NanoPi Duo, " timing out command, waited 180s" issue
Posted: Sat Sep 16, 2017 1:04 am
by mikemoy
I am constantly getting this in the terminal. What is the reason for this.
This is a fresh install from nanopi-duo_ubuntu-core-xenial_4.11.2_20170908.img.zip
root@NanoPi-Duo:~# [ 183.243424] sd 0:0:0:0: timing out command, waited 180s
[ 363.184929] sd 0:0:0:0: timing out command, waited 180s
[ 543.161443] sd 0:0:0:0: timing out command, waited 180s
[ 723.223300] sd 0:0:0:0: timing out command, waited 180s
[ 903.230300] sd 0:0:0:0: timing out command, waited 180s
[ 903.235937] sd 0:0:0:0: [sda] Asking for cache data failed
[ 903.241742] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 1083.322172] sd 0:0:0:0: timing out command, waited 180s
[ 1263.381305] sd 0:0:0:0: timing out command, waited 180s
[ 1263.389294] sd 0:0:0:0: timing out command, waited 30s
[ 1443.434428] sd 0:0:0:0: timing out command, waited 180s
[ 1623.402308] sd 0:0:0:0: timing out command, waited 180s
[ 1803.413176] sd 0:0:0:0: timing out command, waited 180s
Re: NanoPi Duo, " timing out command, waited 180s" issue
Posted: Sun Sep 17, 2017 11:35 am
by guidol
Looks like a bad or really slow MicroSD-Card.
Which card you you use? Brand? Speed?
Iam using a Sandisk Ultra 16GB , Speed: Class 10, 80MB/sec (grey/red - the white/red has only 48MB/sec)
[EDIT]:
Now I also see what you mean - I got this also showing up via dmesg:
[290602.875821] sd 0:0:0:0: timing out command, waited 20s
[290622.886702] sd 0:0:0:0: timing out command, waited 20s
[290667.087432] sd 0:0:0:0: timing out command, waited 20s
[290687.099332] sd 0:0:0:0: timing out command, waited 20s
[290723.810697] sd 0:0:0:0: timing out command, waited 20s
[290743.831691] sd 0:0:0:0: timing out command, waited 20s
[290780.202069] sd 0:0:0:0: timing out command, waited 20s
[290800.212946] sd 0:0:0:0: timing out command, waited 20s
[290844.015456] sd 0:0:0:0: timing out command, waited 20s
[290864.025444] sd 0:0:0:0: timing out command, waited 20s
[290899.947581] sd 0:0:0:0: timing out command, waited 20s
[290919.977699] sd 0:0:0:0: timing out command, waited 20s
BUT after a fresh reboot I got the following messages:
[ 3.152268] sd 0:0:0:0: [sda] Unit Not Ready
[ 3.156667] sd 0:0:0:0: [sda] Sense Key : 0x4 [current]
[ 3.161988] sd 0:0:0:0: [sda] ASC=0x44 <<vendor>>ASCQ=0x81
[ 183.180528] sd 0:0:0:0: timing out command, waited 180s
root@NanoPiDuo:~# dmesg -w|grep 'sd 0:0:0:0'
[ 363.229656] sd 0:0:0:0: timing out command, waited 180s
[ 543.244787] sd 0:0:0:0: timing out command, waited 180s
[ 543.250393] sd 0:0:0:0: [sda] Read Capacity(10) failed: Result: hostbyte=0x00 driverbyte=0x08
[ 543.250468] sd 0:0:0:0: [sda] Sense Key : 0x4 [current]
[ 543.250532] sd 0:0:0:0: [sda] ASC=0x44 <<vendor>>ASCQ=0x81
[ 543.250620] sd 0:0:0:0: [sda] 0 512-byte logical blocks: (0 B/0 B)
[ 543.250670] sd 0:0:0:0: [sda] 0-byte physical blocks
[ 723.289783] sd 0:0:0:0: timing out command, waited 180s
[ 723.295352] sd 0:0:0:0: [sda] Test WP failed, assume Write Enabled
[ 903.334026] sd 0:0:0:0: timing out command, waited 180s
[ 903.339572] sd 0:0:0:0: [sda] Asking for cache data failed
[ 903.345385] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 903.387067] sd 0:0:0:0: [sda] Unit Not Ready
[ 903.387195] sd 0:0:0:0: [sda] Sense Key : 0x4 [current]
[ 903.387389] sd 0:0:0:0: [sda] ASC=0x44 <<vendor>>ASCQ=0x81
[ 1083.400648] sd 0:0:0:0: timing out command, waited 180s
[ 1263.451276] sd 0:0:0:0: timing out command, waited 180s
[ 1263.461194] sd 0:0:0:0: timing out command, waited 30s
[ 1443.468392] sd 0:0:0:0: timing out command, waited 180s
[ 1443.473824] sd 0:0:0:0: [sda] Read Capacity(10) failed: Result: hostbyte=0x00 driverbyte=0x08
[ 1443.473860] sd 0:0:0:0: [sda] Sense Key : 0x4 [current]
[ 1443.473891] sd 0:0:0:0: [sda] ASC=0x44 <<vendor>>ASCQ=0x81
[ 1623.504763] sd 0:0:0:0: timing out command, waited 180s
[ 1803.541287] sd 0:0:0:0: timing out command, waited 180s
[ 1803.546926] sd 0:0:0:0: [sda] Attached SCSI disk
Hmmmm... whats that?
Dont know what there timed out before :(
Posted: Mon Sep 18, 2017 5:31 pm
by mikemoy
I am using a SanDisk Ultra 16GB Class 10. Have tried 2 different ones, with same issues.
Posted: Thu Sep 21, 2017 10:57 am
by chensy
What type of SD card do you use?
Thanks!
Posted: Thu Sep 28, 2017 12:22 am
by mikemoy
The problem is that there is no mSATA card installed. That is why we are getting these warnings.
Once you stick a mSATA card it they stop. I don't know why they have not done something about it so people can use it without so they dont get the terminal filled up with this information when its useless.
