mSATA SSD Boot ?
Posted: Sat Sep 23, 2017 9:19 pm
by mikemoy
I just bought a Kingspec 64GB MiniPCIe mSATA Half-size SSD for my NanoPi Duo. I used Win32DiskImager to flash the image to it. I placed it into the NanoPi Duo Starter Kit and powered it on. But it did not boot. Can the Nano Pi Duo boot from mSATA ?
Re: mSATA SSD Boot ?
Posted: Sun Sep 24, 2017 3:43 am
by SunWukong
I had the same problem, so I used both, a 8 GB SD card and a 32 GB mSATA SSD. I changed the /boot/boot.cmd on the SD (/ dev / mmcblk0p1) to (/ dev / sda2), that the SSD as / is integrated.
setenv bootargs console=ttyS0,115200 earlyprintk root=/dev/sda2 rootfstype=ext4 rw rootwait fsck.repair=${fsck.repair} panic=10 ${extra} fbcon=${fbcon}
After editing /boot/boot.cmd I do this:
sudo mkimage -C none -A arm -T script -d /boot/boot.cmd /boot/boot.scr
sudo shutdown -r now
Posted: Sun Sep 24, 2017 10:48 am
by mikemoy
Thanks for the great help, that worked!
However I am looking for a way to just use mSATA drive alone without having a uSD installed. Is that possible ?
I am thinking this has to be done in U-boot.
Posted: Thu Sep 28, 2017 1:11 pm
by mikemoy
Just to update this. I was told by support this.
The SSD is not for system storage in our design, it is only for data backup,
so we don't make any instruction for how run OS on it, sorry.
This is too bad because the mSATA is SO much faster and better than the usd card.
I wish they had designed it to boot from it, it would have made this device perfect.
Posted: Sun Oct 01, 2017 3:35 am
by mikemoy
SunWukong wrote:I had the same problem, so I used both, a 8 GB SD card and a 32 GB mSATA SSD. I changed the /boot/boot.cmd on the SD (/ dev / mmcblk0p1) to (/ dev / sda2), that the SSD as / is integrated.
how did you resize the mSATA ssd ?
The wiki says "When you boot OS for the first time with your image card your OS will automatically resize the file system"
But that is for the uSD card.
Posted: Sun Oct 01, 2017 11:23 am
by guidol
you dont need to resize the msata sdd if you format the ssd normally and then recursively copy the uSD to the ssd and then change the boot argument!?
Posted: Fri Oct 20, 2017 4:46 pm
by mikemoy
Am i right in my thinking of what this does.
At power on, It will boot from the uSD card, then at some point switch over to the mSATA and from there on out only use that?
My whole goal is to keep the uSD access to a bare minimum.
Posted: Thu Oct 26, 2017 1:00 pm
by SunWukong
Yes, you are right. And yes, it is only a 'work around', but a SSD is faster and saver than a SD.
Posted: Mon Oct 30, 2017 1:59 pm
by guidol
here are also instructions how to use the complete mSATA as root / (not only partition2 if you clone from uSD to mSATA)
while the uSD is /boot
https://www.cnx-software.com/2017/10/30 ... ld-and-ssdsearch on the page for:
'Time to move the rootfs to the SSD, and to do so I’ll adapt the instructions for CubieTruck, another Allwinner development board.'
Posted: Tue Nov 07, 2017 2:45 pm
by mikemoy
Thank you both for the help!
@guidol, thanks so much for pointing that link out. It made everything so clear to do for a novice like me!
Posted: Sun Nov 12, 2017 2:52 pm
by mikemoy
There is a simpler way.
go to the wiki page:
http://wiki.friendlyarm.com/wiki/index.php/NanoPi_DuoAnd scroll down until you get to
Boot System from SSDWorks like a charm.
Posted: Mon Nov 13, 2017 5:49 am
by guidol
mikemoy wrote:
And scroll down until you get to Boot System from SSD
Does the boot work without a TF/uSD-Card? and does it boot a TF/uSD-Card when inserted?
Sounds like a u-boot setting.....
Posted: Mon Nov 13, 2017 6:11 am
by igorp
Not possible. U-boot must be somewhere - on SD card. On Armbian, this is even more simple (type nand-sata-install) and more advanced - possible to have BTRFS root filesystem on target drive.
