guidol wrote:gtj wrote:
What kind of support forum is his?
3 times I needed some help and posted a thread.Never got a response. I'm out
Hmm - FriendlyARM does not much support on their forum
Most of the time a normal user does help the other user - but because this is no payed support you will only get help if another user could help you
Did you compare the pins against the RPi and try to use/convert the script by yourself?
Thank you very much for getting back. The only time I got a response in here, as you rightly say, it was by a fellow member (Igor).
I have 2 NanoPi NeoPlus2 and a NanoPC T4 and in all honesty I deeply regret buying them due to this unprecedented for this type of product lack of support! Needless to say it's the last time I buy anything from this brand. As far as I'm concerned even other fellow chinese makers like Orange Pi are a lot more active in the communities. On top of that, I have sent them a tech support question over a week ago and I haven't got any response!
I mean this is a very basic question: I asked if the Audio HAT (which is for NeoPus) is going to fit my NeoPlus2. They haven't bothered to answer!
This one, I asked something very common and easy for the manufacturer.
I want to add this software switch with this script to my NanoPi NeoPlus2
https://howchoo.com/g/mwnlytk3zmm/how-t ... spberry-piThat's essentially bridging pins 5 & 6 which apparently are the same with RPi.
I don't know how to modify the script but the pins seem identical between the 2 boards.
Although my questions were addressed to the maker of the board and they were easy to answer, I have never got an official reply. Funnily in the 2nd case I wanted to buy something, a HAT.
They just don't bother.
