Compatibility of NanoPi NEO2 black and 1-bay NAS Kit v1.2
Posted: Thu Jan 16, 2020 11:17 am
by antonL
The question is rather simple:
Does 1-bay NAS kit (the PCB to be more precise) work with the NanoPI NEO2 Black SBC?
The PCB is listed among the accessories for NanoPI NEO2 Black for ordering but there are some clear differences between NO/NEO2 and the Black version: the number of GPIO pins is different and their role is also different. Both the data pins (USB2.0) and %VDC in/out are on different positions.
IMO the Black version of NEO2 and the PCB for NAS are incompatible with each other. Is this so? If yes, then the option for a NAS board should be removed from the page for NanoPi NEO2 black and the compatibility should be clarified somewhere and somehow.
Re: Compatibility of NanoPi NEO2 black and 1-bay NAS Kit v1.2
Posted: Tue Apr 07, 2020 12:57 am
by spikerguy
I would like to know the same before I place the order.
Is neo2 black compatible with. 1-kit Nas dock?
Also anyone officially maintaining the support? Also I dont like omv anymore as I've been using it since few years but might move to nextcloud with smb/cif/nfs.
I would appreciate a quick reply from the friendly arm team.
Thanks.
F. K.
Manjaro ARM Team.
Posted: Tue Apr 07, 2020 2:02 am
by spikerguy
Looks like my post is still under review, so posting another one.
After reading alot I see that neo2 black face different gpio pins so it won't be compatible with 1bay nas dock kit.
While neo2-1gb is out of stock all over online stores. If there is any way I can buy 1gb model then please advice.
Also I would need the uboot and kernel source for it so I can port it to Manjaro or Arch linux and maintain it as I see the debian OMV is outdated. While I would prefer nextcloud over omv.
I can build new distro for it if it is upstreamed to mainline kernel as I read uboot was mainlined few years ago.
Looking forward for positive response from friendly devs.
F. k.
Manjaro ARM Team.
Posted: Tue Apr 07, 2020 9:59 am
by igorp
Armbian (Debian) is fully up 2 date with
OMV 5 or Nextcloud with tons of improvements on top of mainline (K5.4.y, K5.6.y) sources ...
P.S.
I think Neo2 black is not compatible.
Not everything was mainlined and something will never be ...
Posted: Tue Apr 07, 2020 11:43 am
by spikerguy
Hi Igor,
I see you here
Well every SBC manufacturer is depending on Armbian devs. As I use Balbes kernels for most of the devices I maintain at Manjaro ARM Community
I see Armbian is maintaining support for Neo2 which is good to see as there is mainline 5.4 support
https://www.armbian.com/nanopi-neo-2/I think I would be able to add Neo2 support to Nextcloudpi but I cannot find 1gb version of neo2 while I think 512mb is quite low for the nextcoud use.
I don't know, Maybe I will look for 1gb version on this forum if there is anyone looking to sell his/her's.
Can someone from FriendlyArm team confirm if they will produce 1GB version of Neo2?
Thanks.
Posted: Tue Apr 07, 2020 9:47 pm
by spikerguy
Hello @admin and @FATechsupport,
I tried to purchase from your official store but it doesn't seem to get shipping cost to my country. I have dropped an email to contact us. If it cannot be send to my country then maybe I should purchase it from Aliexpress?
Also is there any plan for Neo2-1GB version?
Thanks.
Posted: Wed Apr 08, 2020 8:44 am
by spikerguy
Update.
After doing some more research. I found that some supplier are selling 1bay nas kit dock with the claim that neo plus2 is supported.
I am not sure of this compatibility claim. If anyone can confirm if I can use neo plus2 with nas kit then it will be very helpful.
Thanks.
Update:
I compared Neo/Neo2/Neo Plus2 and found all have the same GPIO pin and connectors only thing is Neo Plus2 is a big longer which will make it stay outside the case which is not a problem.
is the comparison image.
Comparison Image
Posted: Sat May 09, 2020 3:04 pm
by spikerguy
I cannot find any specification of JSM567 as mentioned on the datasheet of the NAS Kit.
I can only find JMS576 so I assume it is a typo on all the datasheet provided by FriendlyArm ?
Can anyone confirm?
Posted: Fri Jun 19, 2020 7:43 pm
by spikerguy
For everyone who have the same questions like me which I asked above then the answers for them is
Black edition is not pin compatible so only option is Neo or Neo Plus2 but Neo Plus2 will not completely fit inside the case. it will come outside the case, So I will cut the metal plate accordingly to fix the plate in place while the RJ45 and USB ports are outside the case.
I think this is one of the best DIY Nas case. I also tried with 3.5" HDD it works but there is some clicking which indicated that the power is not sufficient, I will try with 12V 4amp adapter to see if that makes any difference which I doubt it will as the dock itself have voltage limitation.
2.5inch hdd can survive on 5v while 3.5inch needs full 12v with 1.1amp atleast.
Posted: Sat Jun 20, 2020 12:41 pm
by guidol
Can anyone confirm?
root@npi-neo2:~# lsusb
Bus 004 Device 002: ID 152d:0578
JMicron Technology Corp. / JMicron USA Technology Corp.
JMS567 SATA 6Gb/s bridge
Posted: Sun Jun 21, 2020 6:34 pm
by spikerguy
Thank you for the reply.
I have just received my device and I have been playing around with it.
Posted: Tue Feb 02, 2021 1:11 pm
by spikerguy
Does anyone else have slow speed on NasKit with NanoPi Neo Plus2?
sudo hdparm -t --direct /dev/sda
/dev/sda:
Timing O_DIRECT disk reads: 50 MB in 3.03 seconds = 16.50 MB/sec
[spikerguy@NAS ~]$ sudo hdparm -t --direct /dev/sda
/dev/sda:
Timing O_DIRECT disk reads: 112 MB in 3.03 seconds = 36.97 MB/sec
[spikerguy@NAS ~]$
I am using Western Digital HDD and I think it should be around 200 MB/sec
I have already updated the firmware on JMS578 as I have this version.
Bus 003 Device 002: ID 152d:0578 JMicron Technology Corp. / JMicron USA Technology Corp. JMS578 SATA 6Gb/s
Please suggest.
