NanoPi NEO and zRAM
Posted: Wed Feb 20, 2019 3:29 am
I have more then 100 pcs nanoPi NEO already installed and solder inside measuring units, with several sensor connected to each one. Because most of them has only 256 MB RAM, I must to increase amount of memory. I use Linux distro from Friendly Elec. It is not possible to solder something in already existing units or use USB Flash Drive because life-time of such memory. I moved all temporary files to RAM-disk (including measurements) so SD card is practically read-only (except sys upgrade). The only solution for me is zRAM. Does anybody has experiences with such solution on nanoPi with Linux taken from Friendly Elec repo? Is it worth to install it? What about performance? (less important for me). What version of zRAM I have to install? (any link if You be so kind).
Below current (the latest available) version of Linux I use (with all updates available this day):
Linux NanoPi-NEO 4.14.0 #1 SMP Mon Dec 18 11:43:22 CST 2017 armv7l armv7l armv7l GNU/Linux
