I have a Neo Air with the new AP6212A wifi chip and I can't get hostapd to broad cast itself. The only error I have while launching hostapd (hostap Failed to set TX queue parameters for queue 0) but then it says the it was succesful in setting up the accesspoint. Does anyone know what the problem could be? Using FriendlyArm distribution.
TL;DR: Neo Air with an AP6212A wifi module won't broadcast SSID, or at least no device can detect it, and the only error is (hostap Failed to set TX queue parameters for queue 0) but even then it says wlan0 was successfully set as an accesspoint.
