I tried installing the latest FriendlyWrt (rk3399-sd-friendlywrt-5.10-20211029.img) on my new NanoPi R4S but I can't seem to get any 802.1Q VLAN tagging to work on either my LAN or WAN ports. It always fails with a "DEVICE_CLAIM_FAILED" error.
However it works perfectly (with the same config) when I use the latest build from https://github.com/quintus-lab/openwrt-rockchip. For background, my ISP requires VLAN tagging and PPPoE on my WAN port.
Here's the output from ifstatus wan (currently disconnected, but I get "DEVICE_CLAIM_FAILED" either way):
"up": false,
"pending": false,
"available": true,
"autostart": true,
"dynamic": false,
"proto": "pppoe",
"device": "eth0.201",
"data": {
"errors": [
"subsystem": "interface",
"code": "DEVICE_CLAIM_FAILED"
