connectors and pins to fit NanoHat Hub and motor.
Posted: Fri Apr 13, 2018 6:31 am
by quantumtarget
I need a US source for the mating connectors for these two boards. Not the board to cpu headers of course, the 4 pole connectors for peripheral connectors. If a US source is not available I will consider alternatives - reluctantly.
I need to make up wires of different lengths for the boards I have and would like to order more of the boards but If I can't have a mating connector and terminals to load for custom wire lengths in small quantities, I will have to look elsewhere for my embedded solutions. Splicing wires is not an option.
I have searched both Mouser and Digikey's offerings for a connector that will fit. None I could Identify do. Digikey pn 455-1488-ND (JST PAP-04V-S) is the closest but not nearly close enough.
This kind of information should be on WIKI. At least a reference to a manufacturer part number that will work.
Lacking this kind of information relegates these boards to the interesting but useless bin.
Q
Re: connectors and pins to fit NanoHat Hub and motor.
Posted: Wed Jun 27, 2018 2:22 pm
by quantumtarget
Bump. Very disappointing...
