Bionic / Buster based optimised Armbian Linux 5.4.y
Base features are working as they should. Use armbian-config to turn hardware features on and off.
armbian-config -> system -> hardware (SPI,I2C,UART, AUDIO, ...)
Tested with shield board, mSATA drive, wireless, USB ports, audio, ... It's a first built, bugs are possible, but in general, it works fine.
https://www.armbian.com/nanopi-duo
Hi Igor,
at the armbian NanoPi Duo page there is only a link button for the xenial ubuntu not for the stretch version.
But I did get the stretch version out of the same directory while editing the url:
https://dl.armbian.com/nanopiduo/Debian ... nightly.7z
PS: stretch-version installed:
 _   _                   ____  _   ____
| \ | | __ _ _ __   ___ |  _ \(_) |  _ \ _   _  ___
|  \| |/ _` | '_ \ / _ \| |_) | | | | | | | | |/ _ \
| |\  | (_| | | | | (_) |  __/| | | |_| | |_| | (_) |
|_| \_|\__,_|_| |_|\___/|_|   |_| |____/ \__,_|\___/
Welcome to ARMBIAN 5.34.171103 nightly Debian GNU/Linux 9 (stretch) 4.13.10-sunxi
System load:   0.17 0.22 0.09   Up time:       2 min
Memory usage:  8 % of 493MB     IP:            192.168.6.113
CPU temp:      37°C
Usage of /:    15% of 7.2G
New to Armbian? Check the documentation first: https://docs.armbian.com
Last login: Thu Nov  2 10:58:46 2017 from 192.168.6.17
Great!
We plan to start actively promoting Debian Stretch when last few bugs are solved. They (known) are cosmetic and affect desktop builds, while CLI should already be fine.
Images were updated to 5.4.y, update (apt update) will follow shortly.
In total there are 39 users online :: 0 registered, 0 hidden and 39 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 39 guests
