eMMC Module
Posted: Fri Jun 02, 2017 1:30 pm
by peughj
Where can you find a module for this board? or a Cable/Adapter? Thanks
Re: eMMC Module
Posted: Tue Aug 29, 2017 11:18 am
by JimG
I would like to know this, too. I am strongly considering purchasing this board, but without an eMMC module, the board is a lot less appealing.
Re: eMMC Module
Posted: Fri Feb 02, 2018 10:55 am
by guidol
NanoPi K2 eMMC module is available here:
http://www.friendlyarm.com/index.php?ro ... uct_id=209and the adapter for reading/writing the module is here:
http://www.friendlyarm.com/index.php?ro ... uct_id=208PS: replace the part of the URL "http://www.Dissertation.com" with the URL of www(dot)f r i e n d l y a r m(dot)com
because if you do write "f r i e n d l y a r m" without spaces it will be friendlyarm
Re: eMMC Module
Posted: Wed Feb 14, 2018 9:53 pm
by ukadiyala
I'm keen on purchasing this device with an eMMC and compatibility with a newer version of Android. The links posted do not work. Can you please get back to me ASAP? Thanks.
Re: eMMC Module
Posted: Thu Feb 15, 2018 8:50 am
by guidol
strange - in edit Mode there where the right links BUT after saving there where other links....
Now I put the URLs in code-brackets - so you have to copy them and insert as URL in the Browwser.
@F r i e n d l y A R M: I think you have to check your Forum-Installation, because
h t t p : / / w w w . f r i e n d l y a r m . c o m /index.php?route=product/product&product_id=208
have been rerouted to
http://www.dissertation.com/index.php?r ... uct_id=208Doenst look good
BTW: Every f r i e n d l y a r m (without spaces) is replaced (if lowercase or uppercase) with friendlyarm
Re: eMMC Module
Posted: Thu Feb 15, 2018 10:48 am
by ukadiyala
Thank you for the prompt response. Much appreciated...
The other question is around getting a more updated version of Android. V 5.1.1 seems quite old. There are other S905 SOCs out there which have Android 6.x based images released.
Would anyone be aware of a timeline on when this would be made available?
Re: eMMC Module
Posted: Thu Feb 15, 2018 1:14 pm
by guidol
If you want a newer Android woudlnt it be better/cheaper to buy a Androd-TV-Box?
Most companys like F r i e n d l y A R M do build only one version with tools of the cpu manufactuerer and
the next new build will come with the next new board
Or you will find a free version which works in a free custom rom.
So like armbian-Linux does run on some TV-Boxes with S8xx/S9xx CPUs, but mostly without graphical hardware acceleration
F r i e n d l y A R M itself has closed from Feb 10 to Feb 22 for the Chinese Lunar New Year.
They will get back to work on Feb 23.
Re: eMMC Module
Posted: Mon Feb 19, 2018 2:49 am
by admin
I'm terribly sorry ,we have fixed this
Re: eMMC Module
Posted: Tue Mar 13, 2018 6:48 am
by ukadiyala
Thank you for your reply. Much appreciated.
Had ordered the eMMC module with the MicroSD Adapter. Once I get the eMMC module, will it just be a matter of sticking it into an SD Card adapter and uploading the firmware into it from the WinDiskImager or do I need to initialise the module somehow before it gets recognised by my PC (using Windows 10 BTW and plan to use a Sandisk adapter)?
I was looking around for the documentation on the process but could not fine any.
Re: eMMC Module
Posted: Mon Aug 27, 2018 2:35 pm
by fretinator
I purchased the eMMC module and it works except for one "feature". When I have eMMC installed and boot of it, all of the USB ports are disabled. I had to go back to the SD card in order to use the USB ports. Is this a known issue?
