NanoPi Neo Core & Core2 released on the Webpage
Posted: Wed Dec 13, 2017 10:08 am
....but no News-entry in the Forum
Some descriptions are not-so-right....
Neo Core2 says the MiniShield would fit in a RPi3 Case....but the Audio-Port and the USB-Port are on a other place....
Neo Core2 text show also 512MB - but the featute-icons show only 1GB Ram.
Neo Core2 Feature-Icons show Octa-Core for the H5 - but H5 is only Quadcore
Pins for the Neo Core2 has only option for non-soldered - but the *Pins Text looks like there maybe a soldered option.
Also for the 1GB Ram (isnt selected at start - since there is no other option at this time - it should be selected).
I would like to see the "pins soldered" option to not ruin the board and not getting a message from the support "you did a bad soldering".
I like the Idea of the Base-mini shield and compatibility for the "normal" Neo(2) Hats
Also fine is now a full-size M2 against the half-size of the NanoPi Duo.
