Distro: nanopi-neo-plus2_eflasher_4.11.2_20170630
Usb wifi
[  165.026697] kernel BUG at net/core/dev.c:2591!
[  165.031213] Internal error: Oops - BUG: 0 [#1] SMP
[  165.036033] Modules linked in: rt2800usb rt2800lib rt2x00usb rt2x00lib hci_uart btbcm btqca btintel bluetooth bridge stp llc ir_lie
[  165.056752] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.11.2 #267
[  165.062870] Hardware name: FriendlyElec NanoPi-NEO-Plus2 (DT)
[  165.068650] task: ffff000008bd0c00 task.stack: ffff000008bc0000
[  165.074646] PC is at skb_checksum_help+0x188/0x198
[  165.079481] LR is at validate_xmit_skb+0x1d4/0x2b0
[  165.084306] pc : [<ffff0000086e03f8>] lr : [<ffff0000086e658c>] pstate: 00000145
[  165.091722] sp : ffff80003ef7a960
[  165.095066] x29: ffff80003ef7a960 x28: ffff800009e40500
[  165.100431] x27: ffff80003c879000 x26: 0000000000000000
[  165.105792] x25: ffff80003c19949c x24: ffff800009ef6c00
[  165.111157] x23: ffff80003c80e000 x22: 0000000000006000
[  165.116519] x21: ffff80003c80e000 x20: 00000000ffffff7e
[  165.121881] x19: ffff80003c0a5100 x18: ffff000008c5b980
[  165.127244] x17: 0000000000001800 x16: 0000000000000040
[  165.132606] x15: 0000000000000000 x14: 0000000000000008
[  165.137965] x13: 0000000000000000 x12: 003d090000000000
[  165.143325] x11: 0000000000000040 x10: 0000000000000000
[  165.148687] x9 : ffff0000080932b8 x8 : 000000000000003b
[  165.154049] x7 : ffff80003c1a3a00 x6 : 0000000000000010
[  165.159407] x5 : 0000000000000001 x4 : ffff80003c19949c
[  165.164767] x3 : ffff80003c1a3a00 x2 : 000000000000003c
[  165.170127] x1 : 000000000000003c x0 : 0000000000000082
[  165.175480]
[  165.177010] Process swapper/0 (pid: 0, stack limit = 0xffff000008bc0000)
[  165.183741] Stack: (0xffff80003ef7a960 to 0xffff000008bc4000)
[  165.189510] Call trace:
[  165.192000] Exception stack(0xffff80003ef7a790 to 0xffff80003ef7a8c0)
[  165.198482] a780:                                   ffff80003c0a5100 0001000000000000
[  165.206355] a7a0: ffff80003ef7a960 ffff0000086e03f8 ffff0000086ce5c0 ffff000008c40c00
[  165.214227] a7c0: 000000000000d683 0000000000000083 0000000000000000 00000000ff1e000a
[  165.222099] a7e0: ffff000008bcee60 00000000501e000a 0000000000000000 ffff80003c80e880
[  165.229972] a800: ffff800009db9e00 0000000000000000 ffff80003ef7a920 ffff000008851268
[  165.237843] a820: ffff80003ef7a840 000000018010000f 0000000000000082 000000000000003c
[  165.245716] a840: 000000000000003c ffff80003c1a3a00 ffff80003c19949c 0000000000000001
[  165.253587] a860: 0000000000000010 ffff80003c1a3a00 000000000000003b ffff0000080932b8
[  165.261458] a880: 0000000000000000 0000000000000040 003d090000000000 0000000000000000
[  165.269328] a8a0: 0000000000000008 0000000000000000 0000000000000040 0000000000001800
[  165.277213] [<ffff0000086e03f8>] skb_checksum_help+0x188/0x198
[  165.283091] [<ffff0000086e658c>] validate_xmit_skb+0x1d4/0x2b0
[  165.288970] [<ffff0000086e6694>] validate_xmit_skb_list+0x2c/0x68
[  165.295123] [<ffff00000870c030>] sch_direct_xmit+0xa0/0x1b0
[  165.300740] [<ffff0000086e6b00>] __dev_queue_xmit+0x1f0/0x558
[  165.306530] [<ffff0000086e6e78>] dev_queue_xmit+0x10/0x18
[  165.312240] [<ffff000000981a6c>] br_dev_queue_push_xmit+0xa4/0x160 [bridge]
[  165.319484] [<ffff000000981b58>] br_forward_finish+0x30/0x298 [bridge]
[  165.326292] [<ffff000000981ca0>] br_forward_finish+0x178/0x298 [bridge]
[  165.333185] [<ffff000000981d90>] br_forward_finish+0x268/0x298 [bridge]
[  165.340078] [<ffff000000981fe0>] br_flood+0x120/0x198 [bridge]
[  165.346190] [<ffff00000098345c>] br_handle_frame_finish+0x114/0x4a8 [bridge]
[  165.353515] [<ffff000000983980>] br_handle_frame+0x190/0x988 [bridge]
[  165.360012] [<ffff0000086e08a0>] __netif_receive_skb_core+0x260/0x870
[  165.366494] [<ffff0000086e3318>] __netif_receive_skb+0x18/0x60
[  165.372372] [<ffff0000086e3380>] netif_receive_skb_internal+0x20/0x90
[  165.378854] [<ffff0000086e3bd8>] napi_gro_receive+0xa8/0x138
[  165.384571] [<ffff000008597680>] sun8i_emac_poll+0x5f0/0x688
[  165.390274] [<ffff0000086e4a24>] net_rx_action+0x2ac/0x368
[  165.395815] [<ffff0000080ad86c>] __do_softirq+0x10c/0x228
[  165.401259] [<ffff0000080adc88>] irq_exit+0xc8/0x118
[  165.406275] [<ffff0000080f14c8>] __handle_domain_irq+0x60/0xb8
[  165.412153] [<ffff000008080d24>] gic_handle_irq+0x54/0xa8
[  165.417586] Exception stack(0xffff000008bc3de0 to 0xffff000008bc3f10)
[  165.424068] 3de0: 0000000000000000 0000000000000000 0000000000000001 0000000000000000
[  165.431941] 3e00: 00000000000001c0 0100000000000000 ffff80003c7a2a99 ffff80003c7a2a98
[  165.439812] 3e20: 0000000000000002 ffff000008bc3e70 0000000000000860 0000000000044e67
[  165.447681] 3e40: 0000000000000001 0000000000000005 0000000000000003 0000000000000000
[  165.455553] 3e60: 0000000000000040 0000000000001800 ffff000008c5b980 ffff000008b96000
[  165.463426] 3e80: ffff000008bc8d38 ffff000008bc8000 ffff000008ba1748 0000000000000000
[  165.471297] 3ea0: 0000000000000000 ffff000008bd0c00 000000007ff51220 0000000000000400
[  165.479171] 3ec0: 0000000046b50018 ffff000008bc3f10 ffff00000808469c ffff000008bc3f10
[  165.487045] 3ee0: ffff0000080846a0 0000000000000145 000000007bf49560 000000007ff51220
[  165.494909] 3f00: ffffffffffffffff 7fffffffffffffff
[  165.499831] [<ffff000008081ff4>] el1_irq+0xb4/0x140
[  165.504761] [<ffff0000080846a0>] arch_cpu_idle+0x10/0x18
[  165.510120] [<ffff0000080e520c>] do_idle+0x10c/0x1f0
[  165.515131] [<ffff0000080e54c4>] cpu_startup_entry+0x24/0x28
[  165.520854] [<ffff000008878b48>] rest_init+0x68/0x70
[  165.525869] [<ffff000008b50b18>] start_kernel+0x350/0x364
[  165.531325] [<ffff000008b501e0>] __primary_switched+0x64/0x6c
[  165.537124] Code: 97ffff68 128002a0 17ffffe7 d503201f (d4210000)
[  165.543559] ---[ end trace e587860acec600a8 ]---
[  165.548264] Kernel panic - not syncing: Fatal exception in interrupt
[  165.554658] SMP: stopping secondary CPUs
[  165.558631] Kernel Offset: disabled
[  165.562143] Memory Limit: none
[  165.565245] Rebooting in 10 seconds..
Internal wifi
pi@Sirius-NEO:~$ sudo systemctl start hostapd
pi@Sirius-NEO:~$ [   30.899563] kernel BUG at net/core/dev.c:2591!
[   30.904008] Internal error: Oops - BUG: 0 [#1] SMP
[   30.908789] Modules linked in: hci_uart btbcm btqca btintel bluetooth bridge stp llc ir_lirc_codec lirc_dev sunxi_cir rc_core brcme
[   30.925736] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.11.2 #267
[   30.931816] Hardware name: FriendlyElec NanoPi-NEO-Plus2 (DT)
[   30.937550] task: ffff000008bd0c00 task.stack: ffff000008bc0000
[   30.943469] PC is at skb_checksum_help+0x188/0x198
[   30.948251] LR is at validate_xmit_skb+0x1d4/0x2b0
[   30.953031] pc : [<ffff0000086e03f8>] lr : [<ffff0000086e658c>] pstate: 00000145
[   30.960411] sp : ffff80003ef7a960
[   30.963717] x29: ffff80003ef7a960 x28: ffff800009ccd500
[   30.969020] x27: ffff800009dbb000 x26: 0000000000000000
[   30.974322] x25: ffff80003c15909c x24: ffff800009fdea00
[   30.979624] x23: ffff800009db6000 x22: 0000000000006000
[   30.984927] x21: ffff800009db6000 x20: 00000000ffffff7e
[   30.990229] x19: ffff800009e08e00 x18: 0000000000000020
[   30.995531] x17: 0000000000000000 x16: 0000000000002000
[   31.000833] x15: 0000000000000000 x14: 0000000000000008
[   31.006135] x13: 0000000000000000 x12: 003d090000000000
[   31.011437] x11: 0000000000000040 x10: 0000000000000000
[   31.016739] x9 : 0000000000000000 x8 : 000000000000003b
[   31.022041] x7 : ffff80003ca79200 x6 : 0000000000000010
[   31.027343] x5 : 0000000000000001 x4 : ffff80003c15909c
[   31.032645] x3 : ffff80003ca79200 x2 : 000000000000003c
[   31.037947] x1 : 000000000000003c x0 : 0000000000000082
[   31.043250]
[   31.044738] Process swapper/0 (pid: 0, stack limit = 0xffff000008bc0000)
[   31.051426] Stack: (0xffff80003ef7a960 to 0xffff000008bc4000)
[   31.057160] Call trace:
[   31.059602] Exception stack(0xffff80003ef7a790 to 0xffff80003ef7a8c0)
[   31.066030] a780:                                   ffff800009e08e00 0001000000000000
[   31.073846] a7a0: ffff80003ef7a960 ffff0000086e03f8 0000000000000021 ffff800009fdfa00
[   31.081661] a7c0: ffff000008c595c0 0000000000000004 0000000000000000 ffff800009c9a200
[   31.089477] a7e0: ffff000008bcee60 00000000501e000a ffff80003ef7a800 ffff0000080beb5c
[   31.097293] a800: ffff80003ef7a810 ffff0000080beef4 ffff80003ef7a880 ffff0000080bf188
[   31.105108] a820: ffff80003ef7a840 ffff0000087657d4 0000000000000082 000000000000003c
[   31.112924] a840: 000000000000003c ffff80003ca79200 ffff80003c15909c 0000000000000001
[   31.120739] a860: 0000000000000010 ffff80003ca79200 000000000000003b 0000000000000000
[   31.128554] a880: 0000000000000000 0000000000000040 003d090000000000 0000000000000000
[   31.136370] a8a0: 0000000000000008 0000000000000000 0000000000002000 0000000000000000
[   31.144187] [<ffff0000086e03f8>] skb_checksum_help+0x188/0x198
[   31.150009] [<ffff0000086e658c>] validate_xmit_skb+0x1d4/0x2b0
[   31.155832] [<ffff0000086e6694>] validate_xmit_skb_list+0x2c/0x68
[   31.161917] [<ffff00000870c030>] sch_direct_xmit+0xa0/0x1b0
[   31.167479] [<ffff0000086e6b00>] __dev_queue_xmit+0x1f0/0x558
[   31.173215] [<ffff0000086e6e78>] dev_queue_xmit+0x10/0x18
[   31.178636] [<ffff000000981a6c>] br_dev_queue_push_xmit+0xa4/0x160 [bridge]
[   31.185607] [<ffff000000981b58>] br_forward_finish+0x30/0x298 [bridge]
[   31.192145] [<ffff000000981ca0>] br_forward_finish+0x178/0x298 [bridge]
[   31.198769] [<ffff000000981d90>] br_forward_finish+0x268/0x298 [bridge]
[   31.205393] [<ffff000000981fe0>] br_flood+0x120/0x198 [bridge]
[   31.211238] [<ffff00000098345c>] br_handle_frame_finish+0x114/0x4a8 [bridge]
[   31.218296] [<ffff000000983980>] br_handle_frame+0x190/0x988 [bridge]
[   31.224725] [<ffff0000086e08a0>] __netif_receive_skb_core+0x260/0x870
[   31.231154] [<ffff0000086e3318>] __netif_receive_skb+0x18/0x60
[   31.236976] [<ffff0000086e3380>] netif_receive_skb_internal+0x20/0x90
[   31.243404] [<ffff0000086e3bd8>] napi_gro_receive+0xa8/0x138
[   31.249056] [<ffff000008597680>] sun8i_emac_poll+0x5f0/0x688
[   31.254703] [<ffff0000086e4a24>] net_rx_action+0x2ac/0x368
[   31.260182] [<ffff0000080ad86c>] __do_softirq+0x10c/0x228
[   31.265570] [<ffff0000080adc88>] irq_exit+0xc8/0x118
[   31.270527] [<ffff0000080f14c8>] __handle_domain_irq+0x60/0xb8
[   31.276350] [<ffff000008080d24>] gic_handle_irq+0x54/0xa8
[   31.281737] Exception stack(0xffff000008bc3de0 to 0xffff000008bc3f10)
[   31.288165] 3de0: 0000000000000000 0000000000000000 0000000000000001 0000000000000000
[   31.295981] 3e00: 00000000000001c0 0100000000000000 ffff000008c5bab1 ffff000008c5bab0
[   31.303796] 3e20: 0000000000000002 ffff000008bc3e70 0000000000000860 ffff0000088998c0
[   31.311611] 3e40: 0000000000000000 0000000000000052 0000000000000000 0000000000000000
[   31.319427] 3e60: 0000000000002000 0000000000000000 0000000000000020 ffff000008b96000
[   31.327242] 3e80: ffff000008bc8d38 ffff000008bc8000 ffff000008ba1748 0000000000000000
[   31.335058] 3ea0: 0000000000000000 ffff000008bd0c00 000000007ff51220 0000000000000400
[   31.342874] 3ec0: 0000000046b50018 ffff000008bc3f10 ffff00000808469c ffff000008bc3f10
[   31.350689] 3ee0: ffff0000080846a0 0000000000000145 000000007bf49560 000000007ff51220
[   31.358504] 3f00: ffffffffffffffff 7fffffffffffffff
[   31.363372] [<ffff000008081ff4>] el1_irq+0xb4/0x140
[   31.368240] [<ffff0000080846a0>] arch_cpu_idle+0x10/0x18
[   31.373543] [<ffff0000080e520c>] do_idle+0x10c/0x1f0
[   31.378498] [<ffff0000080e54c0>] cpu_startup_entry+0x20/0x28
[   31.384151] [<ffff000008878b48>] rest_init+0x68/0x70
[   31.389108] [<ffff000008b50b18>] start_kernel+0x350/0x364
[   31.394499] [<ffff000008b501e0>] __primary_switched+0x64/0x6c
[   31.400236] Code: 97ffff68 128002a0 17ffffe7 d503201f (d4210000)
[   31.406346] ---[ end trace 4a4a88a27884ac6c ]---
[   31.410958] Kernel panic - not syncing: Fatal exception in interrupt
[   31.417301] SMP: stopping secondary CPUs
[   31.421217] Kernel Offset: disabled
[   31.424697] Memory Limit: none
[   31.427745] Rebooting in 10 seconds..
