Hi. I would like to ask you how to add and read temperature and humidity from sensor DHT11 on Nano Pi Neo Core 2 with armbian.
I want to use PA13 pin (CS form SPI1) I try to enable overlay:
When I try add dht11 to overlay in /boot/armbianEnv.txt this module after reboot is still disable. Any suggestions?
sudo modprobe dht11
cat /sys/bus/iio/devices/iio:device0/in_temp_sclae
return : -119
