Greetings.
I've recently received an NAS board. Installed the rom, it boots etc, but when I attach an HDD it could not power it up. (it looks like)
It's a 1Tb 2.5" HDD - Seagate ST1000LM010. Label says it requires 0.75A/5V (HDD does work properly when connected to usb or sata)
I'm using 2.5A/12V power brick.
It does work when connected via usb/sata adapter to the same Neo2 board. But only when Neo2 has power from the OTG USB and not 12V.
I've searched and found no info in power limitations of the board. I've tried to contact tech support but got no answer. So I decided to post here. Any advice?
Thank You.
