite=stable&arch=any that maybe you need to:
Posted: Wed Apr 26, 2017 1:52 pm
by huyle
Hi Davef,
Thanks to reply!
I'm sure the package is installed. The issue is why don't detect device controler ??
I checked on two boards NanoPC-T3 but still not seeing the device controler.
root@huyle:~#
root@huyle:~# sudo apt-get install bluetooth bluez blueman
Reading package lists... Done
Building dependency tree
Reading state information... Done
blueman is already the newest version.
bluetooth is already the newest version.
bluez is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 201 not upgraded.
root@huyle:~# systemctl status bluetooth
�● bluetooth.service - Bluetooth service
Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled)
Active: active (running) since Fri 2016-01-01 16:55:20 CST; 1 years 3 months ago
Docs: man:bluetoothd(8)
Main PID: 1144 (bluetoothd)
Status: "Running"
CGroup: /system.slice/bluetooth.service
�└�─1144 /usr/lib/bluetooth/bluetoothd
Jan 01 16:55:20 huyle bluetoothd[1144]: Bluetooth daemon 5.23
Jan 01 16:55:20 huyle systemd[1]: Started Bluetooth service.
Jan 01 16:55:20 huyle bluetoothd[1144]: Starting SDP server
Jan 01 16:55:20 huyle bluetoothd[1144]: Bluetooth management interface 1.10 ...d
Hint: Some lines were ellipsized, use -l to show in full.
root@huyle:~# hcitool dev
Devices:
root@huyle:~# systemctl status bluetooth -l
Status: "Running"
Jan 01 16:55:20 huyle bluetoothd[1144]: Bluetooth management interface 1.10 initialized
root@huyle:~# bluetoothctl
[bluetooth]# help
Available commands:
list List available controllers
show [ctrl] Controller information
select <ctrl> Select default controller
devices List available devices
power <on/off> Set controller power
pairable <on/off> Set controller pairable mode
discoverable <on/off> Set controller discoverable mode
agent <on/off/capability> Enable/disable agent with given capability
default-agent Set agent as the default one
scan <on/off> Scan for devices
info <dev> Device information
pair <dev> Pair with device
trust <dev> Trust device
remove <dev> Remove device
connect <dev> Connect device
disconnect <dev> Disconnect device
version Display version
quit Quit program
[bluetooth]# list
[bluetooth]# devices
[bluetooth]# power on
No default controller available
[bluetooth]# version
Version 5.9
[bluetooth]#
Posted: Wed Apr 26, 2017 7:39 pm
by davef
What do you get when you do:
Posted: Thu Apr 27, 2017 1:43 pm
by huyle
Attachment the log run service:
root@huyle:~#
��● bluetooth.service - Bluetooth service
Active: active (running) since Fri 2016-01-01 16:00:26 CST; 1 years 3 months ago
Main PID: 1145 (bluetoothd)
Status: "Running"
��└��─1145 /usr/lib/bluetooth/bluetoothd
Jan 01 16:00:26 huyle bluetoothd[1145]: Bluetooth daemon 5.23
Jan 01 16:00:26 huyle systemd[1]: Started Bluetooth service.
Jan 01 16:00:26 huyle bluetoothd[1145]: Starting SDP server
Jan 01 16:00:26 huyle bluetoothd[1145]: Bluetooth management interface 1.10 ...d
Devices:
root@huyle:~# sudo service --status-all
[ - ] alsa-utils
[ - ] apache2
[ + ] avahi-daemon
[ + ] avahi-dnsconfd
[ + ] bluetooth
[ - ] bootlogs
[ - ] bootmisc.sh
[ ? ] brcm_patchram_plus
[ - ] checkfs.sh
[ - ] checkroot-bootclean.sh
[ - ] checkroot.sh
[ - ] console-setup
[ + ] cron
[ + ] dbus
[ - ] dnsmasq
[ - ] gpsd
[ - ] hostapd
[ - ] hostname.sh
[ - ] hwclock.sh
[ - ] isc-dhcp-server
[ - ] keyboard-setup
[ - ] killprocs
[ + ] kmod
[ - ] lcd4linux
[ + ] lightdm
[ - ] motd
[ - ] mountall-bootclean.sh
[ - ] mountall.sh
[ - ] mountdevsubfs.sh
[ - ] mountkernfs.sh
[ - ] mountnfs-bootclean.sh
[ - ] mountnfs.sh
[ + ] network-manager
[ + ] networking
[ + ] nmbd
[ + ] ntp
[ - ] pppd-dns
[ + ] procps
[ + ] rc.local
[ + ] resolvconf
[ - ] rmnologin
[ - ] rsync
[ + ] rsyslog
[ - ] samba
[ + ] samba-ad-dc
[ - ] screen-cleanup
[ - ] sendsigs
[ - ] smbd
[ + ] ssh
[ - ] sudo
[ + ] tftpd-hpa
[ ? ] tightvncserver
[ + ] udev
[ + ] udev-finish
[ - ] udhcpd
[ + ] ufw
[ - ] umountfs
[ - ] umountnfs.sh
[ - ] umountroot
[ + ] urandom
[ + ] vsftpd
[ - ] x11-common
[ + ] xinetd
root@huyle:~# sudo service --status-all | grep bluetooth
[ + ] bluetooth
Devices:
root@huyle:~#
Posted: Thu Apr 27, 2017 7:50 pm
by davef
Dropping:
into Google turns up some possibly interesting reading.
Sorry, can't help further.
Good luck!
Posted: Fri Apr 28, 2017 1:46 am
by huyle
Ok Davef,
Thanks to disscussion. Will sent to you if bluetooth work.
--Regards,
HuyLe
