how to generate boot.img
Posted: Fri Nov 30, 2018 5:54 am
by flatmax
Hi there,
I would like to generate boot.img, however any time I do generate boot.img the sdcard doesn't work.
If I do the following to build the boot.img :
git clone https://github.com/friendlyarm/kernel-rockchip --depth 1 -b nanopi4-linux-v4.4.y kernel-rockchip
cd kernel-rockchip
make nanopi4_linux_defconfig
make rk3399-nanopi4-rev04.img
It generates the boot.img as expected, however sd_fuse-rk3399/fusing.sh doesn't generate a usable sd card.
If I replace boot.img with the original boot.img, the sdcard boots and works well.
If I build the kernel.img and resource.img files using the following command :
make nanopi4-images
I can use sd_fuse-rk3399 with these images, and the sd card will boot as expected and works well.
What is the magic to build the boot.img ?
thanks
Matt
Re: how to generate boot.img
Posted: Fri Nov 30, 2018 6:20 am
by igorp
This script https://github.com/armbian/build produce a bootable image.
Posted: Fri Nov 30, 2018 11:46 am
by flatmax
Can you please highlight exactly where the boot.img is generated ? Is this the same boot.img which is used by sd_fuse-rk3399 to generate the sdcard image ?
Posted: Mon Oct 28, 2019 12:38 pm
by ramgopalkota
I replaced kernel.img , resource.img it is still going to old kernel version. Looks like boot.img should have latest kernel. How to create this boot.img file ? Does it have Image / DTB / Ramdisk ? Please help.
Ramgopal Kota
