wifi antenna connector
Posted: Thu Apr 27, 2017 10:22 pm
by seth
I am building some special wifi antennas for nanoPi Neo AIR. Can you confirm that the correct specification for a the connector on board is IPEX MHF Receptacle?
Re: wifi antenna connector
Posted: Fri Apr 28, 2017 6:22 am
by Maroon5
standard interface 2.4
Posted: Fri Apr 28, 2017 6:12 pm
by seth
Sorry for my confusion. I am trying to specify a mating connector to the surface mount wifi antenna connector on the nanoPi Neo AIR. I cannot find anything called 'standard interface 2.4' to spec to.
I can find IPEX IPX (and Hirose refs) connector references. As far as I can tell by measuring, the receptacle on the board is specifically an IPEX MHF Receptacle. I am just trying to confirm that it is definitely MHF size - so that I can spec for taoglas an MHF plug.
Is this correct?
