The Duo and Duo 2 have the same pinout. So i needed to have more storage so I pluged my Duo 2 into the Duo Starter Kit.
It the 64G MiniPCIe mSATA card I have installed in the kit.
I followed the directions as follows.
Enter the "Boot Options" menu, go to "Boot device" and you will see two options:
1) D1 Hard drive
2) D2 TF card
Select "D1 Hard drive" and proceed with its prompts.
Select "D2 TF card" to boot OS from a TF card.
This went smooth, but on next reboot i get the following in the terminal at the tail end. and it then just keeps rebooting with the same problem.
1) D1 Hard drive
2) D2 TF card
Gave up waiting for root device. Common problems:
- Boot args (cat /proc/cmdline)
- Check rootdelay= (did the system wait long enough?)
- Check root= (did the system wait for the right device?)
- Missing modules (cat /proc/modules; ls /dev)
ALERT! /dev/sda1 does not exist. Dropping to a shell!
Rebooting automatically due to panic= boot argument
