SOLVED: ZeroPi not boot friendlywrt
Posted: Tue Mar 10, 2020 3:41 pm
Does not start with two Zero pi.
boot if it is friendlycore(20191230).
File:
zeropi_sd_friendlywrt_4.14_armhf_20191230.img
md5: 30a71b5cb49d8702c928008510543a5f
SD: SanDisk Industrial 8GB
SD: SanDisk Industrial 16GB
UPDATE:
File:
zeropi_sd_friendlycore-xenial_4.14_armhf_20191219.img
md5: 669c0676cb22d43de9b6f38c69059e5e
friendlycore
/BOOT/sun8i-h3-zeropi.dtb
friendlywrt
sun8i-h3-zeropi.dtb file copy
friendlywrt booted
File:
U-Boot SPL 2017.11-05001-gffaf107328 (Dec 13 2019 - 17:05:46)
DRAM: 512 MiB(408MHz)
CPU Freq: 408MHz
memory test: 1
Pattern 55aa Writing...Reading...OK
Trying to boot from MMC1
Boot device: sd
U-Boot 2017.11-05001-gffaf107328 (Dec 13 2019 - 17:05:46 +0800) Allwinner Technology
CPU: Allwinner H3 (SUN8I 1680)
Model: FriendlyElec NanoPi H3
DRAM: 512 MiB
CPU Freq: 1008MHz
MMC: SUNXI SD/MMC: 0, SUNXI SD/MMC: 1
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: No ethernet found.
BOARD: zeropi
starting USB...
No controllers found
Hit any key to stop autoboot: 2 1 0
reading boot.scr
1478 bytes read in 19 ms (75.2 KiB/s)
## Executing script at 43100000
running boot.scr
reading uEnv.txt
968 bytes read in 20 ms (46.9 KiB/s)
reading zImage
5901600 bytes read in 296 ms (19 MiB/s)
reading rootfs.cpio.gz
5880768 bytes read in 291 ms (19.3 MiB/s)
** Unable to read file sun8i-h3-zeropi.dtb **
libfdt fdt_check_header(): FDT_ERR_BADMAGIC
No FDT memory address configured. Please configure
the FDT address via "fdt addr <address>" command.
Aborting!
Unknown command 'overlay' - try 'help'
reading overlays/sun8i-h3-fixup.scr
4109 bytes read in 34 ms (117.2 KiB/s)
## Executing script at 44500000
Aborting!
ERROR: Did not find a cmdline Flattened Device Tree
Could not find a valid device tree
UPDATE:
File:
friendlycore
friendlywrt
friendlywrt booted
