I am trying to setup a wireless hotspot/access point on the NanoPi R1S-H3 by following the post here https://raspberrypi.stackexchange.com/q ... 9804#89804
I am able to get hostapd to start and I can see the SSID (from the NanoPi) on my phone but can't connect to it.
When trying to connect to I get an error saying "WPA: received EAPOL-Key msg 2/4 in invalid state (10) - dropped"
Another thing I noticed is that the command:
sudo iw list | grep -A4 "valid interface combinations:"
Doesn't return anything.
Is the wireless interface on the NanoPi R1S-H3 not capable of interface combinations (e.g. to act as both a client and access point)?
Or could this be a drivers issue?
Note: I am running FriendlyCore/Ubuntu (nanopi-r1s-h3_sd_friendlycore-focal_4.14_armhf_20210618), because it has better CUPs and Gutenprint support. I have not been able to setup printing in FriendlyWRT (OpenWRT), so it is preferred to setup the wireless hotspot in Ubuntu.
