NanoPI NEO Uarts Showing Garbage
Posted: Fri Mar 09, 2018 9:36 pm
I have NaoPI Neo, just opened it out of the box yesterday and was testing the uarts.
I'm hooked to pins 6 (gnd), 8 (tx) and 10 (rx), running to my PC's pin's 2/3/5 (9-pin serial port).
My serial port is setup as:
# root@NovusOne:~# stty -F /dev/ttyS1
speed 9600 baud; line = 0;
I'm running Putty on my computer, serial port is set to 9600/8/N/1.
On the Nano, I do a simple:
# cat /dev/ttyS1
Which dumps out whatever shows up at the com port. On the Putty, I dump a small text file (I'm lazy). I get garbage.
# cat /dev/ttyS1
5�Wy_�_=9)��Y5�����g5#����囋�_!
��g!9='��}!�;5�=/5�!
%;/5�m_�=9)�����7���s'=1����Wy_�_!9)��Y5�����}9)�����g5#���噋�g!9='��_!
5�Ya9)�g=
5#�9!%��#���y!##-!#��y'!5��#�廡�#��嗋���}5=�!!�%=#
It's consistent at any baud rate with any bit/parity setting. I was unable to get ttyS0 to work at all [no response]. Device Tree file has been untouched. An interesting effect is I get the same pattern of garbage if I continue to repeat the paste operation. So, that tells me it's some kind of configuration.
Anyone have any idea what is going on?! Is my nanopi broke?
# cat /dev/ttyS1
# cat /dev/ttyS1
5�Ya9)�g=
