Wiring NP - bug - GPIO 0 cannot be manipulated
Posted: Fri Aug 10, 2018 1:09 pm
by R4C3R
There is a bug in WiringNP that is included in the "nanopi-neo2_friendlycore-xenial_4.14.52_20180628.img".
This bug did not exist in the WiringNP version included with "nanopi-neo2_friendlycore-xenial_4.14.0_20180511.img"
When I transfer the old WiringNP version to the new image, there is also no problem.
The bug can be reproduced like this:
1) use e.g. etcher to create an SD card with the "nanopi-neo2_friendlycore-xenial_4.14.52_20180628.img"
2) boot the from the SD
3) logon via ssh as root, use password fa
4) run npi-config and disable uart2
5) install WiringNP by running the following commands:
cd /root/WiringNP/
chmod 755 build
./build
6) use
gpio readall
to view the current gpio status
7) change gpio 0 to an output with
gpio mode 0 out
8) set gpio 0 high with the following command
gpio write 0 1
9) use
gpio readall
there will be no change to gpio 0
root@NanoPi-NEO2:~# uname -a
Linux NanoPi-NEO2 4.14.0 #25 SMP Fri May 11 16:57:53 CST 2018 aarch64 aarch64 aarch64 GNU/Linux
root@NanoPi-NEO2:~# gpio write 0 1
root@NanoPi-NEO2:~# gpio readall
 +-----+-----+----------+------+---+-NanoPi-NEO2--+------+----------+-----+-----+
 | BCM | wPi |   Name   | Mode | V | Physical | V | Mode | Name     | wPi | BCM |
 |     |     |     3.3V |      |   |  1 || 2  |   |      | 5V       |     |     |
 |  12 |   8 |  GPIOA12 | ALT5 | 0 |  3 || 4  |   |      | 5V       |     |     |
 |  11 |   9 |  GPIOA11 | ALT5 | 0 |  5 || 6  |   |      | 0v       |     |     |
 | 203 |   7 |  GPIOG11 |  OFF | 0 |  7 || 8  | 0 | ALT5 | GPIOG6   | 15  | 198 |
 |     |     |       0v |      |   |  9 || 10 | 0 | ALT5 | GPIOG7   | 16  | 199 |
 |   0 |   0 |   GPIOA0 |  OUT | 0 | 11 || 12 | 0 | IN   | GPIOA6   | 1   | 6   |
 |   2 |   2 |   GPIOA2 |  OUT | 0 | 13 || 14 |   |      | 0v       |     |     |
 |   3 |   3 |   GPIOA3 |  OUT | 0 | 15 || 16 | 0 | OUT  | GPIOG8   | 4   | 200 |
 |     |     |     3.3v |      |   | 17 || 18 | 0 | OUT  | GPIOG9   | 5   | 201 |
 |  64 |  12 |   GPIOC0 | ALT4 | 0 | 19 || 20 |   |      | 0v       |     |     |
 |  65 |  13 |   GPIOC1 | ALT4 | 0 | 21 || 22 | 0 | OUT  | GPIOA1   | 6   | 1   |
 |  66 |  14 |   GPIOC2 | ALT4 | 0 | 23 || 24 | 1 | OUT  | GPIOC3   | 10  | 67  |
 +-----+----NanoPi-NEO2 USB/Audio-+----+
 | BCM | wPi |   Name   | Mode | V | Ph |
 |     |     |       5V |      |   | 25 |
 |     |     |  USB-DP1 |      |   | 26 |
 |     |     |  USB-DM1 |      |   | 27 |
 |     |     |  USB-DP2 |      |   | 28 |
 |     |     |  USB-DM2 |      |   | 29 |
 |     |     |    IR-RX |      |   | 30 |
 |  17 |  19 |  GPIOA17 |  OFF | 0 | 31 |
 |     |     |  PCM/I2C |      |   | 32 |
 |     |     |  PCM/I2C |      |   | 33 |
 |     |     |  PCM/I2C |      |   | 34 |
 |     |     |  PCM/I2C |      |   | 35 |
 |     |     |       0V |      |   | 36 |
 +-----+----NanoPi-NEO2 Debug UART-+----+
 |   4 |  17 |   GPIOA4 | ALT5 | 0 | 37 |
 |   5 |  18 |   GPIOA5 | ALT5 | 0 | 38 |
if you repeat the commands for e.g. gpio 2 it works perfectly well. Also in the old version it worked for gpio 0.
