Dropbox on Neo2?
Posted: Fri Sep 06, 2019 5:15 am
by IliaB
Hi Guys,
Someone tried to run dropbox on Neo2 successfully, will appreciate any info on this.
Thanks in advance!
Ilia.
Re: Dropbox on Neo2?
Posted: Fri Sep 06, 2019 5:17 am
by igorp
IliaB wrote:
Hi Guys,
Someone tried to run dropbox on Neo2 successfully, will apretiate any info on this.
Thanks in advance!
Ilia.
Perhaps this way
https://help.dropbox.com/installs-integ ... ands#build ?
Posted: Sun Sep 08, 2019 8:16 am
by IliaB
Thanks Igor,
Tried this and many other stuff, nothing helps.
I guess it's impossible.
Best Regards.
Ilia.
Posted: Sun Sep 08, 2019 9:10 am
by igorp
IliaB wrote:
Thanks Igor,
Best Regards.
Ilia.
I saw they don't provide packages for ARM but building from sources? That should work ... if your build environment is not crippled and with assumption that their sources are alright. Sometimes adjustments or different compiler is needed, adjusting minor things ... well, you have to ask them/authors/dropbox for assistance. FriendlyARM has nothing to do with this.
Posted: Sun Sep 08, 2019 9:40 am
by IliaB
Hi Igor,
That's what I did eventually, trying to compile from source, too much errors..
Tried
rclone https://rclone.org/ app and it works fine, I probably stick with
rclone for a while.
Thanks again.
Ilia.
Posted: Sun Sep 08, 2019 9:50 am
by igorp
IliaB wrote:Hi Igor,
Tried
rclone for a while.
Thanks again.
Ilia.
I see ... Rclone looks like a much better option.
