Pins 6 and 7
Posted: Sun Aug 21, 2016 5:36 pm
by tadvi
What Linux GPIO numbers do single row Pins 6 and 7 correspond to?
6 GPIOL11/IR-RX - Linux GPIO # ?
7 SPDIF-OUT/GPIOA17 - Linux GPIO # ?
Re: Pins 6 and 7
Posted: Tue Aug 23, 2016 8:47 am
by jjm
Accessing the GPIO pins through sysfs with mainline kernel The GPIO pins can be accessed from user space using sysfs. To enabled this you need the following kernel option enabled: CONFIG_GPIO_SYSFS
Device Drivers ---> GPIO Support ---> /sys/class/gpio/... (sysfs interface)
To access a GPIO pin you first need to export it with
echo XX > /sys/class/gpio/export
with XX being the number of the desired pin. To obtain the correct number you have to calculate it from the pin name (like PH18)[1]:
(position of letter in alphabet - 1) * 32 + pin number
E.g for PH18 this would be ( 8 - 1) * 32 + 18 = 224 + 18 = 242 (since 'h' is the 8th letter).
After you have successfully exported the pin you can access it through /sys/class/gpio/gpio*NUMBER* (in case of PH18 it's /sys/class/gpio/gpio242).
With /sys/class/gpio/gpio*NUMBER*/direction you can set the pin to out or in using
echo "out" > /sys/class/gpio/gpio*NUMBER*/direction
and you can read/write the value with /sys/class/gpio/gpio*NUMBER*/value.
When you are done unexport the pin with
echo XX > /sys/class/gpio/unexport
Re: Pins 6 and 7
Posted: Tue Aug 23, 2016 10:52 am
by HermannSW
Good question, the Neo Wiki does only provide Linux GPIO numbers for the double row connections:
http://wiki.friendlyarm.com/wiki/index.php/NanoPi_NEO#Layout
Re: Pins 6 and 7
Posted: Tue Aug 23, 2016 12:54 pm
by tadvi
Thank you "jjm" for very detailed answer.
Based on it pin 7 GPIOA17 should be Linux PIN 17. Unfortunately this does not work. I have just tried it by connecting relay to it. Other GPIO pins work (pins on two rows) and switch the relay ON/OFF but not PIN 17.
Based on calculation pin 6 GPIOL11 should be Linux PIN 363 which is calculated as (11*32)+11. Please confirm.
