weston video not working
Posted: Fri Dec 07, 2018 6:02 am
I have built an sdcard image for the Neo4 using this external buildroot system :
viewtopic.php?f=61&t=2020
I am having trouble starting weston, I get the following errors - any help would be hugely appreciated :
# weston --tty 2
Date: 2018-12-07 UTC
[05:45:15.046] weston 3.0.0
http://wayland.freedesktop.org
Bug reports to: https://bugs.freedesktop.org/enter_bug.cgi?product=Wayland&component=weston&version=3.0.0
Build: unknown (not built from git or tarball)
[05:45:15.046] Command line: weston --tty 2
[05:45:15.047] OS: Linux, 4.4.143, #1 SMP Fri Dec 7 16:02:19 AEDT 2018, aarch64
[05:45:15.047] Starting with no config file.
[05:45:15.052] Output repaint window is 15 ms maximum.
[05:45:15.055] Loading module '/usr/lib/libweston-3/drm-backend.so'
[05:45:15.075] initializing drm backend
[05:45:15.088] using /dev/dri/card0
[05:45:15.095] Loading module '/usr/lib/libweston-3/gl-renderer.so'
gbm: failed to open any driver (search paths /usr/lib/dri)
gbm: Last dlopen error: /usr/lib/dri/rockchip_dri.so: cannot open shared object file: No such file or directory
failed to load driver: rockchip
[05:45:15.258] EGL client extensions: EGL_EXT_client_extensions
EGL_EXT_platform_base EGL_KHR_client_get_all_proc_addresses
EGL_KHR_debug EGL_EXT_platform_wayland
[05:45:15.261] failed to initialize egl
[05:45:15.342] fatal: failed to create compositor backend
