NEO Plus 2 do not support cp210x usb-serial adapter
Posted: Thu Aug 02, 2018 6:14 am
by vividcheng
I'am using NEO Plus 2. The board is using Linux kernel 4.14.0.
I need to use CP210x usb-serail adapter with this board to interface some device.
However, this board does not have cp210x.ko driver install by default.
I tried to compile, but found I can not install linux-headers-4.14.0 for this board, as it is not included in the software repository.
Can you help to compile a cp210x.ko for me? Or please tell me how to install the required linux-headers-4.14.0 package?
Thanks,
Cheng
Re: NEO Plus 2 do not support cp210x usb-serial adapter
Posted: Thu Aug 02, 2018 7:20 pm
by igorp
Thanks,
Cheng
Try Armbian perhaps? This probably works out of the box. If not:
https://github.com/armbian/build
Posted: Fri Aug 31, 2018 11:57 am
by alopecosa
Have you tried to install the needed linux headers using the metapackages?
apt install linux-headers-generic
should search for the correct Veriosn of the linux-headers package.
Alternatively you could do
apt install linux-headers-$(uname -r)
which also should install the correct header files for your installed kernel.
In both cases you should do an initial apt update!
apt update
both options are working flawless on my nanoPi Neo Plus2.
best regards.
