Got Mini Shield put a SSD on it but it don't see it.
Posted: Mon Feb 14, 2022 4:59 am
Hi I got the Mini Shield for NanoPi NEO Core2.
I got a 32GB SD boot and then I put a 256GB SSD.
Got it at Amazon here.
But it don't see it.
How can I see it?
Ubuntu 16.04.7 LTS NanoPi-NEO ttyS0
NanoPi-NEO login: pi (automatic login)
Last login: Fri Apr 2 02:52:08 UTC 2021 on tty1
_____ _ _ _ _____ _ _____ ____
| ___| __(_) ___ _ __ __| | |_ _| ____| | | ____/ ___|
| |_ | '__| |/ _ \ '_ \ / _` | | | | | _| | | | _|| |
| _|| | | | __/ | | | (_| | | |_| | |___| |___| |__| |___
|_| |_| |_|\___|_| |_|\__,_|_|\__, |_____|_____|_____\____|
|___/
Welcome to Ubuntu 16.04.7 LTS 4.14.111
System load: 0.44 Up time: 17 sec
Memory usage: 32 % of 491Mb IP: 192.168.86.110
CPU temp: 36°C
Usage of /: 7% of 28G
* Documentation: http://wiki.friendlyarm.com/Ubuntu
* Forum: http://www.friendlyarm.com/Forum/
pi@NanoPi-NEO:~$ sudo su root
root@NanoPi-NEO:/home/pi# fdisk -l
Disk /dev/mmcblk0: 29.1 GiB, 31266439168 bytes, 61067264 sectors
Disklabel type: dos
Disk identifier: 0xd221d321
/dev/mmcblk0p1 49152 131071 81920 40M b W95 FAT32
/dev/mmcblk0p2 131072 2516991 2385920 1.1G 83 Linux
/dev/mmcblk0p3 2516992 61067263 58550272 27.9G 83 Linux
Disk /dev/mmcblk1: 7.3 GiB, 7818182656 bytes, 15269888 sectors
Disklabel type: dos
Disk identifier: 0xb8957c57
/dev/mmcblk1p1 49152 131071 81920 40M 83 Linux
/dev/mmcblk1p2 131072 2533375 2402304 1.1G 83 Linux
/dev/mmcblk1p3 2533376 15269887 12736512 6.1G 83 Linux
Disk /dev/mmcblk1boot1: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/mmcblk1boot0: 4 MiB, 4194304 bytes, 8192 sectors
(parted) p
Error: /dev/mmcblk1boot0: unrecognised disk label
Model: Generic SD/MMC Storage Card (sd/mmc)
Disk /dev/mmcblk1boot0: 4194kB
Sector size (logical/physical): 512B/512B
Partition Table: unknown
Disk Flags:
(parted)
So I don't think it sees it right?
Should it see it?
-Raymond Day
How can I see it?
|___/
CPU temp: 36°C
Disklabel type: dos
Disklabel type: dos
(parted) p
Disk Flags:
(parted)
Should it see it?
-Raymond Day
