After upgrade Android boot.img, S5P6818 boot failure
Posted: Fri Jul 13, 2018 8:38 am
Dear all :
I successful download and compiler Android source, and create boot.img, cache.img, userdata.img and system.img. for T3
steps and source as below:
http://wiki.friendlyarm.com/wiki/index.php/NanoPC-T3
and then, I try to upgrade *.img, respectively upgrade and reboot test
1. fastboot flash system system system.img --> and then, reboot , android boot ok
2. fastboot flash system userdata userdata.img --> and then, reboot , android boot ok
3. fastboot flash system cache cache.img --> and then, reboot , android boot ok
4. fastboot flash system system boot.img --> and then, reboot , android boot failure
it seems kernel crash?! does anyone have comment for this problems ?!
many thanks
error message as below:
scratch is broken, clear
watchdog timer start
working to aarch32
waiting for pll change..
Second Boot by Nexell Co. : Ver0.3.6 - Built on Jun 29 2016 15:19:53
DDR3 POR Init Start 0
Lock value = 196
GATE CYC = 0x00000492
GATE CODE = 0x00000000
Read DQ = 0x08080808
Write DQ = 0x08080808
DDR3 Init Done!
CCI Init!
Wakeup CPU Wakeup Sub CPU 1234567
CPU Wakeup done! WFI is expected.
CPU0 is Master!
Loading from sdmmc...
Image Loading Done!
Launch to 0x42C00000
U-Boot 2014.07-ge53fe65 (Apr 12 2018 - 21:03:51)
PLL : [0] = 800000000, [1] = 800000000, [2] = 614394000, [3] = 800000000
(0) PLL1: CPU FCLK = 800000000, HCLK = 200000000 (G0)
(7) PLL1: CPU FCLK = 800000000, HCLK = 200000000 (G1)
(2) PLL3: MEM FCLK = 800000000, DCLK = 800000000, BCLK = 400000000, PCLK = 200000000
(1) PLL0: BUS BCLK = 400000000, PCLK = 200000000
(8) PLL0: CCI4 BCLK = 400000000, PCLK = 200000000
(3) PLL0: G3D BCLK = 400000000
(4) PLL0: CODA BCLK = 400000000, PCLK = 200000000
(5) PLL0: DISP BCLK = 400000000, PCLK = 200000000
(6) PLL0: HDMI PCLK = 100000000
I2C: ready
DRAM: 256 MiB
Heap = 0x43000000~0x45000000
Code = 0x42c00000~0x42c75984
GLD = 0x42bffeb8
GLBD = 0x42bffe68
SP = 0x42bffe68,0x42bffe50(CURR)
PC = 0x42c06220
TAGS = 0x40000100
PAGE = 0x42c80000~0x42c8c000
MACH = [4330]
VER = 0
BOARD= [nanopi3]
LCD = N/A (-1)
MMC: NXP DWMMC: 0, NXP DWMMC: 1, NXP DWMMC: 2
In: serial
Out: serial
Err: serial
switch to partitions #0, OK
mmc2(part 0) is current device
HDMI: display.0, preset 0 (1280 * 720)
HDMI: PHY Ready!!!
DONE: Logo bmp 800 by 480 (3bpp), len=1152056
DRAW: 0x47000000 -> 0x46000000
Hit any key to stop autoboot: 1 0
## Booting kernel from Legacy Image at 48000000 ...
Image Name: Linux-3.4.39-FriendlyARM
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 4641384 Bytes = 4.4 MiB
Load Address: 40008000
Entry Point: 40008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Linux version 3.4.39-FriendlyARM (root@gibbs) (gcc version 4.9.3 (ctng-1.21.0-229g-FA) ) #6 SMP PREEMPT Tue Jun 12 16:58:47 CST 2018
[ 0.000000] CPU: ARMv7 Processor [410fd033] revision 3 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine: NANOPI3
[ 0.000000] Ignoring unrecognised tag 0x00000000
[ 0.000000] Display: HDMI selected
[ 0.000000] nxp_reserve_mem: reserve CMA: size 167772160
[ 0.000000] NXP/CMA: Reserved 0x65600000/0x0a000000 for 'ion'
[ 0.000000] NXP/CMA: success register cma region for 'ion'
[ 0.000000] rquest persistent memory from 655fc000 (00000000)-00004000
[ 0.000000] Initialized persistent memory from 655fc000-655fffff
[ 0.000000] Memory policy: ECC disabled, Data cache writealloc
[ 0.000000] CPU : iomap[ 0]: p 0xc0000000 -> v 0xf0000000 len=0x300000
[ 0.000000] CPU : iomap[ 1]: p 0xe0000000 -> v 0xf0300000 len=0x100000
[ 0.000000] CPU : iomap[ 2]: p 0xfff00000 -> v 0xf0400000 len=0x100000
[ 0.000000] CPU : iomap[ 3]: p 0x2c000000 -> v 0xf0500000 len=0x100000
[ 0.000000] CPU : iomap[ 4]: p 0x00000000 -> v 0xf0600000 len=0x100000
[ 0.000000] CPU : DMA Zone Size =16M, CORE 8
[ 0.000000] s5p6818-NanoPi3: Board initialized
[ 0.000000] CPU : Clock Generator= 58 EA, DVFS = support, PLL.1
[ 0.000000] PLL : [0] = 800000000, [1] = 800000000, [2] = 614394000, [3] = 800000000
[ 0.000000] (0) PLL1: CPU FCLK = 800000000, HCLK = 200000000 (G0)
[ 0.000000] (7) PLL1: CPU FCLK = 800000000, HCLK = 200000000 (G1)
[ 0.000000] (2) PLL3: MEM FCLK = 800000000, DCLK = 800000000, BCLK = 400000000, PCLK = 200000000
[ 0.000000] (1) PLL0: BUS BCLK = 400000000, PCLK = 200000000
[ 0.000000] (8) PLL0: CCI4 BCLK = 400000000, PCLK = 200000000
[ 0.000000] (3) PLL0: G3D BCLK = 400000000
[ 0.000000] (4) PLL0: CODA BCLK = 400000000, PCLK = 200000000
[ 0.000000] (5) PLL0: DISP BCLK = 400000000, PCLK = 200000000
[ 0.000000] (6) PLL0: HDMI PCLK = 100000000
[ 0.000000] PERCPU: Embedded 9 pages/cpu @c131d000 s12608 r8192 d16064 u36864
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 260096
[ 0.000000] Kernel command line: console=ttySAC0,115200n8 androidboot.console=ttySAC0 androidboot.serialno=0123456789abcdef initrd=0x49000000,0x100000 lcd=HDMI720P60 bootdev=2
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] allocated 2097152 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Memory: 1024MB = 1024MB total
[ 0.000000] Memory: 860976k/860976k available, 187600k reserved, 272384K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xef800000 - 0xfee00000 ( 246 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xef600000 ( 758 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0876dfc (8636 kB)
[ 0.000000] .init : 0xc0877000 - 0xc08ae140 ( 221 kB)
[ 0.000000] .data : 0xc08b0000 - 0xc092c850 ( 499 kB)
[ 0.000000] .bss : 0xc092c874 - 0xc0b0fae0 (1933 kB)
[ 0.000000] SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:272
[ 0.000000] GIC @f0009000: start 0 (gic 31)
[ 0.000000] GPIO @f001a000: start 106, mask 0xffffffff (gpio 85)
[ 0.000000] GPIO @f001b000: start 138, mask 0xffffffff (gpio 86)
[ 0.000000] GPIO @f001c000: start 170, mask 0xffffffff (gpio 87)
[ 0.000000] GPIO @f001d000: start 202, mask 0xffffffff (gpio 88)
[ 0.000000] GPIO @f001e000: start 234, mask 0xffffffff (gpio 89)
[ 0.000000] ALIVE @f0010800: start 266, mask 0x000000ff (alive 36, num 6)
[ 0.000000] timer.0: source, 10000000(HZ:250), mult:3355443200
[ 0.000000] timer.1: event , 10000000(HZ:250), mult:42949673
[ 0.000000] sched_clock: 32 bits at 250 Hz, resolution 4000000ns, wraps every 4294967292ms
[ 0.000000] Calibrating delay loop... 1594.36 BogoMIPS (lpj=3188736)
[ 0.048000] pid_max: default: 32768 minimum: 301
[ 0.048000] Security Framework initialized
[ 0.048000] SELinux: Initializing.
[ 0.048000] Mount-cache hash table entries: 512
[ 0.048000] Initializing cgroup subsys debug
[ 0.048000] Initializing cgroup subsys cpuacct
[ 0.048000] Initializing cgroup subsys memory
[ 0.048000] Initializing cgroup subsys freezer
[ 0.048000] CPU: Testing write buffer coherency: ok
[ 0.048000] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.048000] hw perfevents: no hardware support available
[ 0.048000] Setting up static identity map for 0x4061a8c8 - 0x4061a920
[ 0.096000] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.132000] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.176000] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.216000] CPU4: thread -1, cpu 0, socket 4, mpidr 80040400
[ 0.252000] CPU5: thread -1, cpu 1, socket 4, mpidr 80040401
[ 0.292000] CPU6: thread -1, cpu 2, socket 4, mpidr 80040402
[ 0.332000] CPU7: thread -1, cpu 3, socket 4, mpidr 80040403
[ 0.332000] Brought up 8 CPUs
[ 0.332000] SMP: Total of 8 processors activated (12762.11 BogoMIPS).
[ 0.340000] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 3
[ 0.340000] pwm: max = 50000000 hz
[ 0.340000] prepare_gpio_suspend:
[ 0.340000] alfn[0][0]: 0x00000000, alfn[0][1]: 0x00000000
[ 0.340000] alfn[1][0]: 0x66800000, alfn[1][1]: 0x55555566
[ 0.340000] alfn[2][0]: 0x55555555, alfn[2][1]: 0x00555555
[ 0.340000] alfn[3][0]: 0x00000000, alfn[3][1]: 0x00000000
[ 0.340000] alfn[4][0]: 0x00000000, alfn[4][1]: 0x55540000
[ 0.344000] dummy:
[ 0.344000] NET: Registered protocol family 16
[ 0.344000] persistent_ram: uncorrectable error in header
[ 0.344000] persistent_ram: no valid data in buffer (sig = 0xff00ff00)
[ 0.356000] console [ram-1] enabled
[ 0.356000] [Register machine platform devices]
[ 0.356000] mach: add amba device pl08xdmac.0
[ 0.356000] mach: add amba device pl08xdmac.1
[ 0.356000] mach: add device uart0
[ 0.356000] mach: add device uart1
[ 0.356000] mach: add device uart2
[ 0.356000] mach: add device uart3
[ 0.360000] mach: add device uart4
[ 0.360000] mach: add device syncgen [2]
[ 0.360000] mach: add device lvds
[ 0.360000] mach: add device hdmi
[ 0.360000] mach: add device i2c bus (array:3)
[ 0.360000] mach: add device Real Time Clock
[ 0.360000] mach: add device generic pwm (array:4)
[ 0.360000] mach: add device generic gpio (array:6)
[ 0.360000] mach: add device i2s (array:1)
[ 0.360000] mach: add device spdif tx
[ 0.360000] mach: add device usb_ehci
[ 0.360000] mach: add device usb_ohci
[ 0.360000] mach: add device usb otg
[ 0.364000] mach: add device ion-nxp
[ 0.364000] mach: add graphic device opengl|es
[ 0.364000] [Register board platform devices]
[ 0.364000] plat: board revision 1
[ 0.364000] plat: reset USB hub
[ 0.364000] plat: add dynamic frequency (pll.1)
[ 0.364000] plat: add device TMU
[ 0.364000] plat: add framebuffer
[ 0.364000] plat: boot from mmc.2
[ 0.364000] plat: add device sdmmc [2]
[ 0.364000] plat: add device sdmmc [1]
[ 0.364000] plat: add device sdmmc [0]
[ 0.368000] plat: add backlight pwm device
[ 0.368000] plat: add device keypad
[ 0.368000] plat: add device fake-battery
[ 0.368000] plat: add device spdif playback
[ 0.368000] plat: add device asoc-es8316
[ 0.368000] plat: add device nxp-v4l2
[ 0.372000] plat: register spidev
[ 0.372000] plat: add touch(ft5x0x) device
[ 0.372000] plat: add touch(goodix) device
[ 0.372000] plat: goodix: irq=186 (80)
[ 0.372000] plat: add touch(himax) device
[ 0.372000] plat: add touch(it7260) device
[ 0.372000] plat: add onewire ts device
[ 0.372000] plat: add iio adc device
[ 0.372000] plat: add device hdmi-cec
[ 0.372000] plat: add device nxp-gmac
[ 0.372000] plat: add device gpio_led
[ 0.372000]
[ 0.372000] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.372000] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.396000] bio: create slab <bio-0> at 0
[ 0.396000] gpiochip_add: registered GPIOs 0 to 31 on device: GPIOA
[ 0.396000] gpiochip_add: registered GPIOs 32 to 63 on device: GPIOB
[ 0.396000] gpiochip_add: registered GPIOs 64 to 95 on device: GPIOC
[ 0.396000] gpiochip_add: registered GPIOs 96 to 127 on device: GPIOD
[ 0.396000] gpiochip_add: registered GPIOs 128 to 159 on device: GPIOE
[ 0.396000] gpiochip_add: registered GPIOs 160 to 165 on device: GPIOALV
[ 0.396000] pl08xdmac pl08xdmac.0: Unbalanced pm_runtime_enable!
[ 0.400000] pl08xdmac pl08xdmac.0: initialized 8 virtual memcpy channels
[ 0.400000] pl08xdmac pl08xdmac.0: initialized 16 virtual slave channels
[ 0.400000] pl08xdmac pl08xdmac.0: DMA: PL080 rev1 at 0xc0000000 irq 33
[ 0.400000] pl08xdmac pl08xdmac.1: Unbalanced pm_runtime_enable!
[ 0.400000] pl08xdmac pl08xdmac.1: initialized 8 virtual memcpy channels
[ 0.400000] pl08xdmac pl08xdmac.1: initialized 15 virtual slave channels
[ 0.404000] pl08xdmac pl08xdmac.1: DMA: PL080 rev1 at 0xc0001000 irq 34
[ 0.404000] nxp_ion_probe success!!!
[ 0.404000] SCSI subsystem initialized
[ 0.404000] usbcore: registered new interface driver usbfs
[ 0.404000] usbcore: registered new interface driver hub
[ 0.404000] usbcore: registered new device driver usb
[ 0.404000] i2c-gpio i2c-gpio.3: using pins 159 (SDA) and 158 (SCL)
[ 0.408000] s3c-i2c s3c2440-i2c.0: i2c-0: S3C I2C adapter
[ 0.408000] s3c-i2c s3c2440-i2c.0: slave address 0x10
[ 0.408000] s3c-i2c s3c2440-i2c.0: bus frequency set to 390 KHz
[ 0.408000] s3c-i2c s3c2440-i2c.1: i2c-1: S3C I2C adapter
[ 0.408000] s3c-i2c s3c2440-i2c.1: slave address 0x10
[ 0.408000] s3c-i2c s3c2440-i2c.1: bus frequency set to 97 KHz
[ 0.408000] s3c-i2c s3c2440-i2c.2: i2c-2: S3C I2C adapter
[ 0.408000] s3c-i2c s3c2440-i2c.2: slave address 0x10
[ 0.408000] s3c-i2c s3c2440-i2c.2: bus frequency set to 195 KHz
[ 0.408000] Linux media interface: v0.10
[ 0.408000] Linux video capture interface: v2.00
[ 0.412000] pps_core: LinuxPPS API ver. 1 registered
[ 0.412000] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.412000] PTP clock support registered
[ 0.416000] axp_mfd 3-0034: AXP (CHIP ID: 0x06) detected
[ 0.420000] axp22_ldo1: 3000 mV
[ 0.428000] axp22_aldo1: 700 <--> 3300 mV at 3300 mV
[ 0.432000] axp22_aldo2: 700 <--> 3300 mV at 1800 mV
[ 0.436000] axp22_aldo3: 700 <--> 3300 mV at 1000 mV
[ 0.440000] axp22_dldo1: 700 <--> 3300 mV at 3300 mV
[ 0.440000] axp22_dldo2: No configuration
[ 0.444000] axp22_dldo2: 700 <--> 3300 mV at 700 mV
[ 0.444000] axp22_dldo3: No configuration
[ 0.444000] axp22_dldo3: 700 <--> 3300 mV at 700 mV
[ 0.448000] axp22_dldo4: No configuration
[ 0.448000] axp22_dldo4: 700 <--> 3300 mV at 700 mV
[ 0.452000] axp22_eldo1: 700 <--> 3300 mV at 1800 mV
[ 0.456000] axp22_eldo2: 700 <--> 3300 mV at 3300 mV
[ 0.460000] axp22_eldo3: No configuration
[ 0.460000] axp22_eldo3: 700 <--> 3300 mV at 700 mV
[ 0.460000] axp22_dc5ldo: No configuration
[ 0.464000] axp22_dc5ldo: 700 <--> 1400 mV at 1200 mV
[ 0.468000] axp22_dcdc1: 1600 <--> 3400 mV at 3300 mV
[ 0.472000] axp22_dcdc2: 600 <--> 1540 mV at 1200 mV
[ 0.476000] axp22_dcdc3: 600 <--> 1860 mV at 1200 mV
[ 0.480000] axp22_dcdc4: 600 <--> 1540 mV at 1500 mV
[ 0.484000] axp22_dcdc5: 1000 <--> 2550 mV at 1500 mV
[ 0.488000] axp22_ldoio0: 700 <--> 3300 mV at 3800 mV
[ 0.492000] axp22_ldoio1: 700 <--> 3300 mV at 3800 mV
[ 0.492000] Advanced Linux Sound Architecture Driver Version 1.0.25.
[ 0.492000] Bluetooth: Core ver 2.19
[ 0.492000] NET: Registered protocol family 31
[ 0.492000] Bluetooth: HCI device and connection manager initialized
[ 0.492000] Bluetooth: HCI socket layer initialized
[ 0.492000] Bluetooth: L2CAP socket layer initialized
[ 0.492000] Bluetooth: SCO socket layer initialized
[ 0.492000] cfg80211: Calling CRDA to update world regulatory domain
[ 0.496000] Switching to clocksource source timer
[ 0.500000] Clockevents: could not switch to one-shot mode:
[ 0.500000] Clockevents: could not switch to one-shot mode: dummy_timer is not functional.
[ 0.500000] dummy_timer is not functional.
[ 0.500000] Could not switch to high resolution mode on CPU 6
[ 0.500000] Could not switch to high resolution mode on CPU 7
[ 0.500000] Could not switch to high resolution mode on CPU 4
[ 0.500000] Could not switch to high resolution mode on CPU 5
[ 0.500000] Could not switch to high resolution mode on CPU 0
[ 0.500000] Could not switch to high resolution mode on CPU 3
[ 0.500000] Could not switch to high resolution mode on CPU 2
[ 0.500000] Could not switch to high resolution mode on CPU 1
[ 0.512000] NET: Registered protocol family 2
[ 0.512000] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.512000] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.516000] TCP bind hash table entries: 65536 (order: 8, 1572864 bytes)
[ 0.516000] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.516000] TCP: reno registered
[ 0.520000] UDP hash table entries: 512 (order: 3, 32768 bytes)
[ 0.520000] UDP-Lite hash table entries: 512 (order: 3, 32768 bytes)
[ 0.520000] NET: Registered protocol family 1
[ 0.520000] RPC: Registered named UNIX socket transport module.
[ 0.520000] RPC: Registered udp transport module.
[ 0.520000] RPC: Registered tcp transport module.
[ 0.520000] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.520000] Unpacking initramfs...
[ 0.560000] Initramfs unpacking failed: junk in compressed archive
[ 0.560000] Freeing initrd memory: 1024K
[ 0.560000] Disply Reset Status : On
[ 0.560000] Display LVDS register operation
[ 0.560000] Display.0 fps=45 (22 ms), wait= 8 jiffies, Pixelclk=43885285hz
[ 0.560000] LVDS: [4]=LVDS connect to [6]=SYNCGEN0
[ 0.588000] find cec header!_edid_find_target_cec_address: cec physical address 1000
[ 0.588000] hdmi_get_edid_preset: preferred_preset is supported
[ 0.588000] Display HDMI register operation
[ 0.588000] Display.0 fps=161 (6 ms), wait= 4 jiffies, Pixelclk=200000000hz
[ 0.588000] bt_bcm: rfkill initialized
[ 0.588000] audit: initializing netlink socket (disabled)
[ 0.588000] type=2000 audit(0.584:1): initialized
[ 0.592000] highmem bounce pool size: 64 pages
[ 0.600000] NFS: Registering the id_resolver key type
[ 0.600000] fuse init (API version 7.18)
[ 0.600000] msgmni has been set to 1151
[ 0.604000] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 0.604000] io scheduler noop registered
[ 0.604000] io scheduler deadline registered
[ 0.604000] io scheduler cfq registered (default)
[ 0.604000] display.0 connected to fb.0 ...
[ 0.604000] nxp-fb.0: dma addr = 0x65600000, buf[0xe4a6ce40]
[ 0.604000] nxp-fb.0: dma addr = 0x65984000, buf[0xe4a6b840]
[ 0.604000] nxp-fb.0: dma addr = 0x65d08000, buf[0xe4a6d180]
[ 0.644000] Fail, wait vsync 0, time:out, condition:0
[ 0.644000] nxp-fb 0: out[0], 1280 * 720 - 32 bpp (phys:65600000 virt:0xe5600000 max:11059200)
[ 0.644000] spu1705: REQ 0x21: i2c xfer error -6
[ 0.644000] spu1705 3-002d: failed to detect chip
[ 0.644000] nxp-uart.0: ttySAC0 at MMIO 0xc00a1000 (irq = 39) is a S3C6400/10
[ 1.564000] HDMI HPD State 0x1
[ 1.588000] find cec header!_edid_find_target_cec_address: cec physical address 1000
[ 1.588000] _hdmi_hpd_changed: edid update success, preset 2
[ 1.588000] notify_hpd_changed: state 1
[ 1.588000] hdmi_run entered
[ 1.596000] HDMI PHY Ready!!!
[ 1.596000] Display.0 fps=161 (6 ms), wait= 4 jiffies, Pixelclk=200000000hz
[ 1.596000] Fail, HDMI is already connected to SYNCGEN0 ...
[ 1.596000] _set_remote_sync: failed to connect to source
[ 1.596000] _calc_hdmi_sync_param: _h_sync_offset 0
[ 1.620000] hdmi_run exit
[ 2.188000] console [ttySAC0] enabled
[ 2.192000] nxp-uart.1: ttySAC1 at MMIO 0xc00a0000 (irq = 38) is a S3C6400/10
[ 2.200000] nxp-uart.2: ttySAC2 at MMIO 0xc00a2000 (irq = 40) is a S3C6400/10
[ 2.208000] nxp-uart.3: ttySAC3 at MMIO 0xc00a3000 (irq = 41) is a S3C6400/10
[ 2.216000] nxp-uart.4: ttySAC4 at MMIO 0xc006d000 (irq = 42) is a S3C6400/10
[ 2.220000] Matirx PWM init
[ 2.224000] iio-adc initialized
[ 2.232000] loop: module loaded
[ 2.232000] tun: Universal TUN/TAP device driver, 1.6
[ 2.236000] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 2.244000] -- nxpmac initialize --
[ 2.244000] stmmac - user ID: 0x37, Synopsys ID: 0x37
[ 2.252000] Ring mode enabled
[ 2.252000] DMA HW capability register supported
[ 2.256000] Enhanced/Alternate descriptors
[ 2.264000] Enabled extended descriptors
[ 2.268000] RX Checksum Offload Engine supported (type 2)
[ 2.272000] TX Checksum insertion supported
[ 2.276000] Wake-Up On Lan supported
[ 2.280000] Enable RX Mitigation via HW Watchdog Timer
[ 2.320000] stmmac: probed
[ 2.320000] eth0: PHY ID 001cc915 at 0 IRQ 257 (stmmac-0:00)
[ 2.324000] eth0: PHY ID 001cc915 at 7 IRQ 257 (stmmac-0:07) active
[ 2.328000] PPP generic driver version 2.4.2
[ 2.336000] PPP BSD Compression module registered
[ 2.340000] PPP Deflate Compression module registered
[ 2.344000] PPP MPPE Compression module registered
[ 2.348000] NET: Registered protocol family 24
[ 2.352000] usbcore: registered new interface driver asix
[ 2.360000] usbcore: registered new interface driver cdc_ether
[ 2.364000] usbcore: registered new interface driver net1080
[ 2.368000] usbcore: registered new interface driver cdc_subset
[ 2.376000] usbcore: registered new interface driver zaurus
[ 2.380000] usbcore: registered new interface driver cdc_ncm
[ 2.388000] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.392000] nxp-ehci nxp-ehci: SLsi Synopsys EHCI Host Controller
[ 2.400000] nxp-ehci nxp-ehci: new USB bus registered, assigned bus number 1
[ 2.408000] nxp-ehci nxp-ehci: irq 82, io mem 0xc0030000
[ 2.424000] nxp-ehci nxp-ehci: USB 0.0 started, EHCI 1.00
[ 2.424000] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.428000] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.436000] usb usb1: Product: SLsi Synopsys EHCI Host Controller
[ 2.440000] usb usb1: Manufacturer: Linux 3.4.39-FriendlyARM ehci_hcd
[ 2.448000] usb usb1: SerialNumber: nxp-ehci
[ 2.452000] hub 1-0:1.0: USB hub found
[ 2.456000] hub 1-0:1.0: 3 ports detected
[ 2.460000] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 2.600000] HDMI HPD State 0x1
[ 2.668000] Core Release: 2.93a
[ 2.668000] Setting default values for core params
[ 2.668000] Finished setting default values for core params
[ 2.780000] usb 1-1: new high-speed USB device number 2 using nxp-ehci
[ 2.872000] Using Buffer DMA mode
[ 2.876000] Dedicated Tx FIFOs mode
[ 2.876000] dwc_otg dwc_otg: DWC OTG Controller
[ 2.880000] dwc_otg dwc_otg: new USB bus registered, assigned bus number 2
[ 2.888000] dwc_otg dwc_otg: irq 81, io mem 0x00000000
[ 2.892000] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.900000] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.904000] usb usb2: Product: DWC OTG Controller
[ 2.912000] usb usb2: Manufacturer: Linux 3.4.39-FriendlyARM dwc_otg_hcd
[ 2.912000] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610
[ 2.912000] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 2.912000] usb 1-1: Product: USB2.0 Hub
[ 2.912000] hub 1-1:1.0: USB hub found
[ 2.912000] hub 1-1:1.0: 4 ports detected
[ 2.944000] usb usb2: SerialNumber: dwc_otg
[ 2.948000] hub 2-0:1.0: USB hub found
[ 2.952000] hub 2-0:1.0: 1 port detected
[ 2.956000] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 2.960000] nxp-ohci nxp-ohci: SLsi Synopsys OHCI Host Controller
[ 2.968000] nxp-ohci nxp-ohci: new USB bus registered, assigned bus number 3
[ 2.972000] nxp-ohci nxp-ohci: irq 82, io mem 0xc0020000
[ 3.044000] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 3.044000] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.052000] usb usb3: Product: SLsi Synopsys OHCI Host Controller
[ 3.056000] usb usb3: Manufacturer: Linux 3.4.39-FriendlyARM ohci_hcd
[ 3.064000] usb usb3: SerialNumber: nxp-ohci
[ 3.068000] hub 3-0:1.0: USB hub found
[ 3.072000] hub 3-0:1.0: 3 ports detected
[ 3.076000] Initializing USB Mass Storage driver...
[ 3.080000] usbcore: registered new interface driver usb-storage
[ 3.084000] USB Mass Storage support registered.
[ 3.092000] usbcore: registered new interface driver usbserial
[ 3.096000] usbcore: registered new interface driver usbserial_generic
[ 3.104000] USB Serial support registered for generic
[ 3.108000] usbserial: USB Serial Driver core
[ 3.112000] usbcore: registered new interface driver ch341
[ 3.116000] USB Serial support registered for ch341-uart
[ 3.124000] usbcore: registered new interface driver cp210x
[ 3.128000] USB Serial support registered for cp210x
[ 3.132000] usbcore: registered new interface driver ftdi_sio
[ 3.140000] USB Serial support registered for FTDI USB Serial Device
[ 3.144000] ftdi_sio: v1.6.0:USB FTDI Serial Converters Driver
[ 3.152000] usbcore: registered new interface driver option
[ 3.156000] USB Serial support registered for GSM modem (1-port)
[ 3.164000] usbcore: registered new interface driver pl2303
[ 3.168000] USB Serial support registered for pl2303
[ 3.172000] usbcore: registered new interface driver ti_usb_3410_5052
[ 3.180000] USB Serial support registered for TI USB 3410 1 port adapter
[ 3.188000] USB Serial support registered for TI USB 5052 2 port adapter
[ 3.192000] ti_usb_3410_5052: v0.10:TI USB 3410/5052 Serial Driver
[ 3.200000] android_usb gadget: Mass Storage Function, version: 2009/09/11
[ 3.208000] android_usb gadget: Number of LUNs=1
[ 3.212000] lun0: LUN: removable file: (no medium)
[ 3.216000] android_usb gadget: android_usb ready
[ 3.220000] mousedev: PS/2 mouse device common for all mice
[ 3.228000] input: Nexell Keypad as /devices/platform/nxp-keypad/input/input0
[ 3.232000] usbcore: registered new interface driver xpad
[ 3.240000] i2c-core: driver [IT7260-ts] using legacy suspend method
[ 3.244000] i2c-core: driver [IT7260-ts] using legacy resume method
[ 3.252000] <<-GTP-INFO->> GTP driver installing...
[ 3.256000] himax_ts 2-0048: Unable to get DevId
[ 3.260000] touchscreen-1wire initialized
[ 3.264000] backlight-1wire initialized
[ 3.268000] onewire: REQ 0x60: i2c write error -6
[ 3.272000] input: fa_ts_input as /devices/virtual/input/input1
[ 3.280000] ts-if initialized
[ 3.280000] [RTC] day=2016.01.01 time=09:42:57
[ 3.288000] nxp-rtc nxp-rtc.0: rtc core: registered nxp-rtc as rtc0
[ 3.292000] i2c /dev entries driver
[ 3.296000] ov5640_probe
[ 3.300000] ...................................ov5640_probe 2255
[ 3.304000] ...................................ov5640_video_probe 2212
[ 3.312000] ov5640_video_probe
[ 3.312000] addr= 3C, reg_read->i2c_master_send, data=0x300A
[ 3.320000] reg_read->i2c_master_recv, val=0x56
[ 3.324000] addr= 3C, reg_read->i2c_master_send, data=0x300B
[ 3.332000] reg_read->i2c_master_recv, val=0x40
[ 3.336000] OV5640 Chip ID 0x5640 detected
[ 3.340000] addr= 3C, reg_read->i2c_master_send, data=0x4730
[ 3.344000] reg_read->i2c_master_recv, val=0x0
[ 3.348000] addr= 3C, reg_write->i2c_master_send, reg=0x4730, val=0x01
[ 3.356000] ov5640_initialize_ctrls.............1809...........
[ 3.360000] Error: Driver 'nxp_edid' is already registered, aborting...
[ 3.368000] nxp_edid_init: failed to i2c_add_driver()
[ 3.372000] hdmi_init_context: failed to nxp_edid_init()
[ 3.376000] register_nxp_hdmi: failed to hdmi_init_context()
[ 3.384000] register_nxp_out: failed to register_nxp_hdmi()
[ 3.388000] ------------[ cut here ]------------
[ 3.392000] WARNING: at kernel/irq/manage.c:1196 __free_irq+0xa0/0x1c0()
[ 3.400000] Trying to free already-free IRQ 0
[ 3.404000] Modules linked in:
[ 3.408000] [<c00151c4>] (unwind_backtrace+0x0/0x12c) from [<c0041230>] (warn_slowpath_common+0x54/0x64)
[ 3.416000] [<c0041230>] (warn_slowpath_common+0x54/0x64) from [<c0041270>] (warn_slowpath_fmt+0x30/0x40)
[ 3.428000] [<c0041270>] (warn_slowpath_fmt+0x30/0x40) from [<c00b5470>] (__free_irq+0xa0/0x1c0)
[ 3.436000] [<c00b5470>] (__free_irq+0xa0/0x1c0) from [<c00b5624>] (free_irq+0x4c/0xa4)
[ 3.444000] [<c00b5624>] (free_irq+0x4c/0xa4) from [<c002f790>] (hdmi_deinit_context+0x30/0x68)
[ 3.452000] [<c002f790>] (hdmi_deinit_context+0x30/0x68) from [<c03d9524>] (unregister_nxp_hdmi+0x24/0x4c)
[ 3.460000] [<c03d9524>] (unregister_nxp_hdmi+0x24/0x4c) from [<c03d563c>] (register_nxp_out+0x164/0x220)
[ 3.472000] [<c03d563c>] (register_nxp_out+0x164/0x220) from [<c060e280>] (nxp_v4l2_probe+0x2bc/0x3a8)
[ 3.480000] [<c060e280>] (nxp_v4l2_probe+0x2bc/0x3a8) from [<c02cd8c8>] (driver_probe_device+0xb4/0x360)
[ 3.492000] [<c02cd8c8>] (driver_probe_device+0xb4/0x360) from [<c02cdc44>] (__driver_attach+0x8c/0x90)
[ 3.500000] [<c02cdc44>] (__driver_attach+0x8c/0x90) from [<c02cbb4c>] (bus_for_each_dev+0x68/0x9c)
[ 3.508000] [<c02cbb4c>] (bus_for_each_dev+0x68/0x9c) from [<c02cce6c>] (bus_add_driver+0xd4/0x290)
[ 3.516000] [<c02cce6c>] (bus_add_driver+0xd4/0x290) from [<c02ce24c>] (driver_register+0x78/0x134)
[ 3.528000] [<c02ce24c>] (driver_register+0x78/0x134) from [<c00086f0>] (do_one_initcall+0x114/0x16c)
[ 3.536000] [<c00086f0>] (do_one_initcall+0x114/0x16c) from [<c0877998>] (kernel_init+0x13c/0x1d0)
[ 3.544000] [<c0877998>] (kernel_init+0x13c/0x1d0) from [<c000f7ec>] (kernel_thread_exit+0x0/0x8)
[ 3.552000] ---[ end trace 3eae0ee1bf538aad ]---
[ 3.560000] Unable to handle kernel NULL pointer dereference at virtual address 00000004
[ 3.568000] pgd = c0004000
[ 3.568000] [00000004] *pgd=00000000
[ 3.572000] Internal error: Oops: 5 [#1] PREEMPT SMP ARM
[ 3.576000] Modules linked in:
[ 3.580000] CPU: 3 Tainted: G W (3.4.39-FriendlyARM #6)
[ 3.588000] PC is at dev_set_drvdata+0x8/0x44
[ 3.592000] LR is at hdmi_deinit_context+0x38/0x68
[ 3.596000] pc : [<c02cd454>] lr : [<c002f798>] psr: 60000113
[ 3.596000] sp : e5043ec0 ip : 00000000 fp : 00000000
[ 3.608000] r10: 00000000 r9 : c08d7b70 r8 : c08d8754
[ 3.612000] r7 : e4ba9c00 r6 : ffffffea r5 : 00000000 r4 : 00000000
[ 3.620000] r3 : 00000000 r2 : 00000003 r1 : 00000000 r0 : 00000000
[ 3.624000] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel
[ 3.632000] Control: 10c5383d Table: 4000406a DAC: 00000015
[ 3.640000]
[ 3.640000] PC: 0xc02cd3d4:
[ 3.644000] d3d4 e1a00004 eb000cce e5940004 e3a03000 e584305c e2800034 eb0cf5b1 e5943058
[ 3.652000] d3f4 e3530000 08bd8038 e593003c e1a02004 e3a01006 e8bd4038 e28000c0 eaf664b6
[ 3.660000] d414 e595301c e3530000 1affffea eaffffeb e92d4038 e2804034 e1a05000 e1a00004
[ 3.668000] d434 eb0d2b7b e1a00005 ebffffc8 e1a00004 e8bd4038 ea0d2afb e92d4010 e1a04000
[ 3.676000] d454 e5903004 e24dd008 e3530000 0a000003 e3a00000 e583105c e28dd008 e8bd8010
[ 3.684000] d474 e58d1004 ebfff5f0 e3500000 1afffff9 e5943004 e59d1004 eafffff4 e92d4010
[ 3.692000] d494 e3004194 e34c408f e1a00004 eb0d2b60 e1a03004 e5b32048 e1520003 0a000008
[ 3.700000] d4b4 e594104c e284c024 e5940028 e5820004 e5802000 e581c000 e5841028 e5843048
[ 3.708000]
[ 3.708000] LR: 0xc002f718:
[ 3.712000] f718 e1a00008 ebfffca2 e1a00007 ebfff60f e1a00005 eafffff0 e3050c18 e59f1020
[ 3.720000] f738 e34c0078 eb179290 eafffff4 e3050bf4 e59f100c e34c0078 eb17928b eafffff1
[ 3.728000] f758 c092e38c c061e484 e30b3078 e92d4010 e34c3091 e1a04000 e1d32ab2 e3120004
[ 3.736000] f778 1a00000b e2840070 eb00b129 e1a01004 e594002c eb021791 e28400b4 eb0f8672
[ 3.744000] f798 e2840f79 ebfffc82 e2840f7f e8bd4010 eafff5ee e3011464 e2830090 e34c107b
[ 3.752000] f7b8 e59f2004 eb0992c3 eaffffed c061e498 eafffd3b e5801250 e12fff1e e92d4038
[ 3.760000] f7d8 e30b3078 e34c3091 e1a04000 e1d32bba e3120004 1a000032 e3040258 e59f10f0
[ 3.768000] f7f8 e34c0078 eb179260 e5943028 e3530008 18bd8038 e3a00000 e3a05064 e1a01000
[ 3.776000]
[ 3.776000] SP: 0xe5043e40:
[ 3.784000] 3e40 e5043e54 c006fa90 e521f088 e5043e8c 00000000 c061a120 e521f088 c060a9ac
[ 3.792000] 3e60 c02cd454 60000113 ffffffff e5043eac c08d8754 c000e858 00000000 00000000
[ 3.800000] 3e80 00000003 00000000 00000000 00000000 ffffffea e4ba9c00 c08d8754 c08d7b70
[ 3.808000] 3ea0 00000000 00000000 00000000 e5043ec0 c002f798 c02cd454 60000113 ffffffff
[ 3.816000] 3ec0 e4baa8ac c002f798 e4baa800 c03d9524 e4bb7dc0 c03d563c 00000000 c03d5348
[ 3.824000] 3ee0 e4b9ea00 00000001 e4ba9f64 c060e280 c0a05e00 e4ba9ed0 00000000 c08d7b70
[ 3.832000] 3f00 c09f31b0 c091da00 c0901acc c092c880 0000015b c08a4c5c c089466c c02cd8c8
[ 3.840000] 3f20 e5177f44 e5043f50 c08d7b70 c0901acc c08d7ba4 e4b61380 c092c880 c02cdc44
[ 3.848000]
[ 3.848000] R7: 0xe4ba9b80:
[ 3.852000] 9b80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 3.860000] 9ba0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 3.868000] 9bc0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 3.876000] 9be0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 3.884000] 9c00 c08d7b70 00000000 c065cee0 00000000 c08d7b70 e4b61480 e4bb5540 e4a1413c
[ 3.892000] 9c20 e4b9e00c c08d7b78 e50f2580 c08f00a0 e4bb55c0 00000003 00000007 00000000
[ 3.900000] 9c40 00000000 00000001 00000000 00000000 dead4ead ffffffff ffffffff e4ba9c5c
[ 3.908000] 9c60 e4ba9c5c 00000000 c08fcd9c 00000000 00000000 00000000 00000000 00010001
[ 3.916000]
[ 3.916000] R8: 0xc08d86d4:
[ 3.920000] 86d4 c08d86d0 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 3.928000] 86f4 00000000 00000000 00000000 00000000 00000000 00000002 c08d8714 00000000
[ 3.936000] 8714 c07869a0 c07869a8 0000002c 00000001 c07869b4 c07a4520 0000002b 00000001
[ 3.944000] 8734 00000000 00000064 c08d8748 00000001 00000000 00000055 00000064 000c3500
[ 3.952000] 8754 c08d87dc c08d875c 00000000 00000000 00000000 c003d7a4 c003d770 c003d75c
[ 3.964000] 8774 c08d87ac c08d877c c08d8784 00000001 5f70786e 70636468 00000000 00000000
[ 3.972000] 8794 00000000 003a0000 00000000 00000000 00000000 00000000 c08d87b4 00000001
[ 3.980000] 87b4 5f70786e 64696465 00000000 00000000 00000000 00500000 00000000 00000000
[ 3.988000]
[ 3.988000] R9: 0xc08d7af0:
[ 3.992000] 7af0 00000000 00000000 00000000 00000000 00000000 c08d7b04 c08d7b04 00000000
[ 4.000000] 7b10 00000000 00000000 00000000 00000000 00000000 dead4ead ffffffff ffffffff
[ 4.008000] 7b30 c08d7b30 c08d7b30 00000000 00000000 00000000 00000000 00000000 00000000
[ 4.016000] 7b50 00000000 00000000 00000000 00000000 00000000 00000000 c07869d4 00000000
[ 4.024000] 7b70 c08f0238 e5177f00 e517e900 c08d7d94 c08d79ac c08f0240 e50f2580 c08f00a0
[ 4.032000] 7b90 e517e980 0000000e 00000007 00000000 00000000 00000000 00000000 00000000
[ 4.040000] 7bb0 dead4ead ffffffff ffffffff c08d7bbc c08d7bbc e5048000 c08f03f0 c0901acc
[ 4.048000] 7bd0 c08d8754 00000000 00000000 00020002 00000000 dead4ead ffffffff ffffffff
[ 4.056000] Process swapper/0 (pid: 1, stack limit = 0xe50422f0)
[ 4.064000] Stack: (0xe5043ec0 to 0xe5044000)
[ 4.068000] 3ec0: e4baa8ac c002f798 e4baa800 c03d9524 e4bb7dc0 c03d563c 00000000 c03d5348
[ 4.076000] 3ee0: e4b9ea00 00000001 e4ba9f64 c060e280 c0a05e00 e4ba9ed0 00000000 c08d7b70
[ 4.084000] 3f00: c09f31b0 c091da00 c0901acc c092c880 0000015b c08a4c5c c089466c c02cd8c8
[ 4.092000] 3f20: e5177f44 e5043f50 c08d7b70 c0901acc c08d7ba4 e4b61380 c092c880 c02cdc44
[ 4.100000] 3f40: 00000000 c0901acc c02cdbb8 c02cbb4c e5006a78 e5177f44 00000000 c0901acc
[ 4.108000] 3f60: c08f03f0 c02cce6c c07869d4 c0901acc c0901acc e5042020 c08a4c54 c092c880
[ 4.116000] 3f80: c092c880 c02ce24c c092c880 e5042020 c08a4c54 c092c880 c092c880 c00086f0
[ 4.124000] 3fa0: c077e448 c091b210 00000006 00000000 c131aa4e 60000013 00000001 c08aa624
[ 4.132000] 3fc0: 00000006 c08a4c54 c092c880 c092c880 0000015b c08a4c5c 00000000 c0877998
[ 4.140000] 3fe0: 00000006 00000006 c0877280 c000f7dc 00000013 c000f7ec ff00ff00 ff00ff02
[ 4.148000] [<c02cd454>] (dev_set_drvdata+0x8/0x44) from [<c03d9524>] (unregister_nxp_hdmi+0x24/0x4c)
[ 4.156000] [<c03d9524>] (unregister_nxp_hdmi+0x24/0x4c) from [<c03d563c>] (register_nxp_out+0x164/0x220)
[ 4.168000] [<c03d563c>] (register_nxp_out+0x164/0x220) from [<c060e280>] (nxp_v4l2_probe+0x2bc/0x3a8)
[ 4.176000] [<c060e280>] (nxp_v4l2_probe+0x2bc/0x3a8) from [<c02cd8c8>] (driver_probe_device+0xb4/0x360)
[ 4.184000] [<c02cd8c8>] (driver_probe_device+0xb4/0x360) from [<c02cdc44>] (__driver_attach+0x8c/0x90)
[ 4.196000] [<c02cdc44>] (__driver_attach+0x8c/0x90) from [<c02cbb4c>] (bus_for_each_dev+0x68/0x9c)
[ 4.204000] [<c02cbb4c>] (bus_for_each_dev+0x68/0x9c) from [<c02cce6c>] (bus_add_driver+0xd4/0x290)
[ 4.212000] [<c02cce6c>] (bus_add_driver+0xd4/0x290) from [<c02ce24c>] (driver_register+0x78/0x134)
[ 4.224000] [<c02ce24c>] (driver_register+0x78/0x134) from [<c00086f0>] (do_one_initcall+0x114/0x16c)
[ 4.232000] [<c00086f0>] (do_one_initcall+0x114/0x16c) from [<c0877998>] (kernel_init+0x13c/0x1d0)
[ 4.240000] [<c0877998>] (kernel_init+0x13c/0x1d0) from [<c000f7ec>] (kernel_thread_exit+0x0/0x8)
[ 4.248000] Code: e8bd4038 ea0d2afb e92d4010 e1a04000 (e5903004)
[ 4.256000] ---[ end trace 3eae0ee1bf538aae ]---
[ 4.260000] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
[ 4.260000]
[ 4.268000] CPU2: stopping
[ 4.268000] [<c00151c4>] (unwind_backtrace+0x0/0x12c) from [<c0014020>] (handle_IPI+0x1d0/0x1e8)
[ 4.268000] [<c0014020>] (handle_IPI+0x1d0/0x1e8) from [<c0008560>] (gic_handle_irq+0x54/0x58)
[ 4.268000] [<c0008560>] (gic_handle_irq+0x54/0x58) from [<c000e8c0>] (__irq_svc+0x40/0x70)
[ 4.268000] Exception stack(0xe509ff88 to 0xe509ffd0)
[ 4.268000] ff80: ffffffed 00000002 00a84000 00000000 c092c948 c061f290
[ 4.268000] ffa0: e509e000 e509e000 c08ce328 e509e018 e509e000 00000000 01000000 e509ffd0
[ 4.268000] ffc0: c000f8ac c000f8b0 60000013 ffffffff
[ 4.268000] [<c000e8c0>] (__irq_svc+0x40/0x70) from [<c000f8b0>] (default_idle+0x2c/0x30)
[ 4.268000] [<c000f8b0>] (default_idle+0x2c/0x30) from [<c000fbe4>] (cpu_idle+0xdc/0x108)
[ 4.268000] [<c000fbe4>] (cpu_idle+0xdc/0x108) from [<40008168>] (0x40008168)
[ 4.268000] CPU0: stopping
[ 4.268000] Exception stack(0xc08b1f58 to 0xc08b1fa0)
[ 4.268000] 1f40: ffffffed 00000000
[ 4.268000] 1f60: 00a72000 00000000 c092c948 c061f290 c08b0000 c08b0000 c08ce328 c08b0028
[ 4.268000] 1f80: c08b0000 00000000 01000000 c08b1fa0 c000f8ac c000f8b0 60000013 ffffffff
[ 4.268000] [<c000fbe4>] (cpu_idle+0xdc/0x108) from [<c0877850>] (start_kernel+0x324/0x330)
[ 4.268000] [<c0877850>] (start_kernel+0x324/0x330) from [<40008044>] (0x40008044)
[ 4.268000] CPU1: stopping
[ 4.268000] Exception stack(0xe506ff88 to 0xe506ffd0)
[ 4.268000] ff80: ffffffed 00000001 00a7b000 00000000 c092c948 c061f290
[ 4.268000] ffa0: e506e000 e506e000 c08ce328 e506e018 e506e000 00000000 01000000 e506ffd0
[ 4.268000] CPU4: stopping
[ 4.268000] Exception stack(0xe50b3f88 to 0xe50b3fd0)
[ 4.268000] 3f80: ffffffed 00000004 00a96000 00000000 c092c948 c061f290
[ 4.268000] 3fa0: e50b2000 e50b2000 c08ce328 e50b2018 e50b2000 00000000 01000000 e50b3fd0
[ 4.268000] 3fc0: c000f8ac c000f8b0 60000113 ffffffff
[ 4.268000] CPU7: stopping
[ 4.268000] Exception stack(0xe510df88 to 0xe510dfd0)
[ 4.268000] df80: ffffffed 00000007 00ab1000 00000000 c092c948 c061f290
[ 4.268000] dfa0: e510c000 e510c000 c08ce328 e510c018 e510c000 00000000 01000000 e510dfd0
[ 4.268000] dfc0: c000f8ac c000f8b0 60000113 ffffffff
[ 4.268000] CPU6: stopping
[ 4.268000] Exception stack(0xe50e3f88 to 0xe50e3fd0)
[ 4.268000] 3f80: ffffffed 00000006 00aa8000 00000000 c092c948 c061f290
[ 4.268000] 3fa0: e50e2000 e50e2000 c08ce328 e50e2018 e50e2000 00000000 01000000 e50e3fd0
[ 4.268000] CPU5: stopping
[ 4.268000] Exception stack(0xe50d9f88 to 0xe50d9fd0)
[ 4.268000] 9f80: ffffffed 00000005 00a9f000 00000000 c092c948 c061f290
[ 4.268000] 9fa0: e50d8000 e50d8000 c08ce328 e50d8018 e50d8000 00000000 01000000 e50d9fd0
[ 4.268000] 9fc0: c000f8ac c000f8b0 60000013 ffffffff
[ 4.268000] Rebooting in 5 seconds..
[ 4.268000] Restarting Linux version 3.4.39-FriendlyARM (root@gibbs) (gcc version 4.9.3 (ctng-1.21.0-229g-FA) ) #6 SMP PREEMPT Tue Jun 12 16:58:47 CST 2018
[ 4.268000]
[ 4.268000] system resetþscratch is broken, clear
working to aarch32
Lock value = 197
DDR3 Init Done!
CCI Init!
CPU0 is Master!
Image Loading Done!
I2C: ready
DRAM: 256 MiB
GLD = 0x42bffeb8
GLBD = 0x42bffe68
PC = 0x42c06220
TAGS = 0x40000100
MACH = [4330]
VER = 0
BOARD= [nanopi3]
LCD = N/A (-1)
In: serial
Out: serial
Err: serial
many thanks
working to aarch32
Lock value = 196
DDR3 Init Done!
CCI Init!
CPU0 is Master!
Image Loading Done!
I2C: ready
DRAM: 256 MiB
GLD = 0x42bffeb8
GLBD = 0x42bffe68
PC = 0x42c06220
TAGS = 0x40000100
MACH = [4330]
VER = 0
BOARD= [nanopi3]
LCD = N/A (-1)
In: serial
Out: serial
Err: serial
HDMI: PHY Ready!!!
Starting kernel ...
[ 0.344000] dummy:
[ 0.372000]
[ 3.640000]
[ 3.708000]
[ 3.776000]
[ 3.848000]
[ 3.916000]
[ 3.988000]
[ 4.260000]
[ 4.268000]
working to aarch32
Lock value = 197
DDR3 Init Done!
CCI Init!
CPU0 is Master!
Image Loading Done!
I2C: ready
DRAM: 256 MiB
GLD = 0x42bffeb8
GLBD = 0x42bffe68
PC = 0x42c06220
TAGS = 0x40000100
MACH = [4330]
VER = 0
BOARD= [nanopi3]
LCD = N/A (-1)
In: serial
Out: serial
Err: serial
