NanaoPi M3 Boot
Posted: Sun Jun 11, 2017 12:29 pm
by dorche
connect only sd card and power to NanoPi M3 then
with image "s5p6818-ubuntu-core-qte-sd4g-20170420.img" blue led is blinking
but with image "s5p6818-android-sd4g-20170420.img" blue led is always on.
search all forums but not work any ...
links :
nanopi m3 wown't boot
nanopi m3 android image
Android stuck at rainbow colored screen
Android not booting
NanoPi M3 boot fails
Nanopi M3 Boot Issues
Android image s5p6818-android-sd4g-20170307.img not boot
how to solve this problem?
Re: NanaoPi M3 Boot
Posted: Mon Jun 12, 2017 8:12 am
by dorche
log of my android boot:
please help me.
watchdog timer start
working to aarch32
waiting for pll change..
 Second Boot by Nexell Co. : Ver0.3.6 - Built on Jun 29 2016 15:19:53
DDR3 POR Init Start 0
Lock value  = 191
GATE CYC    = 0x00000492
GATE CODE   = 0x00000000
Read  DQ    = 0x08080808
Write DQ    = 0x08080808
DDR3 Init Done!
CCI Init!
Wakeup CPU Wakeup Sub CPU 1234567
CPU Wakeup done! WFI is expected.
CPU0 is Master!
Loading from sdmmc...
 Image Loading Done!
Launch to 0x42C00000
U-Boot 2014.07-g87a83ca (Mar 24 2017 - 19:33:41)
PLL : [0] =  800000000, [1] =  800000000, [2] =  614394000, [3] =  800000000
(0) PLL1: CPU  FCLK =  800000000, HCLK = 200000000 (G0)
(7) PLL1: CPU  FCLK =  800000000, HCLK = 200000000 (G1)
(2) PLL3: MEM  FCLK =  800000000, DCLK = 800000000, BCLK = 400000000, PCLK = 200000000
(1) PLL0: BUS  BCLK =  400000000, PCLK = 200000000
(8) PLL0: CCI4 BCLK =  400000000, PCLK = 200000000
(3) PLL0: G3D  BCLK =  400000000
(4) PLL0: CODA BCLK =  400000000, PCLK = 200000000
(5) PLL0: DISP BCLK =  400000000, PCLK = 200000000
(6) PLL0: HDMI PCLK =  100000000
I2C:   ready
DRAM:  256 MiB
Heap = 0x43000000~0x45000000
Code = 0x42c00000~0x42c75984
GLD  = 0x42bffeb8
GLBD = 0x42bffe68
SP   = 0x42bffe68,0x42bffe50(CURR)
PC   = 0x42c06220
TAGS = 0x40000100
PAGE = 0x42c80000~0x42c8c000
MACH = [4330]
VER  = 0
BOARD= [nanopi3]
LCD  = N/A (-1)
MMC:   NXP DWMMC: 0, NXP DWMMC: 1, NXP DWMMC: 2
In:    serial
Out:   serial
Err:   serial
switch to partitions #0, OK
mmc0 is current device
HDMI: display.0, preset 0 (1280 *  720)
HDMI: PHY Ready!!!
Failed to mount ext2 filesystem...
** Unrecognized filesystem type **
can't find bmp at 0x47000000 (type:0xffff), fb:0x46000000...
LOGO: DRAW FB=0x46000000, X=1280, Y= 720, Bpp=32
Hit any key to stop autoboot:  0
Wrong Image Format for bootm command
ERROR: can't get kernel image!
s5p6818#
Re: NanaoPi M3 Boot
Posted: Sat Jun 24, 2017 5:46 am
by dorche
Redownload image and now with this debug :
     €             ے    €      ü           ہ      à    چ،پ¥حپ‰ة½­•¹±پچ±•…ة5)ف…رچ،‘½‌پر¥µ•ةپحر…ةر5)5))ف½ة­¥¹‌پر½پ……ةچ،حة5)ف…¥ر¥¹‌پ™½ةپء±±پچ،…¹‌•¹¹5)ے
Lock value  = 191
DDR3 Init Done!
CCI Init!
CPU0 is Master!
 Image Loading Done!
I2C:   ready
DRAM:  256 MiB
GLD  = 0x42bffeb8
GLBD = 0x42bffe68
PC   = 0x42c06220
TAGS = 0x40000100
MACH = [4330]
VER  = 0
BOARD= [nanopi3]
LCD  = N/A (-1)
In:    serial
Out:   serial
Err:   serial
Writing to MMC(0)... done
HDMI: PHY Ready!!!
DONE: Logo bmp 800 by 480 (3bpp), len=1152056
DRAW: 0x47000000 -> 0x46000000
Hit any key to stop autoboot:  1  0
## Booting kernel from Legacy Image at 48000000 ...
   Image Name:   Linux-3.4.39-FriendlyARM
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    4627360 Bytes = 4.4 MiB
   Load Address: 40008000
   Entry Point:  40008000
   Verifying Checksum ... OK
   Loading Kernel Image ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0
[    0.000000] Initializing cgroup subsys cpu
[    0.000000] Linux version 3.4.39-FriendlyARM (root@jensen) (gcc version 4.9.3 (ctng-1.21.0-229g-FA) ) #1 SMP PREEMPT Wed Mar 1 14:07:39 HKT 2017
[    0.000000] CPU: ARMv7 Processor [410fd033] revision 3 (ARMv7), cr=10c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine: NANOPI3
[    0.000000] Ignoring unrecognised tag 0x00000000
[    0.000000] Display: HDMI selected
[    0.000000] nxp_reserve_mem: reserve CMA: size 167772160
[    0.000000] NXP/CMA: Reserved 0x65600000/0x0a000000 for 'ion'
[    0.000000] NXP/CMA: success register cma region for 'ion'
[    0.000000] rquest persistent memory from 655fc000 (00000000)-00004000
[    0.000000] Initialized persistent memory from 655fc000-655fffff
[    0.000000] Memory policy: ECC disabled, Data cache writealloc
[    0.000000] CPU : iomap[ 0]: p 0xc0000000 -> v 0xf0000000 len=0x300000
[    0.000000] CPU : iomap[ 1]: p 0xe0000000 -> v 0xf0300000 len=0x100000
[    0.000000] CPU : iomap[ 2]: p 0xfff00000 -> v 0xf0400000 len=0x100000
[    0.000000] CPU : iomap[ 3]: p 0x2c000000 -> v 0xf0500000 len=0x100000
[    0.000000] CPU : iomap[ 4]: p 0x00000000 -> v 0xf0600000 len=0x100000
[    0.000000] CPU : DMA Zone Size =16M, CORE 8
[    0.000000] s5p6818-NanoPi3: Board initialized
[    0.000000] CPU : Clock Generator= 58 EA, DVFS = support, PLL.1
[    0.000000] PLL : [0] =  800000000, [1] =  800000000, [2] =  614394000, [3] =  800000000
[    0.000000] (0) PLL1: CPU  FCLK =  800000000, HCLK = 200000000 (G0)
[    0.000000] (7) PLL1: CPU  FCLK =  800000000, HCLK = 200000000 (G1)
[    0.000000] (2) PLL3: MEM  FCLK =  800000000, DCLK = 800000000, BCLK = 400000000, PCLK = 200000000
[    0.000000] (1) PLL0: BUS  BCLK =  400000000, PCLK = 200000000
[    0.000000] (8) PLL0: CCI4 BCLK =  400000000, PCLK = 200000000
[    0.000000] (3) PLL0: G3D  BCLK =  400000000
[    0.000000] (4) PLL0: CODA BCLK =  400000000, PCLK = 200000000
[    0.000000] (5) PLL0: DISP BCLK =  400000000, PCLK = 200000000
[    0.000000] (6) PLL0: HDMI PCLK =  100000000
[    0.000000] PERCPU: Embedded 9 pages/cpu @c1316000 s12608 r8192 d16064 u36864
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 260096
[    0.000000] Kernel command line: console=ttySAC0,115200n8 androidboot.console=ttySAC0 androidboot.serialno=0123456789abcdef initrd=0x49000000,0x100000 lcd=HDMI720P60
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] allocated 2097152 bytes of page_cgroup
[    0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[    0.000000] Memory: 1024MB = 1024MB total
[    0.000000] Memory: 861004k/861004k available, 187572k reserved, 272384K highmem
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[    0.000000]     vmalloc : 0xef800000 - 0xfee00000   ( 246 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xef600000   ( 758 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .text : 0xc0008000 - 0xc0870d28   (8612 kB)
[    0.000000]       .init : 0xc0871000 - 0xc08a8140   ( 221 kB)
[    0.000000]       .data : 0xc08aa000 - 0xc0925c30   ( 496 kB)
[    0.000000]        .bss : 0xc0925c54 - 0xc0b08da0   (1933 kB)
[    0.000000] SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] NR_IRQS:272
[    0.000000] GIC   @f0009000: start   0 (gic 31)
[    0.000000] GPIO  @f001a000: start 106, mask 0xffffffff (gpio 85)
[    0.000000] GPIO  @f001b000: start 138, mask 0xffffffff (gpio 86)
[    0.000000] GPIO  @f001c000: start 170, mask 0xffffffff (gpio 87)
[    0.000000] GPIO  @f001d000: start 202, mask 0xffffffff (gpio 88)
[    0.000000] GPIO  @f001e000: start 234, mask 0xffffffff (gpio 89)
[    0.000000] ALIVE @f0010800: start 266, mask 0x000000ff (alive 36, num 6)
[    0.000000] timer.0: source,  10000000(HZ:250), mult:3355443200
[    0.000000] timer.1: event ,  10000000(HZ:250), mult:42949673
[    0.000000] sched_clock: 32 bits at 250 Hz, resolution 4000000ns, wraps every 4294967292ms
[    0.000000] Calibrating delay loop... 1594.36 BogoMIPS (lpj=3188736)
[    0.048000] pid_max: default: 32768 minimum: 301
[    0.048000] Security Framework initialized
[    0.048000] SELinux:  Initializing.
[    0.048000] Mount-cache hash table entries: 512
[    0.048000] Initializing cgroup subsys debug
[    0.048000] Initializing cgroup subsys cpuacct
[    0.048000] Initializing cgroup subsys memory
[    0.048000] Initializing cgroup subsys freezer
[    0.048000] CPU: Testing write buffer coherency: ok
[    0.048000] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.048000] hw perfevents: no hardware support available
[    0.048000] Setting up static identity map for 0x40617400 - 0x40617458
[    0.096000] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.136000] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.172000] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.216000] CPU4: thread -1, cpu 0, socket 4, mpidr 80040400
[    0.256000] CPU5: thread -1, cpu 1, socket 4, mpidr 80040401
[    0.296000] CPU6: thread -1, cpu 2, socket 4, mpidr 80040402
[    0.336000] CPU7: thread -1, cpu 3, socket 4, mpidr 80040403
[    0.336000] Brought up 8 CPUs
[    0.336000] SMP: Total of 8 processors activated (12754.94 BogoMIPS).
[    0.344000] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 3
[    0.344000] pwm: max = 50000000 hz
[    0.344000] prepare_gpio_suspend:
[    0.344000]   alfn[0][0]: 0x00000000, alfn[0][1]: 0x00000000
[    0.344000]   alfn[1][0]: 0x66800000, alfn[1][1]: 0x55555566
[    0.344000]   alfn[2][0]: 0x55555555, alfn[2][1]: 0x00555555
[    0.344000]   alfn[3][0]: 0x00000000, alfn[3][1]: 0x00000000
[    0.344000]   alfn[4][0]: 0x00000000, alfn[4][1]: 0x55540000
[    0.348000] dummy:
[    0.348000] NET: Registered protocol family 16
[    0.348000] persistent_ram: uncorrectable error in header
[    0.348000] persistent_ram: no valid data in buffer (sig = 0xffffffff)
[    0.360000] console [ram-1] enabled
[    0.360000] [Register machine platform devices]
[    0.360000] mach: add amba device pl08xdmac.0
[    0.360000] mach: add amba device pl08xdmac.1
[    0.360000] mach: add device uart0
[    0.360000] mach: add device uart1
[    0.360000] mach: add device uart2
[    0.360000] mach: add device uart3
[    0.364000] mach: add device uart4
[    0.364000] mach: add device syncgen [2]
[    0.364000] mach: add device lcd
[    0.364000] mach: add device i2c bus (array:3)
[    0.364000] mach: add device Real Time Clock
[    0.364000] mach: add device generic pwm (array:4)
[    0.364000] mach: add device generic gpio (array:6)
[    0.364000] mach: add device i2s (array:1)
[    0.364000] mach: add device spdif tx
[    0.364000] mach: add device usb_ehci
[    0.364000] mach: add device usb_ohci
[    0.364000] mach: add device usb otg
[    0.364000] mach: add device ion-nxp
[    0.368000] mach: add graphic device opengl|es
[    0.368000] [Register board platform devices]
[    0.368000] plat: board revision 7
[    0.368000] plat: add dynamic frequency (pll.1)
[    0.368000] plat: add device TMU
[    0.368000] plat: add framebuffer
[    0.368000] plat: boot from mmc.0
[    0.368000] plat: add device sdmmc [0]
[    0.368000] plat: add device sdmmc [1]
[    0.368000] plat: add backlight pwm device
[    0.368000] plat: add device keypad
[    0.368000] plat: add device spdif playback
[    0.368000] plat: add device asoc-es8316
[    0.372000] plat: add device nxp-v4l2
[    0.372000] plat: register spidev
[    0.372000] plat: add touch(ft5x0x) device
[    0.372000] plat: add touch(goodix) device
[    0.372000] plat: goodix: irq=186 (80)
[    0.372000] plat: add touch(himax) device
[    0.372000] plat: add touch(it7260) device
[    0.372000] plat: add onewire ts device
[    0.376000] plat: add iio adc device
[    0.376000] plat: add device hdmi-cec
[    0.376000] plat: add device nxp-gmac
[    0.376000] plat: add device gpio_led
[    0.376000]
[    0.376000] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.376000] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.400000] bio: create slab <bio-0> at 0
[    0.400000] gpiochip_add: registered GPIOs 0 to 31 on device: GPIOA
[    0.400000] gpiochip_add: registered GPIOs 32 to 63 on device: GPIOB
[    0.400000] gpiochip_add: registered GPIOs 64 to 95 on device: GPIOC
[    0.400000] gpiochip_add: registered GPIOs 96 to 127 on device: GPIOD
[    0.400000] gpiochip_add: registered GPIOs 128 to 159 on device: GPIOE
[    0.400000] gpiochip_add: registered GPIOs 160 to 165 on device: GPIOALV
[    0.400000] pl08xdmac pl08xdmac.0: Unbalanced pm_runtime_enable!
[    0.400000] pl08xdmac pl08xdmac.0: initialized 8 virtual memcpy channels
[    0.400000] pl08xdmac pl08xdmac.0: initialized 16 virtual slave channels
[    0.404000] pl08xdmac pl08xdmac.0: DMA: PL080 rev1 at 0xc0000000 irq 33
[    0.404000] pl08xdmac pl08xdmac.1: Unbalanced pm_runtime_enable!
[    0.404000] pl08xdmac pl08xdmac.1: initialized 8 virtual memcpy channels
[    0.404000] pl08xdmac pl08xdmac.1: initialized 15 virtual slave channels
[    0.404000] pl08xdmac pl08xdmac.1: DMA: PL080 rev1 at 0xc0001000 irq 34
[    0.404000] nxp_ion_probe success!!!
[    0.404000] SCSI subsystem initialized
[    0.404000] usbcore: registered new interface driver usbfs
[    0.408000] usbcore: registered new interface driver hub
[    0.408000] usbcore: registered new device driver usb
[    0.408000] i2c-gpio i2c-gpio.3: using pins 159 (SDA) and 158 (SCL)
[    0.408000] s3c-i2c s3c2440-i2c.0: i2c-0: S3C I2C adapter
[    0.408000] s3c-i2c s3c2440-i2c.0: slave address 0x10
[    0.408000] s3c-i2c s3c2440-i2c.0: bus frequency set to 390 KHz
[    0.408000] s3c-i2c s3c2440-i2c.1: i2c-1: S3C I2C adapter
[    0.408000] s3c-i2c s3c2440-i2c.1: slave address 0x10
[    0.408000] s3c-i2c s3c2440-i2c.1: bus frequency set to 97 KHz
[    0.412000] s3c-i2c s3c2440-i2c.2: i2c-2: S3C I2C adapter
[    0.412000] s3c-i2c s3c2440-i2c.2: slave address 0x10
[    0.412000] s3c-i2c s3c2440-i2c.2: bus frequency set to 195 KHz
[    0.412000] Linux media interface: v0.10
[    0.412000] Linux video capture interface: v2.00
[    0.412000] pps_core: LinuxPPS API ver. 1 registered
[    0.412000] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.412000] PTP clock support registered
[    0.420000] axp_mfd 3-0034: AXP (CHIP ID: 0x06) detected
[    0.424000] axp22_ldo1: 3000 mV
[    0.428000] axp22_aldo1: 700 <--> 3300 mV at 3300 mV
[    0.432000] axp22_aldo2: 700 <--> 3300 mV at 1800 mV
[    0.436000] axp22_aldo3: 700 <--> 3300 mV at 1000 mV
[    0.440000] axp22_dldo1: 700 <--> 3300 mV at 3300 mV
[    0.444000] axp22_dldo2: No configuration
[    0.444000] axp22_dldo2: 700 <--> 3300 mV at 700 mV
[    0.444000] axp22_dldo3: No configuration
[    0.448000] axp22_dldo3: 700 <--> 3300 mV at 700 mV
[    0.448000] axp22_dldo4: No configuration
[    0.448000] axp22_dldo4: 700 <--> 3300 mV at 700 mV
[    0.452000] axp22_eldo1: 700 <--> 3300 mV at 1800 mV
[    0.460000] axp22_eldo2: 700 <--> 3300 mV at 3300 mV
[    0.460000] axp22_eldo3: No configuration
[    0.464000] axp22_eldo3: 700 <--> 3300 mV at 700 mV
[    0.464000] axp22_dc5ldo: No configuration
[    0.464000] axp22_dc5ldo: 700 <--> 1400 mV at 1200 mV
[    0.468000] axp22_dcdc1: 1600 <--> 3400 mV at 3300 mV
[    0.476000] axp22_dcdc2: 600 <--> 1540 mV at 1200 mV
[    0.480000] axp22_dcdc3: 600 <--> 1860 mV at 1200 mV
[    0.484000] axp22_dcdc4: 600 <--> 1540 mV at 1500 mV
[    0.488000] axp22_dcdc5: 1000 <--> 2550 mV at 1500 mV
[    0.492000] axp22_ldoio0: 700 <--> 3300 mV at 3800 mV
[    0.492000] axp22_ldoio1: 700 <--> 3300 mV at 3800 mV
[    0.496000] Advanced Linux Sound Architecture Driver Version 1.0.25.
[    0.496000] Bluetooth: Core ver 2.19
[    0.496000] NET: Registered protocol family 31
[    0.496000] Bluetooth: HCI device and connection manager initialized
[    0.496000] Bluetooth: HCI socket layer initialized
[    0.496000] Bluetooth: L2CAP socket layer initialized
[    0.496000] Bluetooth: SCO socket layer initialized
[    0.496000] cfg80211: Calling CRDA to update world regulatory domain
[    0.496000] Switching to clocksource source timer
[    0.500000] Clockevents: could not switch to one-shot mode:
[    0.500000] Clockevents: could not switch to one-shot mode: dummy_timer is not functional.
[    0.500000] Could not switch to high resolution mode on CPU 7
[    0.500000]  dummy_timer is not functional.
[    0.500000] Could not switch to high resolution mode on CPU 4
[    0.500000] Could not switch to high resolution mode on CPU 6
[    0.500000] Could not switch to high resolution mode on CPU 5
[    0.500000] Could not switch to high resolution mode on CPU 2
[    0.500000] Could not switch to high resolution mode on CPU 1
[    0.500000] Could not switch to high resolution mode on CPU 3
[    0.500000] Could not switch to high resolution mode on CPU 0
[    0.516000] NET: Registered protocol family 2
[    0.516000] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.516000] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.520000] TCP bind hash table entries: 65536 (order: 8, 1572864 bytes)
[    0.520000] TCP: Hash tables configured (established 131072 bind 65536)
[    0.520000] TCP: reno registered
[    0.520000] UDP hash table entries: 512 (order: 3, 32768 bytes)
[    0.520000] UDP-Lite hash table entries: 512 (order: 3, 32768 bytes)
[    0.520000] NET: Registered protocol family 1
[    0.520000] RPC: Registered named UNIX socket transport module.
[    0.520000] RPC: Registered udp transport module.
[    0.520000] RPC: Registered tcp transport module.
[    0.520000] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.520000] Unpacking initramfs...
[    0.560000] Initramfs unpacking failed: junk in compressed archive
[    0.564000] Freeing initrd memory: 1024K
[    0.564000] Disply Reset Status : On
[    0.564000] Display LCD register operation
[    0.564000] Display.0 fps=45 (22 ms), wait= 8 jiffies, Pixelclk=43885285hz
[    0.564000] LCD : [1]=LCD connect to [6]=SYNCGEN0
[    0.564000] bt_bcm: rfkill initialized
[    0.564000] audit: initializing netlink socket (disabled)
[    0.564000] type=2000 audit(0.560:1): initialized
[    0.564000] highmem bounce pool size: 64 pages
[    0.576000] NFS: Registering the id_resolver key type
[    0.576000] fuse init (API version 7.18)
[    0.576000] msgmni has been set to 1151
[    0.580000] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[    0.580000] io scheduler noop registered
[    0.580000] io scheduler deadline registered
[    0.580000] io scheduler cfq registered (default)
[    0.580000] display.0 connected to fb.0  ...
[    0.580000] nxp-fb.0: dma addr = 0x65600000, buf[0xe49a72c0]
[    0.580000] nxp-fb.0: dma addr = 0x65984000, buf[0xe49a7480]
[    0.580000] nxp-fb.0: dma addr = 0x65d08000, buf[0xe49a7640]
[    0.664000] nxp-fb 0: out[0], 1280 * 720 - 32 bpp (phys:65600000 virt:0xe5600000 max:11059200)
[    0.664000] nxp-uart.0: ttySAC0 at MMIO 0xc00a1000 (irq = 39) is a S3C6400/10
[    2.108000] console [ttySAC0] enabled
[    2.108000] nxp-uart.1: ttySAC1 at MMIO 0xc00a0000 (irq = 38) is a S3C6400/10
[    2.116000] nxp-uart.2: ttySAC2 at MMIO 0xc00a2000 (irq = 40) is a S3C6400/10
[    2.124000] nxp-uart.3: ttySAC3 at MMIO 0xc00a3000 (irq = 41) is a S3C6400/10
[    2.132000] nxp-uart.4: ttySAC4 at MMIO 0xc006d000 (irq = 42) is a S3C6400/10
[    2.140000] Matirx PWM init
[    2.140000] iio-adc   initialized
[    2.148000] loop: module loaded
[    2.148000] tun: Universal TUN/TAP device driver, 1.6
[    2.152000] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    2.160000]  -- nxpmac initialize --
[    2.160000] stmmac - user ID: 0x37, Synopsys ID: 0x37
[    2.168000]  Ring mode enabled
[    2.172000]  DMA HW capability register supported
[    2.176000]  Enhanced/Alternate descriptors
[    2.180000]    Enabled extended descriptors
[    2.184000]  RX Checksum Offload Engine supported (type 2)
[    2.188000]  TX Checksum insertion supported
[    2.192000]  Wake-Up On Lan supported
[    2.196000]  Enable RX Mitigation via HW Watchdog Timer
[    2.240000] stmmac: probed
[    2.240000] eth0: PHY ID 001cc915 at 0 IRQ 257 (stmmac-0:00)
[    2.244000] eth0: PHY ID 001cc915 at 7 IRQ 257 (stmmac-0:07) active
[    2.252000] PPP generic driver version 2.4.2
[    2.256000] PPP BSD Compression module registered
[    2.260000] PPP Deflate Compression module registered
[    2.264000] PPP MPPE Compression module registered
[    2.268000] NET: Registered protocol family 24
[    2.272000] usbcore: registered new interface driver asix
[    2.280000] usbcore: registered new interface driver cdc_ether
[    2.284000] usbcore: registered new interface driver net1080
[    2.288000] usbcore: registered new interface driver cdc_subset
[    2.296000] usbcore: registered new interface driver zaurus
[    2.300000] usbcore: registered new interface driver cdc_ncm
[    2.308000] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.312000] nxp-ehci nxp-ehci: SLsi Synopsys EHCI Host Controller
[    2.320000] nxp-ehci nxp-ehci: new USB bus registered, assigned bus number 1
[    2.328000] nxp-ehci nxp-ehci: irq 82, io mem 0xc0030000
[    2.344000] nxp-ehci nxp-ehci: USB 0.0 started, EHCI 1.00
[    2.344000] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    2.348000] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.356000] usb usb1: Product: SLsi Synopsys EHCI Host Controller
[    2.360000] usb usb1: Manufacturer: Linux 3.4.39-FriendlyARM ehci_hcd
[    2.368000] usb usb1: SerialNumber: nxp-ehci
[    2.372000] hub 1-0:1.0: USB hub found
[    2.376000] hub 1-0:1.0: 3 ports detected
[    2.380000] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    2.584000] Core Release: 2.93a
[    2.588000] Setting default values for core params
[    2.588000] Finished setting default values for core params
[    2.700000] usb 1-1: new high-speed USB device number 2 using nxp-ehci
[    2.792000] Using Buffer DMA mode
[    2.792000] Dedicated Tx FIFOs mode
[    2.796000] dwc_otg dwc_otg: DWC OTG Controller
[    2.800000] dwc_otg dwc_otg: new USB bus registered, assigned bus number 2
[    2.808000] dwc_otg dwc_otg: irq 81, io mem 0x00000000
[    2.812000] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    2.820000] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.824000] usb usb2: Product: DWC OTG Controller
[    2.832000] usb usb2: Manufacturer: Linux 3.4.39-FriendlyARM dwc_otg_hcd
[    2.832000] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610
[    2.832000] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    2.832000] usb 1-1: Product: USB2.0 Hub
[    2.832000] hub 1-1:1.0: USB hub found
[    2.832000] hub 1-1:1.0: 4 ports detected
[    2.864000] usb usb2: SerialNumber: dwc_otg
[    2.868000] hub 2-0:1.0: USB hub found
[    2.872000] hub 2-0:1.0: 1 port detected
[    2.876000] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    2.880000] nxp-ohci nxp-ohci: SLsi Synopsys OHCI Host Controller
[    2.888000] nxp-ohci nxp-ohci: new USB bus registered, assigned bus number 3
[    2.892000] nxp-ohci nxp-ohci: irq 82, io mem 0xc0020000
[    2.960000] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[    2.960000] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.968000] usb usb3: Product: SLsi Synopsys OHCI Host Controller
[    2.972000] usb usb3: Manufacturer: Linux 3.4.39-FriendlyARM ohci_hcd
[    2.980000] usb usb3: SerialNumber: nxp-ohci
[    2.984000] hub 3-0:1.0: USB hub found
[    2.988000] hub 3-0:1.0: 3 ports detected
[    2.992000] Initializing USB Mass Storage driver...
[    2.996000] usbcore: registered new interface driver usb-storage
[    3.000000] USB Mass Storage support registered.
[    3.008000] usbcore: registered new interface driver usbserial
[    3.012000] usbcore: registered new interface driver usbserial_generic
[    3.020000] USB Serial support registered for generic
[    3.024000] usbserial: USB Serial Driver core
[    3.028000] usbcore: registered new interface driver ch341
[    3.032000] USB Serial support registered for ch341-uart
[    3.040000] usbcore: registered new interface driver cp210x
[    3.044000] USB Serial support registered for cp210x
[    3.048000] usbcore: registered new interface driver ftdi_sio
[    3.056000] USB Serial support registered for FTDI USB Serial Device
[    3.060000] ftdi_sio: v1.6.0:USB FTDI Serial Converters Driver
[    3.068000] usbcore: registered new interface driver option
[    3.072000] USB Serial support registered for GSM modem (1-port)
[    3.080000] usbcore: registered new interface driver pl2303
[    3.084000] USB Serial support registered for pl2303
[    3.088000] usbcore: registered new interface driver ti_usb_3410_5052
[    3.096000] USB Serial support registered for TI USB 3410 1 port adapter
[    3.104000] USB Serial support registered for TI USB 5052 2 port adapter
[    3.108000] ti_usb_3410_5052: v0.10:TI USB 3410/5052 Serial Driver
[    3.116000] android_usb gadget: Mass Storage Function, version: 2009/09/11
[    3.124000] android_usb gadget: Number of LUNs=1
[    3.128000]  lun0: LUN: removable file: (no medium)
[    3.132000] android_usb gadget: android_usb ready
[    3.136000] mousedev: PS/2 mouse device common for all mice
[    3.144000] input: Nexell Keypad as /devices/platform/nxp-keypad/input/input0
[    3.148000] usbcore: registered new interface driver xpad
[    3.156000] i2c-core: driver [IT7260-ts] using legacy suspend method
[    3.160000] i2c-core: driver [IT7260-ts] using legacy resume method
[    3.168000] <<-GTP-INFO->> GTP driver installing...
[    3.172000] himax_ts 2-0048: Unable to get DevId
[    3.176000] touchscreen-1wire   initialized
[    3.180000] backlight-1wire   initialized
[    3.184000] input: fa_ts_input as /devices/virtual/input/input1
[    3.192000] ts-if   initialized
[    3.192000] [RTC] day=2016.01.01 time=08:00:00
[    3.196000] nxp-rtc nxp-rtc.0: rtc core: registered nxp-rtc as rtc0
[    3.204000] i2c /dev entries driver
[    3.208000] ...................................ov5640_probe 2234
[    3.212000] ...................................ov5640_video_probe 2193
[    3.220000] ov5640 0-003c: reg_read: i2c read error, reg: 300a
[    3.224000] OV5640 read error!!!!!!!!!!!!!!!
[    3.228000] ov5640_initialize_ctrls.............1794...........
[    3.236000] nxp_hdmi_cec_probe success
[    3.240000] device-mapper: uevent: version 1.0.3
[    3.244000] device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com
[    3.252000] Bluetooth: HCI UART driver ver 2.2
[    3.256000] Bluetooth: HCI H4 protocol initialized
[    3.260000] DVFS: ASV[2] IDS 24mA, Ro 129 -> Table [IDS 15mA, Ro 130]
[    3.272000] DVFS: regulator vdd_arm_1.3V
[    3.272000] DVFS: cpu DVFS with PLL.1 [tables=11]
[    3.280000] cpuidle: using governor ladder
[    3.280000] cpuidle: using governor menu
[    3.284000] Synopsys Designware Multimedia Card Interface Driver
[    3.292000] dw_mmc dw_mmc.0: Using internal DMA controller.
[    3.296000] mmc0: no vmmc regulator found
[    3.300000] dw_mmc dw_mmc.0: Using external card detect irq 267 (io 161)
[    3.308000] dw_mmc dw_mmc.0: Version ID is 250a
[    3.312000] dw_mmc dw_mmc.0: DW MMC controller at irq 75, 32 bit host data width, 32 deep fifo hw timeout 500 ms
[    3.320000] dw_mmc dw_mmc.1: Using internal DMA controller.
[    3.324000] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 400000Hz, actual 396825HZ div = 63)
[    3.336000] mmc1: no vmmc regulator found
[    3.340000] dw_mmc dw_mmc.1: Version ID is 250a
[    3.344000] dw_mmc dw_mmc.1: DW MMC controller at irq 76, 32 bit host data width, 32 deep fifo hw timeout 500 ms
[    3.356000] usbcore: registered new interface driver usbhid
[    3.360000] usbhid: USB HID core driver
[    3.364000] ashmem: initialized
[    3.368000] logger: created 256K log 'log_main'
[    3.372000] logger: created 256K log 'log_events'
[    3.376000] logger: created 256K log 'log_radio'
[    3.380000] logger: created 256K log 'log_system'
[    3.388000] snd pcm: register sound platform 'nxp-pcm'
[    3.392000] snd i2s: ch 0, master, iis mode, 48000(47999)hz, 32 FBITs, MCLK=12287880hz, RFS=256
[    3.416000] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[    3.420000] mmc0: new high speed SDHC card at address aaaa
[    3.424000] mmcblk0: mmc0:aaaa SL16G 14.8 GiB
[    3.436000]  mmcblk0: p1 p2 p3 p4 < p5 p6 p7 >
[    3.452000] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 400000Hz, actual 396825HZ div = 63)
[    3.516000] asoc: ES8316 HiFi <-> nxp-i2s.0 mapping ok
[    3.516000] spdif-tx: 48000(47999)Hz, MCLK=12287880hz HDMI out
[    3.524000] asoc: dit-hifi <-> nxp-spdif-tx mapping ok
[    3.528000] GACT probability NOT on
[    3.532000] Mirror/redirect action on
[    3.532000] u32 classifier
[    3.536000]     Actions configured
[    3.540000] Netfilter messages via NETLINK v0.30.
[    3.544000] nf_conntrack version 0.5.0 (13469 buckets, 53876 max)
[    3.552000] ctnetlink v0.93: registering with nfnetlink.
[    3.556000] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[    3.564000] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[    3.568000] xt_time: kernel timezone is -0000
[    3.572000] ip_tables: (C) 2000-2006 Netfilter Core Team
[    3.580000] arp_tables: (C) 2002 David S. Miller
[    3.584000] TCP: cubic registered
[    3.588000] Initializing XFRM netlink socket
[    3.592000] NET: Registered protocol family 10
[    3.596000] Mobile IPv6
[    3.596000] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    3.604000] IPv6 over IPv4 tunneling driver
[    3.608000] NET: Registered protocol family 17
[    3.612000] NET: Registered protocol family 15
[    3.616000] Bluetooth: RFCOMM TTY layer initialized
[    3.620000] Bluetooth: RFCOMM socket layer initialized
[    3.624000] Bluetooth: RFCOMM ver 1.11
[    3.628000] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    3.636000] Bluetooth: BNEP filters: protocol multicast
[    3.640000] Bluetooth: BNEP socket layer initialized
[    3.644000] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    3.652000] Bluetooth: HIDP socket layer initialized
[    3.656000] NET: Registered protocol family 35
[    3.660000] Registering the dns_resolver key type
[    3.664000] Registering SWP/SWPB emulation handler
[    3.672000] axp22_dcdc5: incomplete constraints, leaving on
[    3.676000] axp22_dcdc4: incomplete constraints, leaving on
[    3.680000] axp22_dcdc3: incomplete constraints, leaving on
[    3.688000] axp22_dcdc2: incomplete constraints, leaving on
[    3.692000] axp22_dcdc1: incomplete constraints, leaving on
[    3.700000] axp22_dc5ldo: incomplete constraints, leaving on
[    3.704000] axp22_eldo2: incomplete constraints, leaving on
[    3.708000] axp22_eldo1: incomplete constraints, leaving on
[    3.720000] axp22_dldo1: incomplete constraints, leaving on
[    3.720000] axp22_aldo3: incomplete constraints, leaving on
[    3.728000] axp22_aldo2: incomplete constraints, leaving on
[    3.732000] axp22_aldo1: incomplete constraints, leaving on
[    3.736000] axp22_ldo1: incomplete constraints, leaving on
[    3.740000] otg_wakelock_init: No USB transceiver found
[    3.748000] nxp-rtc nxp-rtc.0: setting system clock to 2016-01-01 08:00:01 UTC (1451635201)
[    3.756000] tmu[0] = trim 44:0, ret 1
[    3.760000] TMU: register tmu.0 to hwmon (max 1400000khz)
[    3.764000] ALSA device list:
[    3.768000]   #0: I2S-ES8316
[    3.772000]   #1: SPDIF-Transciever
[    3.772000] Freeing init memory: 220K
[    3.776000] Write protecting the kernel text section c0008000 - c0842000
[    3.784000] rodata_test: attempting to write to read-only section:
[    3.792000] write to read-only section trapped, success
[    3.872000] type=1403 audit(1451635201.620:2): policy loaded auid=4294967295 ses=4294967295
[    3.876000] type=1404 audit(1451635201.624:3): enforcing=1 old_enforcing=0 auid=4294967295 ses=4294967295
[    4.084000] init: /dev/hw_random not found
[    4.176000] init: /dev/hw_random not found
[    4.196000] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    4.196000] fs_mgr: __mount(source=/dev/block/platform/dw_mmc.0/by-num/p2,target=/system,type=ext4)=0
[    4.232000] EXT4-fs (mmcblk0p3): recovery complete
[    4.232000] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
[    4.236000] HDMI HPD State 0x1
[    4.244000] fs_mgr: check_fs(): mount(/dev/block/platform/dw_mmc.0/by-num/p3,/cache,ext4)=0
[    4.260000] find cec header!_edid_find_target_cec_address: cec physical address 2000
[    4.264000] _hdmi_hpd_changed: edid update success, preset 8
[    4.320000] fs_mgr: Running /system/bin/e2fsck on /dev/block/platform/dw_mmc.0/by-num/p3
[    4.444000] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[    4.444000] e2fsck: cache: clean, 11/27392 files, 3535/109568 blocks
[    4.476000] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=panic
[    4.480000] fs_mgr: __mount(source=/dev/block/platform/dw_mmc.0/by-num/p3,target=/cache,type=ext4)=0
[    4.512000] EXT4-fs (mmcblk0p7): recovery complete
[    4.512000] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
[    4.520000] fs_mgr: check_fs(): mount(/dev/block/platform/dw_mmc.0/by-num/p7,/data,ext4)=0
[    4.576000] fs_mgr: Running /system/bin/e2fsck on /dev/block/platform/dw_mmc.0/by-num/p7
[    4.632000] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[    4.632000] e2fsck: userdata: clean, 81/158720 files, 38838/624468 blocks
[    4.660000] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=panic
[    4.664000] fs_mgr: __mount(source=/dev/block/platform/dw_mmc.0/by-num/p7,target=/data,type=ext4)=0
[    4.692000] setting PHY_BASEADDR_POWER_GATE, set 1
[    4.692000] setting PHY_BASEADDR_PMU_ISOLATE+4, set 0
[    4.696000] setting PHY_BASEADDR_PMU_ISOLATE+8, set 0
[    4.704000] setting PHY_BASEADDR_PMU_ISOLATE, set 1
[    4.708000] read PHY_BASEADDR_PMU_ISOLATE + 0xC
[    4.712000] Wait Power UP Ack(powerUpAck=0x00000000)
[    4.716000] setting ClockGen, set 1
[    4.720000] setting Reset VR addr(0xf0012008)
[    4.724000] setting PHY_BASEADDR_VR_PMU addr(0xf0072000)
[    4.732000] Vr: VR device driver loaded(ver1.2) for s5p6818
[    4.832000] binder: 123:123 transaction failed 29189, size 0-0
[    4.912000] init: cannot find '/system/bin/debuggerd64', disabling 'debuggerd64'
[    4.916000] init: cannot find '/system/bin/rild', disabling 'ril-daemon'
[    4.924000] init: cannot find '/system/bin/install-recovery.sh', disabling 'flash_recovery'
[    4.936000] android_usb: already disabled
[    4.944000] adb_open
[    4.944000] mtp_bind_config
[    4.944000] adb_bind_config
[    5.020000] logd.auditd: start
shell@nanopi3:/ $ [    5.840000] healthd: No charger supplies found
[    5.840000] healthd: No battery devices found
[    6.116000] ov5640_link_setup
[    6.116000] camera_common_vin_setup_io
[    6.116000] ov5640 0-003c: reg_write: i2c write error, reg: 3103
[    6.120000] ov5640_init: failed to ov5640_write_array init regs
[    6.128000] ov5640_s_power.............1944...........
[    6.132000] nxp_hdmi_link_setup: connected to me!!!
[   10.540000] warning: `main' uses 32-bit capabilities (legacy support in use)
