board hangs after booting with AOSP
Posted: Fri Oct 11, 2019 7:09 am
I have a weird problem now , i have build with the friendly arm AOSP and flashed to board .
the board boots now and Android shows up then display is getting off ,board hangs ,
how do i resolve issue ?below is uart debug output
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbdbfff0000 ( 246 GB)
[ 0.000000] .init : 0xffffff8008ff0000 - 0xffffff80090c0000 ( 832 KB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008ae0000 ( 10624 KB)
[ 0.000000] .rodata : 0xffffff8008ae0000 - 0xffffff8008ff0000 ( 5184 KB)
[ 0.000000] .data : 0xffffff80090c0000 - 0xffffff800923c008 ( 1521 KB)
[ 0.000000] vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000 ( 8 GB maximum)
[ 0.000000] 0xffffffbdc0008000 - 0xffffffbdc2000000 ( 31 MB actual)
[ 0.000000] fixed : 0xffffffbffe7fb000 - 0xffffffbffec00000 ( 4116 KB)
[ 0.000000] PCI I/O : 0xffffffbffee00000 - 0xffffffbfffe00000 ( 16 MB)
[ 0.000000] memory : 0xffffffc000200000 - 0xffffffc080000000 ( 2046 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] ITS: /interrupt-controller@fee00000/interrupt-controller@fee20000
[ 0.000000] ITS: allocated 65536 Devices @a200000 (psz 64K, shr 0)
[ 0.000000] ITS: using cache flushing for cmd queue
[ 0.000000] GIC: using LPI property table @0x000000000a280000
[ 0.000000] ITS: Allocated 1792 chunks for LPIs
[ 0.000000] CPU0: found redistributor 0 region 0:0x00000000fef00000
[ 0.000000] CPU0: using LPI pending table @0x000000000a290000
[ 0.000000] GIC: using cache flushing for LPI property table
[ 0.000000] GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@1[1] /cpus/cpu@2[2] /cpus/cpu@3[3] }
[ 0.000000] GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@100[4] /cpus/cpu@101[5] }
[ 0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop0_frac as parent of dclk_vop0, rate changes may not work
[ 0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop1_frac as parent of dclk_vop1, rate changes may not work
[ 0.000000] rockchip_cpuclk_pre_rate_change: limiting alt-divider 33 to 31
[ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[ 0.000006] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.001789] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[ 0.002751] pid_max: default: 32768 minimum: 301
[ 0.003242] Security Framework initialized
[ 0.003631] SELinux: Initializing.
[ 0.004061] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.004689] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.006120] Initializing cgroup subsys memory
[ 0.006550] Initializing cgroup subsys freezer
[ 0.007836] sched-energy: Sched-energy-costs installed from DT
[ 0.008385] CPU0: update cpu_capacity 401
[ 0.008834] ASID allocator initialised with 32768 entries
[ 0.025661] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.026853] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.039064] Detected VIPT I-cache on CPU1
[ 0.039095] CPU1: found redistributor 1 region 0:0x00000000fef20000
[ 0.039129] CPU1: using LPI pending table @0x000000000a3f0000
[ 0.039171] CPU1: update cpu_capacity 401
[ 0.039174] CPU1: Booted secondary processor [410fd034]
[ 0.049054] Detected VIPT I-cache on CPU2
[ 0.049074] CPU2: found redistributor 2 region 0:0x00000000fef40000
[ 0.049106] CPU2: using LPI pending table @0x000000007c020000
[ 0.049134] CPU2: update cpu_capacity 401
[ 0.049137] CPU2: Booted secondary processor [410fd034]
[ 0.059087] Detected VIPT I-cache on CPU3
[ 0.059106] CPU3: found redistributor 3 region 0:0x00000000fef60000
[ 0.059138] CPU3: using LPI pending table @0x000000007c060000
[ 0.059164] CPU3: update cpu_capacity 401
[ 0.059168] CPU3: Booted secondary processor [410fd034]
[ 0.069134] Detected PIPT I-cache on CPU4
[ 0.069162] CPU4: found redistributor 100 region 0:0x00000000fef80000
[ 0.069200] CPU4: using LPI pending table @0x000000007c0b0000
[ 0.069239] CPU4: update cpu_capacity 1024
[ 0.069242] CPU4: Booted secondary processor [410fd082]
[ 0.079161] Detected PIPT I-cache on CPU5
[ 0.079179] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[ 0.079214] CPU5: using LPI pending table @0x000000007c0e0000
[ 0.079242] CPU5: update cpu_capacity 1024
[ 0.079245] CPU5: Booted secondary processor [410fd082]
[ 0.079328] Brought up 6 CPUs
[ 0.091433] SMP: Total of 6 processors activated.
[ 0.091876] CPU features: detected feature: GIC system register CPU interface
[ 0.092548] CPU: All CPU(s) started at EL2
[ 0.092972] alternatives: patching kernel code
[ 0.095288] devtmpfs: initialized
[ 0.114944] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.115901] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.117231] pinctrl core: initialized pinctrl subsystem
[ 0.119142] Failed to find legacy iommu devices
[ 0.119974] NET: Registered protocol family 16
[ 0.120792] schedtune: init normalization constants...
[ 0.121295] schedtune: CLUSTER[0-3] min_pwr: 56 max_pwr: 222
[ 0.121928] schedtune: CPU[0] min_pwr: 0 max_pwr: 222
[ 0.122561] schedtune: CPU[1] min_pwr: 0 max_pwr: 222
[ 0.123206] schedtune: CPU[2] min_pwr: 0 max_pwr: 222
[ 0.123839] schedtune: CPU[3] min_pwr: 0 max_pwr: 222
[ 0.124472] schedtune: CLUSTER[4-5] min_pwr: 65 max_pwr: 1108
[ 0.125104] schedtune: CPU[4] min_pwr: 0 max_pwr: 1108
[ 0.125736] schedtune: CPU[5] min_pwr: 0 max_pwr: 1108
[ 0.126368] schedtune: SYSTEM min_pwr: 121 max_pwr: 4434
[ 0.127028] schedtune: using normalization constants mul: 3862781856 sh1: 1 sh2: 12
[ 0.127768] schedtune: verify normalization constants...
[ 0.128283] schedtune: max_pwr/2^0: 4313 => norm_pwr: 1024
[ 0.128823] schedtune: max_pwr/2^1: 2156 => norm_pwr: 511
[ 0.129363] schedtune: max_pwr/2^2: 1078 => norm_pwr: 255
[ 0.129903] schedtune: max_pwr/2^3: 539 => norm_pwr: 127
[ 0.130449] schedtune: max_pwr/2^4: 269 => norm_pwr: 63
[ 0.130989] schedtune: max_pwr/2^5: 134 => norm_pwr: 31
[ 0.131528] schedtune: configured to support 5 boost groups
[ 0.140483] cpuidle: using governor ladder
[ 0.150488] cpuidle: using governor menu
[ 0.150885] Registered FIQ tty driver
[ 0.151585] vdso: 2 pages (1 code @ ffffff8008ae6000, 1 data @ ffffff80090c4000)
[ 0.152321] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.153722] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.174673] console [pstore-1] enabled
[ 0.175268] pstore: Registered ramoops as persistent store backend
[ 0.175871] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[ 0.178908] fiq debugger fiq mode enabled
[ [ 0.179564] console [ttyFIQ0] enabled
[ 0.180254] bootconsole [uart0] disabled
[ 0.180824] Registered fiq debugger ttyFIQ0
[ 0.211098] vcc_lcd: supplied by vcc5v0_sys
[ 0.237091] iommu: Adding device ff650000.vpu_service to group 0
[ 0.237165] iommu: Adding device ff660000.rkvdec to group 1
[ 0.237240] iommu: Adding device ff670000.iep to group 2
[ 0.237335] iommu: Adding device ff8f0000.vop to group 3
[ 0.237410] iommu: Adding device ff900000.vop to group 4
[ 0.237515] iommu: Adding device ff910000.isp to group 5
[ 0.237588] iommu: Adding device ff920000.isp to group 6
[ 0.238267] rk_iommu ff670800.iommu: can't get aclk
[ 0.238282] rk_iommu ff670800.iommu: can't get hclk
[ 0.239116] SCSI subsystem initialized
[ 0.239286] usbcore: registered new interface driver usbfs
[ 0.239330] usbcore: registered new interface driver hub
[ 0.239406] usbcore: registered new device driver usb
[ 0.239764] media: Linux media interface: v0.10
[ 0.239798] Linux video capture interface: v2.00
[ 0.239973] pps_core: LinuxPPS API ver. 1 registered
[ 0.239982] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.240003] PTP clock support registered
[ 0.241638] Advanced Linux Sound Architecture Driver Initialized.
[ 0.242174] Bluetooth: Core ver 2.21
[ 0.242207] NET: Registered protocol family 31
[ 0.242215] Bluetooth: HCI device and connection manager initialized
[ 0.242228] Bluetooth: HCI socket layer initialized
[ 0.242240] Bluetooth: L2CAP socket layer initialized
[ 0.242266] Bluetooth: SCO socket layer initialized
[ 0.243042] rockchip-cpuinfo cpuinfo: Serial : a290c00011aa09a5
[ 0.243558] clocksource: Switched to clocksource arch_sys_counter
[ 0.286372] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.286601] NET: Registered protocol family 2
[ 0.287050] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.287191] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[ 0.287465] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.287542] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[ 0.287600] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[ 0.287771] NET: Registered protocol family 1
[ 0.288636] Trying to unpack rootfs image as initramfs...
[ 0.356741] Freeing initrd memory: 1504K
[ 0.357345] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.357432] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.360166] audit: initializing netlink subsys (disabled)
[ 0.360251] audit: type=2000 audit(0.356:1): initialized
[ 0.365367] VFS: Disk quotas dquot_6.6.0
[ 0.365496] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.366484] Registering sdcardfs 0.1
[ 0.367087] fuse init (API version 7.23)
[ 0.368183]
[ 0.368183] TEE Core Framework initialization (ver 1:0.1)
[ 0.368209] TEE armv7 Driver initialization
[ 0.368572] tz_tee_probe: name="armv7sec", id=0, pdev_name="armv7sec.0"
[ 0.368592] TEE core: Alloc the misc device "opteearmtz00" (id=0)
[ 0.368764] TEE Core: Register the misc device "opteearmtz00" (id=0,minor=62)
[ 0.372769] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 0.372790] io scheduler noop registered
[ 0.372952] io scheduler cfq registered (default)
[ 0.374150] phy phy-ff770000.syscon:usb2-phy@e460.0: Failed to get VBUS supply regulator
[ 0.378812] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found
[ 0.378836] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[ 0.378850] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[ 0.900288] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[ 0.900447] rockchip-pcie: probe of f8000000.pcie failed with error -110
[ 0.901303] backlight supply power not found, using dummy regulator
[ 0.901893] iep: failed to find iep power down clock source.
[ 0.902439] IEP Power ON
[ 0.902687] IEP Power OFF
[ 0.902800] IEP Driver loaded succesfully
[ 0.903048] Module initialized.
[ 0.903459] rk-vcodec ff650000.vpu_service: no regulator for vcodec
[ 0.903808] rk-vcodec ff650000.vpu_service: probe device
[ 0.903861] rk-vcodec ff650000.vpu_service: vpu mmu dec ffffffc07c25dc10
[ 0.904031] rk-vcodec ff650000.vpu_service: allocator is drm
[ 0.904085] rk-vcodec ff650000.vpu_service: checking hw id 0
[ 0.904605] rk-vcodec ff650000.vpu_service: could not find power_model node
[ 0.904621] rk-vcodec ff650000.vpu_service: init success
[ 0.904808] rk-vcodec ff660000.rkvdec: no regulator for vcodec
[ 0.905193] rk-vcodec ff660000.rkvdec: probe device
[ 0.905237] rk-vcodec ff660000.rkvdec: vpu mmu dec ffffffc07c25e410
[ 0.905376] rk-vcodec ff660000.rkvdec: allocator is drm
[ 0.905428] rk-vcodec ff660000.rkvdec: checking hw id 6876
[ 0.905763] rk-vcodec ff660000.rkvdec: could not find power_model node
[ 0.905777] rk-vcodec ff660000.rkvdec: init success
[ 0.907341] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.907362] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 0.908720] dma-pl330 ff6e00�-dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.908739] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 0.910728] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[ 0.912394] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 38, base_baud = 1500000) is a 16550A
[ 0.912687] rockchip-pinctrl pinctrl: pin gpio4-19 already requested by fiq-debugger; cannot claim for ff1a0000.serial
[ 0.912704] rockchip-pinctrl pinctrl: pin-147 (ff1a0000.serial) status -22
[ 0.912715] rockchip-pinctrl pinctrl: could not request pin 147 (gpio4-19) from group uart2c-xfer on device rockchip-pinctrl
[ 0.912725] dw-apb-uart ff1a0000.serial: Error applying setting, reverse things back
[ 0.912991] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 39, base_baud = 1500000) is a 16550A
[ 0.913531] ff370000.serial: ttyS4 at MMIO 0xff370000 (irq = 41, base_baud = 1500000) is a 16550A
[ 0.913923] [drm] Initialized drm 1.1.0 20060810
[ 0.917436] [drm] Rockchip DRM driver version: v1.0.1
[ 0.919868] mali ff9a0000.gpu: Failed to get regulator
[ 0.919884] mali ff9a0000.gpu: Power control initialization failed
[ 0.920183] Unable to detect cache hierarchy for CPU 0
[ 0.930353] brd: module loaded
[ 0.940001] loop: module loaded
[ 0.940692] zram: Added device: zram0
[ 0.944880] SCSI Media Changer driver v0.25
[ 0.948842] tun: Universal TUN/TAP device driver, 1.6
[ 0.948855] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 0.949834] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[ 0.949854] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28).
[ 0.949865] rk_gmac-dwmac fe300000.ethernet: RX delay(0x11).
[ 0.949890] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[ 0.950043] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed
[ 0.950055] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[ 0.955070] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[ 0.955185] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 0.955196] Ring mode enabled
[ 0.955204] DMA HW capability register supported
[ 0.955211] Normal descriptors
[ 0.955220] RX Checksum Offload Engine supported (type 2)
[ 0.955227] TX Checksum insertion supported
[ 0.955234] Wake-Up On Lan supported
[ 0.955273] Enable RX Mitigation via HW Watchdog Timer
[ 1.022951] libphy: stmmac: probed
[ 1.022993] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
[ 1.023002] eth%d: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01)
[ 1.023899] PPP generic driver version 2.4.2
[ 1.024119] PPP BSD Compression module registered
[ 1.024172] PPP Deflate Compression module registered
[ 1.024214] PPP MPPE Compression module registered
[ 1.024267] NET: Registered protocol family 24
[ 1.024331] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 1.024340] CSLIP: code copyright 1989 Regents of the University of California.
[ 1.024358] Rockchip WiFi SYS interface (V1.00) ...
[ 1.024498] usbcore: registered new interface driver catc
[ 1.024589] usbcore: registered new interface driver kaweth
[ 1.024606] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 1.024659] usbcore: registered new interface driver pegasus
[ 1.024747] usbcore: registered new interface driver rtl8150
[ 1.024802] usbcore: registered new interface driver r8152
[ 1.024818] hso: drivers/net/usb/hso.c: Option Wireless
[ 1.024900] usbcore: registered new interface driver hso
[ 1.024997] usbcore: registered new interface driver asix
[ 1.025056] usbcore: registered new interface driver ax88179_178a
[ 1.025117] usbcore: registered new interface driver cdc_ether
[ 1.025205] usbcore: registered new interface driver cdc_eem
[ 1.025273] usbcore: registered new interface driver dm9601
[ 1.025345] usbcore: registered new interface driver smsc75xx
[ 1.025444] usbcore: registered new interface driver smsc95xx
[ 1.025499] usbcore: registered new interface driver gl620a
[ 1.025558] usbcore: registered new interface driver net1080
[ 1.025651] usbcore: registered new interface driver plusb
[ 1.025707] usbcore: registered new interface driver rndis_host
[ 1.025765] usbcore: registered new interface driver cdc_subset
[ 1.025863] usbcore: registered new interface driver zaurus
[ 1.025919] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 1.026004] usbcore: registered new interface driver int51x1
[ 1.026097] usbcore: registered new interface driver kalmia
[ 1.026153] usbcore: registered new interface driver ipheth
[ 1.026215] usbcore: registered new interface driver sierra_net
[ 1.026314] usbcore: registered new interface driver cx82310_eth
[ 1.026381] usbcore: registered new interface driver cdc_ncm
[ 1.026444] usbcore: registered new interface driver qmi_wwan
[ 1.026537] usbcore: registered new interface driver cdc_mbim
[ 1.028464] rockchip-dwc3 usb@fe800000: failed to get drvdata dwc3
[ 1.033193] rockchip-dwc3 usb@fe900000: fail to get drvdata hcd
[ 1.034844] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.034898] ehci-pci: EHCI PCI platform driver
[ 1.034994] ehci-platform: EHCI generic platform driver
[ 1.039056] ehci-platform fe3c0000.usb: EHCI Host Controller
[ 1.039313] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 1
[ 1.039575] ehci-platform fe3c0000.usb: irq 30, io mem 0xfe3c0000
[ 1.046922] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[ 1.047144] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.047190] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.047204] usb usb1: Product: EHCI Host Controller
[ 1.047217] usb usb1: Manufacturer: Linux 4.4.126 ehci_hcd
[ 1.047267] usb usb1: SerialNumber: fe3c0000.usb
[ 1.047884] hub 1-0:1.0: USB hub found
[ 1.047966] hub 1-0:1.0: 1 port detected
[ 1.048774] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.048839] ohci-platform: OHCI generic platform driver
[ 1.049453] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[ 1.049672] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 2
[ 1.049922] ohci-platform fe3e0000.usb: irq 31, io mem 0xfe3e0000
[ 1.104449] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.104497] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.104512] usb usb2: Product: Generic Platform OHCI controller
[ 1.104525] usb usb2: Manufacturer: Linux 4.4.126 ohci_hcd
[ 1.104537] usb usb2: SerialNumber: fe3e0000.usb
[ 1.105094] hub 2-0:1.0: USB hub found
[ 1.105142] hub 2-0:1.0: 1 port detected
[ 1.106454] usbcore: registered new interface driver cdc_acm
[ 1.106499] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.106580] usbcore: registered new interface driver usblp
[ 1.106644] usbcore: registered new interface driver cdc_wdm
[ 1.106706] usbcore: registered new interface driver uas
[ 1.106842] usbcore: registered new interface driver usb-storage
[ 1.106974] usbcore: registered new interface driver ums-alauda
[ 1.107065] usbcore: registered new interface driver ums-cypress
[ 1.107129] usbcore: registered new interface driver ums-datafab
[ 1.107222] usbcore: registered new interface driver ums_eneub6250
[ 1.107276] usbcore: registered new interface driver ums-freecom
[ 1.107332] usbcore: registered new interface driver ums-isd200
[ 1.107390] usbcore: registered new interface driver ums-jumpshot
[ 1.107478] usbcore: registered new interface driver ums-karma
[ 1.107534] usbcore: registered new interface driver ums-onetouch
[ 1.107596] usbcore: registered new interface driver ums-sddr09
[ 1.107684] usbcore: registered new interface driver ums-sddr55
[ 1.107745] usbcore: registered new interface driver ums-usbat
[ 1.107855] usbcore: registered new interface driver usbserial
[ 1.107939] usbcore: registered new interface driver usbserial_generic
[ 1.107978] usbserial: USB Serial support registered for generic
[ 1.108043] usbcore: registered new interface driver ch341
[ 1.108112] usbserial: USB Serial support registered for ch341-uart
[ 1.108175] usbcore: registered new interface driver cp210x
[ 1.108212] usbserial: USB Serial support registered for cp210x
[ 1.108286] usbcore: registered new interface driver ftdi_sio
[ 1.108356] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 1.108485] usbcore: registered new interface driver option
[ 1.108555] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.108718] usbcore: registered new interface driver oti6858
[ 1.108788] usbserial: USB Serial support registered for oti6858
[ 1.108851] usbcore: registered new interface driver pl2303
[ 1.108888] usbserial: USB Serial support registered for pl2303
[ 1.108955] usbcore: registered new interface driver qcserial
[ 1.109025] usbserial: USB Serial support registered for Qualcomm USB modem
[ 1.109103] usbcore: registered new interface driver sierra
[ 1.109143] usbserial: USB Serial support registered for Sierra USB modem
[ 1.109213] usbcore: registered new interface driver trancevibrator
[ 1.109264] usb20_otg: version 3.10a 21-DEC-2012
[ 1.109572] usb20_host: version 3.10a 21-DEC-2012
[ 1.110462] usbcore: registered new interface driver xpad
[ 1.110529] usbcore: registered new interface driver usb_acecad
[ 1.110631] usbcore: registered new interface driver aiptek
[ 1.110697] usbcore: registered new interface driver gtco
[ 1.110800] usbcore: registered new interface driver hanwang
[ 1.110860] usbcore: registered new interface driver kbtab
[ 1.110922] <<-GTP-INFO->> GTP driver installing
[ 1.111603] .. rk pwm remotectl v1.1 init
[ 1.111977] input: ff420030.pwm as /devices/platform/ff420030.pwm/input/input0
[ 1.112614] sensor_register_slave:kxtj9,id=11
[ 1.112670] sensor_register_slave:mma8452,id=17
[ 1.112689] sensor_register_slave:lis3dh,id=7
[ 1.112738] sensor_register_slave:mma7660,id=18
[ 1.112756] sensor_register_slave:lsm303d,id=22
[ 1.112774] sensor_register_slave:gs_mc3230,id=23
[ 1.112782] [Gsensor] gsensor_init
[ 1.112796] sensor_register_slave:mpu6880_acc,id=24
[ 1.112810] sensor_register_slave:mpu6500_acc,id=25
[ 1.112824] sensor_register_slave:lsm330_acc,id=26
[ 1.112837] sensor_register_slave:bma2xx_acc,id=27
[ 1.112850] sensor_register_slave:akm8975,id=30
[ 1.112864] sensor_register_slave:akm8963,id=31
[ 1.112877] sensor_register_slave:l3g4200d,id=45
[ 1.112891] sensor_register_slave:l3g20d,id=46
[ 1.112905] sensor_register_slave:ewtsa,id=47
[ 1.112955] sensor_register_slave:lsm330_gyro,id=51
[ 1.112969] sensor_register_slave:cm3217,id=54
[ 1.112982] sensor_register_slave:cm3218,id=55
[ 1.112996] sensor_register_slave:ls_stk3410,id=63
[ 1.113009] sensor_register_slave:bh1750,id=53
[ 1.113023] sensor_register_slave:ps_stk3410,id=68
[ 1.114103] i2c /dev entries driver
[ 1.115749] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[ 1.115882] fan53555-reg: supplied by vcc3v3_sys
[ 1.118583] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[ 1.118688] fan53555-reg: supplied by vcc3v3_sys
[ 1.121199] rk808 0-001b: Pmic Chip id: 0x0
[ 1.125014] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 1.125097] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 1.125241] DCDC_REG1: supplied by vcc3v3_sys
[ 1.126080] DCDC_REG2: supplied by vcc3v3_sys
[ 1.126744] DCDC_REG3: supplied by vcc3v3_sys
[ 1.127170] DCDC_REG4: supplied by vcc3v3_sys
[ 1.127725] LDO_REG1: supplied by vcc3v3_sys
[ 1.128990] LDO_REG2: supplied by vcc3v3_sys
[ 1.130083] LDO_REG3: supplied by vcc3v3_sys
[ 1.131176] LDO_REG4: supplied by vcc3v3_sys
[ 1.132258] LDO_REG5: supplied by vcc3v3_sys
[ 1.133355] LDO_REG6: supplied by vcc3v3_sys
[ 1.134452] LDO_REG7: supplied by vcc3v3_sys
[ 1.135506] LDO_REG8: supplied by vcc3v3_sys
[ 1.136598] SWITCH_REG1: supplied by vcc3v3_sys
[ 1.137034] SWITCH_REG2: supplied by vcc3v3_sys
[ 1.140975] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
[ 1.141476] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff8009656000
[ 1.142333] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff8009658000
[ 1.142929] rk3x-i2c ff120000.i2c: Initialized RK3xxx I2C bus at ffffff800965a000
[ 1.143464] rk3x-i2c ff160000.i2c: Initialized RK3xxx I2C bus at ffffff800965c000
[ 1.145067] fusb302 4-0022: Can't get property of role, set role to default DRP
[ 1.148523] fusb302 4-0022: port 0 probe success with role ROLE_MODE_DRP, try_role ROLE_MODE_NONE
[ 1.149057] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff800965e000
[ 1.150272] IR NEC protocol handler initialized
[ 1.150324] IR RC5(x/sz) protocol handler initialized
[ 1.150340] IR RC6 protocol handler initialized
[ 1.150354] IR JVC protocol handler initialized
[ 1.150369] IR Sony protocol handler initialized
[ 1.150383] IR SANYO protocol handler initialized
[ 1.150398] IR Sharp protocol handler initialized
[ 1.150413] IR MCE Keyboard/mouse protocol handler initialized
[ 1.150428] IR XMP protocol handler initialized
[ 1.150746] usbcore: registered new interface driver uvcvideo
[ 1.150758] USB Video Class driver (1.1.1)
[ 1.150781] CamSys driver version: v0.41.0, CamSys head file version: v1.0.0
[ 1.156586] __power_supply_register: Expected proper parent device for 'test_ac'
[ 1.156827] __power_supply_register: Expected proper parent device for 'test_battery'
[ 1.157303] thermal thermal_zone2: power_allocator: sustainable_power will be estimated
[ 1.157493] __power_supply_register: Expected proper parent device for 'test_usb'
[ 1.161361] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647
[ 1.162879] device-mapper: uevent: version 1.0.3
[ 1.163367] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 1.163761] Bluetooth: HCI UART driver ver 2.3
[ 1.163818] Bluetooth: HCI UART protocol H4 registered
[ 1.163828] Bluetooth: HCI UART protocol LL registered
[ 1.163845] rtk_btusb: RTKBT_RELEASE_NAME: 20170109_TV_ANDROID_6.x
[ 1.163854] rtk_btusb: Realtek Bluetooth USB driver module init, version 4.1.2
[ 1.163862] rtk_btusb: Register usb char device interface for BT driver
[ 1.164167] usbcore: registered new interface driver rtk_btusb
[ 1.164869] cpu cpu0: cpu_leakage=9
[ 1.164979] cpu cpu0: cpu_leakage=9
[ 1.177901] cpu cpu0: temp=38125, pvtm=136580 (136925 + -345)
[ 1.178785] cpu cpu4: cpu_leakage=16
[ 1.178920] cpu cpu4: cpu_leakage=16
[ 1.191056] cpu cpu4: temp=38125, pvtm=142131 (142344 + -213)
[ 1.196834] sdhci: Secure Digital Host Controller Interface driver
[ 1.196925] sdhci: Copyright(c) Pierre Ossman
[ 1.196944] Synopsys Designware Multimedia Card Interface Driver
[ 1.198240] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.198401] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 1.198421] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 1.198498] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 1.198565] dwmmc_rockchip fe310000.dwmmc: 'clock-freq-min-max' property was deprecated.
[ 1.198619] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 1.198645] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 1.199806] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.199935] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[ 1.199954] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[ 1.200022] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[ 1.200077] dwmmc_rockchip fe320000.dwmmc: 'clock-freq-min-max' property was deprecated.
[ 1.200692] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3000000 done
[ 1.200745] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3000000 done
[ 1.213678] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 1.231382] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized
[ 1.231853] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.233900] sdhci-arasan fe330000.sdhci: No vmmc regulator found
[ 1.233950] sdhci-arasan fe330000.sdhci: No vqmmc regulator found
[ 1.260363] mmc1: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[ 1.262482] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.266186] usbcore: registered new interface driver usbhid
[ 1.266214] usbhid: USB HID core driver
[ 1.266461] inv_mpu_iio: inv_mpu_init:746
[ 1.267548] ashmem: initialized
[ 1.274240] ff100000.saradc supply vref not found, using dummy regulator
[ 1.276800] rknandbase v1.2 2018-05-08
[ 1.277905] usbcore: registered new interface driver snd-usb-audio
[ 1.291088] u32 classifier
[ 1.291131] Actions configured
[ 1.291216] Netfilter messages via NETLINK v0.30.
[ 1.291320] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 1.292038] ctnetlink v0.93: registering with nfnetlink.
[ 1.293346] xt_time: kernel timezone is -0000
[ 1.294696] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.295173] arp_tables: (C) 2002 David S. Miller
[ 1.295594] fusb302 4-0022: CC connected in CC1 as UFP
[ 1.295753] Initializing XFRM netlink socket
[ 1.296624] NET: Registered protocol family 10
[ 1.297328] fusb302 4-0022: connection has disconnected
[ 1.298507] mip6: Mobile IPv6
[ 1.298577] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 1.300340] sit: IPv6 over IPv4 tunneling driver
[ 1.301136] mmc1: MAN_BKOPS_EN bit is not set
[ 1.301242] NET: Registered protocol family 17
[ 1.301300] NET: Registered protocol family 15
[ 1.301368] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 1.302288] Bridge firewalling registered
[ 1.302320] Ebtables v2.0 registered
[ 1.302697] Bluetooth: RFCOMM TTY layer initialized
[ 1.302738] Bluetooth: RFCOMM socket layer initialized
[ 1.302782] Bluetooth: RFCOMM ver 1.11
[ 1.302822] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 1.302838] Bluetooth: BNEP filters: protocol multicast
[ 1.302861] Bluetooth: BNEP socket layer initialized
[ 1.302885] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.302906] Bluetooth: HIDP socket layer initialized
[ 1.302968] l2tp_core: L2TP core driver, V2.0
[ 1.303003] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 1.303028] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 1.303507] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 1.303629] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6354
[ 1.303652] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 1.303668] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 1.303801] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 3, flags = 0.
[ 1.303817] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 1.303850] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 1.303938] [BT_RFKILL]: Enter rfkill_rk_init
[ 1.304550] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 83.
[ 1.304644] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 9.
[ 1.304703] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 90.
[ 1.304761] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 4.
[ 1.305458] [BT_RFKILL]: Request irq for bt wakeup host
[ 1.305530] [BT_RFKILL]: BT_WAKE_HOST IRQ fired
[ 1.305571] [BT_RFKILL]: ** disable irq
[ 1.305815] [BT_RFKILL]: bt_default device registered.
[ 1.306188] sensor_register_slave:mpu6500_gyro,id=49
[ 1.306229] sensor_register_slave:mpu6880_gyro,id=50
[ 1.308218] Registered cp15_barrier emulation handler
[ 1.308367] Registered setend emulation handler
[ 1.309561] registered taskstats version 1
[ 1.310503] mmc1: new HS200 MMC card at address 0001
[ 1.310884] rockchip ion idev is NULL
[ 1.310903] rga2 ff680000.rga: rga ion client create success!
[ 1.311172] rga: Driver loaded successfully ver:3.02
[ 1.311325] mmcblk1: mmc1:0001 BJTD4R 29.1 GiB
[ 1.311705] mmcblk1boot0: mmc1:0001 BJTD4R partition 1 4.00 MiB
[ 1.312065] mmcblk1boot1: mmc1:0001 BJTD4R partition 2 4.00 MiB
[ 1.312341] mmcblk1rpmb: mmc1:0001 BJTD4R partition 3 4.00 MiB
[ 1.312773] phy phy-ff770000.syscon:usb2-phy@e450.6: Failed to get VBUS supply regulator
[ 1.312865] uboot: 0x000400000 -- 0x000800000 (4 MB)
[ 1.312879] trust: 0x000800000 -- 0x000c00000 (4 MB)
[ 1.312890] misc: 0x000c00000 -- 0x001000000 (4 MB)
[ 1.312923] resource: 0x001000000 -- 0x002000000 (16 MB)
[ 1.312933] kernel: 0x002000000 -- 0x003800000 (24 MB)
[ 1.312944] boot: 0x003800000 -- 0x005800000 (32 MB)
[ 1.312955] recovery: 0x005800000 -- 0x009800000 (64 MB)
[ 1.312966] backup: 0x009800000 -- 0x010800000 (112 MB)
[ 1.312977] security: 0x010800000 -- 0x010c00000 (4 MB)
[ 1.312987] cache: 0x010c00000 -- 0x030c00000 (512 MB)
[ 1.312999] system: 0x030c00000 -- 0x090c00000 (1536 MB)
[ 1.313009] metadata: 0x090c00000 -- 0x091c00000 (16 MB)
[ 1.313020] vendor: 0x091c00000 -- 0x0b1c00000 (512 MB)
[ 1.313031] oem: 0x0b1c00000 -- 0x0c1c00000 (256 MB)
[ 1.313041] frp: 0x0c1c00000 -- 0x0c1c80000 (0 MB)
[ 1.313052] userdata: 0x0c1c80000 -- 0x747800000 (26715 MB)
[ 1.313135] mmcblk1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16
[ 1.315080] rockchip-drm display-subsystem: dmc is disabled
[ 1.315517] rockchip-vop ff900000.vop: missing rockchip,grf property
[ 1.315886] rockchip-vop ff900000.vop: unable to request PWM
[ 1.315923] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 1.315990] rockchip-vop ff8f0000.vop: missing rockchip,grf property
[ 1.316218] rockchip-vop ff8f0000.vop: unable to request PWM
[ 1.316248] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 1.316514] rockchip-dp ff970000.edp: failed to get vcc regulator: -19
[ 1.316536] rockchip-dp ff970000.edp: failed to get vccio regulator: -19
[ 1.316640] rockchip-dp ff970000.edp: no DP phy configured
[ 1.317110] rockchip-drm display-subsystem: bound ff970000.edp (ops rockchip_dp_component_ops)
[ 1.317432] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[ 1.319220] rockchip-drm display-subsystem: bound ff940000.hdmi (ops dw_hdmi_rockchip_ops)
[ 1.319847] i2c i2c-9: of_i2c: modalias failure on /dp@fec00000/ports
[ 1.320629] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn
[ 1.320713] rockchip-drm display-subsystem: bound fec00000.dp (ops cdn_dp_component_ops)
[ 1.320742] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.320751] [drm] No driver support for vblank timestamp query.
[ 1.321138] rockchip-drm display-subsystem: failed to parse loader memory
[ 1.376587] rockchip-drm display-subsystem: fb0: frame buffer device
[ 1.389092] mali ff9a0000.gpu: gpu_leakage=14
[ 1.413803] mali ff9a0000.gpu: temp=38125, pvtm=111892 (112030 + -138)
[ 1.415982] mali ff9a0000.gpu: GPU identified as 0x0860 r2p0 status 0
[ 1.416279] mali ff9a0000.gpu: Protected mode not available
[ 1.417000] mali ff9a0000.gpu: Using configured power model mali-simple-power-model, and fallback mali-simple-power-model
[ 1.417273] I : [File] : drivers/gpu/arm/midgard/backend/gpu/mali_kbase_devfreq.c; [Line] : 399; [Func] : kbase_devfreq_init(); success ini.
[ 1.419015] mali ff9a0000.gpu: Probed as mali0
[ 1.425323] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller
[ 1.425896] xhci-hcd xhci-hcd.11.auto: new USB bus registered, assigned bus number 3
[ 1.426415] xhci-hcd xhci-hcd.11.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x02030010
[ 1.426564] xhci-hcd xhci-hcd.11.auto: irq 236, io mem 0xfe800000
[ 1.426939] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.426972] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.426998] usb usb3: Product: xHCI Host Controller
[ 1.427095] usb usb3: Manufacturer: Linux 4.4.126 xhci-hcd
[ 1.427118] usb usb3: SerialNumber: xhci-hcd.11.auto
[ 1.428285] hub 3-0:1.0: USB hub found
[ 1.428423] hub 3-0:1.0: 1 port detected
[ 1.429109] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller
[ 1.429567] xhci-hcd xhci-hcd.11.auto: new USB bus registered, assigned bus number 4
[ 1.429768] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.430015] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.430097] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.430122] usb usb4: Product: xHCI Host Controller
[ 1.430144] usb usb4: Manufacturer: Linux 4.4.126 xhci-hcd
[ 1.430166] usb usb4: SerialNumber: xhci-hcd.11.auto
[ 1.431352] hub 4-0:1.0: USB hub found
[ 1.431473] hub 4-0:1.0: 1 port detected
[ 1.434863] xhci-hcd xhci-hcd.11.auto: remove, state 1
[ 1.434971] usb usb4: USB disconnect, device number 1
[ 1.459499] xhci-hcd xhci-hcd.11.auto: Host not halted after 16000 microseconds.
[ 1.459575] xhci-hcd xhci-hcd.11.auto: Host controller not halted, aborting reset.
[ 1.459804] xhci-hcd xhci-hcd.11.auto: USB bus 4 deregistered
[ 1.460255] xhci-hcd xhci-hcd.11.auto: remove, state 1
[ 1.460342] usb usb3: USB disconnect, device number 1
[ 1.461528] xhci-hcd xhci-hcd.11.auto: USB bus 3 deregistered
[ 1.469466] xhci-hcd xhci-hcd.12.auto: xHCI Host Controller
[ 1.470028] xhci-hcd xhci-hcd.12.auto: new USB bus registered, assigned bus number 3
[ 1.470605] xhci-hcd xhci-hcd.12.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x02030010
[ 1.470752] xhci-hcd xhci-hcd.12.auto: irq 237, io mem 0xfe900000
[ 1.471113] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.471146] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.471225] usb usb3: Product: xHCI Host Controller
[ 1.471248] usb usb3: Manufacturer: Linux 4.4.126 xhci-hcd
[ 1.471270] usb usb3: SerialNumber: xhci-hcd.12.auto
[ 1.472491] hub 3-0:1.0: USB hub found
[ 1.472622] hub 3-0:1.0: 1 port detected
[ 1.473283] xhci-hcd xhci-hcd.12.auto: xHCI Host Controller
[ 1.473874] xhci-hcd xhci-hcd.12.auto: new USB bus registered, assigned bus number 4
[ 1.474083] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.474370] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.474441] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.474467] usb usb4: Product: xHCI Host Controller
[ 1.474544] usb usb4: Manufacturer: Linux 4.4.126 xhci-hcd
[ 1.474567] usb usb4: SerialNumber: xhci-hcd.12.auto
[ 1.475895] hub 4-0:1.0: USB hub found
[ 1.476029] hub 4-0:1.0: 1 port detected
[ 1.481543] ehci-platform fe380000.usb: EHCI Host Controller
[ 1.482374] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 5
[ 1.482809] ehci-platform fe380000.usb: irq 28, io mem 0xfe380000
[ 1.490589] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[ 1.491004] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.491034] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.491100] usb usb5: Product: EHCI Host Controller
[ 1.491124] usb usb5: Manufacturer: Linux 4.4.126 ehci_hcd
[ 1.491146] usb usb5: SerialNumber: fe380000.usb
[ 1.492273] hub 5-0:1.0: USB hub found
[ 1.492397] hub 5-0:1.0: 1 port detected
[ 1.494147] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[ 1.494680] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 6
[ 1.495119] ohci-platform fe3a0000.usb: irq 29, io mem 0xfe3a0000
[ 1.551365] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.551443] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.551470] usb usb6: Product: Generic Platform OHCI controller
[ 1.551495] usb usb6: Manufacturer: Linux 4.4.126 ohci_hcd
[ 1.551518] usb usb6: SerialNumber: fe3a0000.usb
[ 1.552826] hub 6-0:1.0: USB hub found
[ 1.552930] hub 6-0:1.0: 1 port detected
[ 1.555621] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.555857] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 1.555934] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 1.555999] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 1.556107] dwmmc_rockchip fe310000.dwmmc: 'clock-freq-min-max' property was deprecated.
[ 1.556200] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 1.556280] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 1.557027] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq
[ 1.564590] fusb302 4-0022: CC connected in CC1 as UFP
[ 1.566053] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn
[ 1.567422] fusb302 4-0022: connection has disconnected
[ 1.569453] rockchip-dwc3 usb@fe800000: USB peripheral connected
[ 1.570568] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 1.571002] rockchip-dwc3 usb@fe800000: USB unconnected
[ 1.571033] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn
[ 1.583930] dwmmc_rockchip fe310000.dwmmc: 1 slots initialized
[ 1.600810] asoc-simple-card rt5651-sound: rt5651-aif1 <-> ff890000.i2s mapping ok
[ 1.600993] asoc-simple-card rt5651-sound: ASoC: no source widget found for MICBIAS1
[ 1.601024] asoc-simple-card rt5651-sound: ASoC: Failed to add route MICBIAS1 -> direct -> Mic Jack
[ 1.601535] rt5651 1-001a: ASoC: mux INL1 Mux has no paths
[ 1.601586] rt5651 1-001a: ASoC: mux INR1 Mux has no paths
[ 1.601666] rt5651 1-001a: ASoC: mux INL2 Mux has no paths
[ 1.601702] rt5651 1-001a: ASoC: mux INR2 Mux has no paths
[ 1.610946] rockchip-spdif ff870000.spdif: Missing dma channel for stream: 0
[ 1.611028] rockchip-spdif ff870000.spdif: ASoC: pcm constructor failed: -22
[ 1.611054] asoc-simple-card spdif-sound: ASoC: can't create pcm ff870000.spdif-dit-hifi :-22
[ 1.611077] asoc-simple-card spdif-sound: ASoC: failed to instantiate card -22
[ 1.611426] asoc-simple-card: probe of spdif-sound failed with error -22
[ 1.612743] rk-hdmi-dp-sound hdmi-dp-sound: control 3:0:0:ELD:0 is already present
[ 1.612819] hdmi-audio-codec hdmi-audio-codec.10.auto: ASoC: Failed to add ELD: -16
[ 1.613884] rk-hdmi-dp-sound hdmi-dp-sound: multicodec <-> ff8a0000.i2s mapping ok
[ 1.614047] hdmi-audio-codec hdmi-audio-codec.10.auto: ASoC: Failed to create Playback debugfs file
[ 1.617134] rk808-rtc rk808-rtc: setting system clock to 2013-01-18 08:50:04 UTC (1358499004)
[ 1.628352] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[ 1.630029] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.631684] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.634637] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
[ 1.638298] mmc2: queuing unknown CIS tuple 0x81 (9 bytes)
[ 1.655541] vcc_sd: disabling
[ 1.655691] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3000000 done
[ 1.655844] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3000000 done
[ 1.657434] input: rk29-keypad as /devices/platform/rockchip-key/input/input1
[ 1.658453] ALSA device list:
[ 1.658505] #0: realtek,rt5651-codec
[ 1.658704] #1: rk-hdmi-dp-sound
[ 1.659537] Freeing unused kernel memory: 832K
[ 1.663308] init: init first stage started!
[ 1.663739] init: Using Android DT directory /proc/device-tree/firmware/android/
[ 1.690608] mmc_host mmc2: Bus speed (slot 0) = 150000000Hz (slot req 150000000Hz, actual 150000000HZ div = 0)
[ 1.776936] usb 3-1: new high-speed USB device number 2 using xhci-hcd
[ 1.827838] fusb302 4-0022: CC connected in CC1 as UFP
[ 1.828972] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn
[ 1.831339] fusb302 4-0022: connection has disconnected
[ 1.832131] rockchip-dwc3 usb@fe800000: USB peripheral connected
[ 1.834419] rockchip-dwc3 usb@fe800000: USB unconnected
[ 1.834450] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn
[ 1.870607] vendor storage:20160801 ret = 0
[ 1.954083] dwmmc_rockchip fe310000.dwmmc: Successfully tuned phase to 197
[ 1.963249] mmc2: queuing unknown CIS tuple 0x91 (3 bytes)
[ 1.963457] mmc2: new ultra high speed SDR104 SDIO card at address 0001
[ 2.079341] fusb302 4-0022: CC connected in CC1 as UFP
[ 2.080944] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn
[ 2.084041] rockchip-dwc3 usb@fe800000: USB peripheral connected
[ 2.158421] init: [libfs_mgr]Enabling dm-verity for system (mode 2)
[ 2.158541] init: [libfs_mgr]loading verity table: '1 /dev/block/by-name/system /dev/block/by-name/system 4096 4096 387072 387072 sha256 58'
[ 2.169325] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: barrier=1,inode_readahead_blks=8
[ 2.169467] init: [libfs_mgr]__mount(source=/dev/block/dm-0,target=/system,type=ext4)=0: Success
[ 2.174853] fusb302 4-0022: connection has disconnected
[ 2.178213] rockchip-dwc3 usb@fe800000: USB unconnected
[ 2.178258] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn
[ 2.340148] random: nonblocking pool is initialized
[ 2.415159] init: [libfs_mgr]Enabling dm-verity for vendor (mode 2)
[ 2.415235] init: [libfs_mgr]loading verity table: '1 /dev/block/by-name/vendor /dev/block/by-name/vendor 4096 4096 129017 129017 sha256 04'
[ 2.422619] fusb302 4-0022: CC connected in CC1 as UFP
[ 2.424048] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn
[ 2.424743] fusb302 4-0022: connection has disconnected
[ 2.427107] EXT4-fs (dm-1): mounted filesystem with ordered data mode. Opts: barrier=1,inode_readahead_blks=8
[ 2.427336] init: [libfs_mgr]__mount(source=/dev/block/dm-1,target=/vendor,type=ext4)=0: Success
[ 2.427724] init: Skipped setting INIT_AVB_VERSION (not in recovery mode)
[ 2.427860] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn
[ 2.427936] init: Loading SELinux policy
[ 2.546176] audit: type=1403 audit(1358499005.426:2): policy loaded auid=4294967295 ses=4294967295
[ 2.546483] selinux: SELinux: Loaded policy from /vendor/etc/selinux/precompiled_sepolicy
[ 2.546483]
[ 2.552176] selinux: SELinux: Loaded file_contexts
[ 2.552176]
[ 2.554335] init: init second stage started!
[ 2.560914] init: Using Android DT directory /proc/device-tree/firmware/android/
[ 2.561395] init: Set boot.mode to emmc
[ 2.561441] init: property_set("ro.boot.mode", "emmc") failed: property already set
[ 2.563783] selinux: SELinux: Loaded file_contexts
[ 2.563783]
[ 2.564388] selinux: SELinux: Loaded property_contexts from /system/etc/selinux/plat_property_contexts & /vendor/etc/selinux/nonplat_proper.
[ 2.564388]
[ 2.564428] init: Running restorecon...
[ 2.570688] init: waitid failed: No child processes
[ 2.573070] init: Couldn't load property file: Unable to open '/odm/default.prop': No such file or directory: No such file or directory
[ 2.575040] init: Created socket '/dev/socket/property_service', mode 666, user 0, group 0
[ 2.575230] init: Parsing file /init.rc...
[ 2.575563] init: Added '/init.environ.rc' to import list
[ 2.575606] init: Added '/init.usb.rc' to import list
[ 2.575638] init: Added '/init.rk30board.rc' to import list
[ 2.575681] init: Added '/vendor/etc/init/hw/init.rk30board.rc' to import list
[ 2.575697] init: Added '/init.usb.configfs.rc' to import list
[ 2.575718] init: Added '/init.zygote64_32.rc' to import list
[ 2.577061] init: Parsing file /init.environ.rc...
[ 2.577196] init: Parsing file /init.usb.rc...
[ 2.577631] init: Parsing file /init.rk30board.rc...
[ 2.577801] init: Added 'init.rk30board.bootmode.emmc.rc' to import list
[ 2.577821] init: Added 'init.rockchip.rc' to import list
[ 2.577857] init: Added 'init.connectivity.rc' to import list
[ 2.577872] init: Added 'init.box.samba.rc' to import list
[ 2.577892] init: Added 'init.rk3399.rc' to import list
[ 2.577913] init: Added 'init.tablet.rc' to import list
[ 2.577928] init: Added 'init.car.rc' to import list
[ 2.577942] init: Added 'init.optee.rc' to import list
[ 2.578526] init: Parsing file init.rk30board.bootmode.emmc.rc...
[ 2.578592] init: Parsing file init.rockchip.rc...
[ 2.578685] init: Added 'init.rk30board.usb.rc' to import list
[ 2.578707] init: Added 'init.rk30board.environment.rc' to import list
[ 2.578723] init: Added '/init.debug.rc' to import list
[ 2.579098] init: Parsing file init.rk30board.usb.rc...
[ 2.579382] init: Parsing file init.rk30board.environment.rc...
[ 2.579468] init: Parsing file /init.debug.rc...
[ 2.579512] init: Unable to open '/init.debug.rc': No such file or directory
[ 2.579536] init: /init.rc: 3: Could not import file '/init.debug.rc': No such file or directory
[ 2.579558] init: Parsing file init.connectivity.rc...
[ 2.579764] init: Parsing file init.box.samba.rc...
[ 2.579815] init: Unable to open 'init.box.samba.rc': No such file or directory
[ 2.579834] init: /init.rc: 4: Could not import file 'init.box.samba.rc': No such file or directory
[ 2.579855] init: Parsing file init.rk3399.rc...
[ 2.579909] init: Added 'init.quectel.rc' to import list
[ 2.580006] init: init.rk3399.rc: 27: invalid keyword 'ioprio'
[ 2.580092] init: Parsing file init.quectel.rc...
[ 2.580273] init: Parsing file init.tablet.rc...
[ 2.580314] init: Unable to open 'init.tablet.rc': No such file or directory
[ 2.580334] init: /init.rc: 6: Could not import file 'init.tablet.rc': No such file or directory
[ 2.580359] init: Parsing file init.car.rc...
[ 2.580391] init: Unable to open 'init.car.rc': No such file or directory
[ 2.580409] init: /init.rc: 7: Could not import file 'init.car.rc': No such file or directory
[ 2.580429] init: Parsing file init.optee.rc...
[ 2.580454] init: Unable to open 'init.optee.rc': No such file or directory
[ 2.580471] init: /init.rc: 8: Could not import file 'init.optee.rc': No such file or directory
[ 2.581911] init: Parsing file /vendor/etc/init/hw/init.rk30board.rc...
[ 2.581959] init: Unable to open '/vendor/etc/init/hw/init.rk30board.rc': No such file or directory
[ 2.581979] init: /init.rc: 10: Could not import file '/vendor/etc/init/hw/init.rk30board.rc': No such file or directory
[ 2.582001] init: Parsing file /init.usb.configfs.rc...
[ 2.582587] init: Parsing file /init.zygote64_32.rc...
[ 2.582844] init: Parsing directory /system/etc/init...
[ 2.583800] init: Parsing file /system/etc/init/android.hidl.allocator@1.0-service.rc...
[ 2.584506] init: Parsing file /system/etc/init/atrace.rc...
[ 2.585699] init: Parsing file /system/etc/init/atrace_userdebug.rc...
[ 2.586220] init: Parsing file /system/etc/init/audioserver.rc...
[ 2.586652] init: Parsing file /system/etc/init/bootanim.rc...
[ 2.587051] init: Parsing file /system/etc/init/bootstat.rc...
[ 2.587576] init: Parsing file /system/etc/init/cameraserver.rc...
[ 2.587986] init: Parsing file /system/etc/init/drmserver.rc...
[ 2.588374] init: Parsing file /system/etc/init/dumpstate.rc...
[ 2.588790] init: Parsing file /system/etc/init/gatekeeperd.rc...
[ 2.589152] init: Parsing file /system/etc/init/hwservicemanager.rc...
[ 2.589559] init: Parsing file /system/etc/init/init-debug.rc...
[ 2.589952] init: Parsing file /system/etc/init/installd.rc...
[ 2.590604] init: Parsing file /system/etc/init/keystore.rc...
[ 2.591016] init: Parsing file /system/etc/init/lmkd.rc...
[ 2.591405] init: Parsing file /system/etc/init/logcatd.rc...
[ 2.591915] init: Parsing file /system/etc/init/logd.rc...
[ 2.592382] init: Parsing file /system/etc/init/logtagd.rc...
[ 2.592767] init: Parsing file /system/etc/init/mdnsd.rc...
[ 2.593142] init: Parsing file /system/etc/init/mediadrmserver.rc...
[ 2.593516] init: Parsing file /system/etc/init/mediaextractor.rc...
[ 2.593962] init: Parsing file /system/etc/init/mediametrics.rc...
[ 2.594359] init: Parsing file /system/etc/init/mediaserver.rc...
[ 2.594770] init: Parsing file /system/etc/init/mtpd.rc...
[ 2.595156] init: Parsing file /system/etc/init/netd.rc...
[ 2.595587] init: Parsing file /system/etc/init/perfprofd.rc...
[ 2.595968] init: Parsing file /system/etc/init/racoon.rc...
[ 2.596324] init: Parsing file /system/etc/init/servicemanager.rc...
[ 2.596716] init: Parsing file /system/etc/init/storaged.rc...
[ 2.597112] init: Parsing file /system/etc/init/surfaceflinger.rc...
[ 2.597569] init: Parsing file /system/etc/init/thermalservice.rc...
[ 2.597934] init: Parsing file /system/etc/init/tombstoned.rc...
[ 2.598359] init: Parsing file /system/etc/init/uncrypt.rc...
[ 2.598789] init: Parsing file /system/etc/init/vdc.rc...
[ 2.599177] init: Parsing file /system/etc/init/vold.rc...
[ 2.599597] init: Parsing file /system/etc/init/webview_zygote32.rc...
[ 2.599978] init: Parsing file /system/etc/init/webview_zygote64.rc...
[ 2.600387] init: Parsing file /system/etc/init/wifi-events.rc...
[ 2.600890] init: Parsing file /system/etc/init/wificond.rc...
[ 2.601344] init: Parsing directory /vendor/etc/init...
[ 2.601533] init: Parsing file /vendor/etc/init/android.hardware.audio@2.0-service.rc...
[ 2.602409] init: Parsing file /vendor/etc/init/android.hardware.bluetooth@1.0-service.rc...
[ 2.603120] init: Parsing file /vendor/etc/init/android.hardware.camera.provider@2.4-service.rc...
[ 2.603831] init: Parsing file /vendor/etc/init/android.hardware.cas@1.0-service.rc...
[ 2.604524] init: Parsing file /vendor/etc/init/android.hardware.configstore@1.0-service.rc...
[ 2.605166] init: Parsing file /vendor/etc/init/android.hardware.drm@1.0-service.rc...
[ 2.605918] init: Parsing file /vendor/etc/init/android.hardware.drm@1.0-service.widevine.rc...
[ 2.606605] init: Parsing file /vendor/etc/init/andro+-----------------------------+2.0-service.rc...
[ 2.607318] init: Parsing file /vendor/etc/init/andro| |.1-service.rc...
[ 2.608004] init: Parsing file /vendor/etc/init/andro| Cannot open /dev/ttyUSB0! |ce.rc...
[ 2.608677] init: Parsing file /vendor/etc/init/andro| |c...
[ 2.609333] init: Parsing file /vendor/etc/init/andro+-----------------------------+ce.rc...
[ 2.610034] init: Parsing file /vendor/etc/init/android.hardware.neuralnetworks@1.0-service-armnn.rc...
[ 2.610726] init: Parsing file /vendor/etc/init/android.hardware.nymblet@1.0-service.rc...
[ 2.611410] init: Parsing file /vendor/etc/init/android.hardware.power@1.0-service.rc...
[ 2.612092] init: Parsing file /vendor/etc/init/android.hardware.sensors@1.0-service.rc...
[ 2.612755] init: Parsing file /vendor/etc/init/android.hardware.wifi@1.0-service.rc...
[ 2.613450] init: Parsing file /vendor/etc/init/drmservice.rc...
[ 2.614135] init: Parsing file /vendor/etc/init/hostapd.android.rc...
[ 2.614816] init: Parsing file /vendor/etc/init/rild.rc...
[ 2.615460] init: /vendor/etc/init/rild.rc: 1: ignored duplicate definition of service 'ril-daemon'
[ 2.615489] init: Parsing file /vendor/etc/init/vndservicemanager.rc...
[ 2.616180] init: Parsing file /odm/etc/init...
[ 2.616219] init: Unable to open '/odm/etc/init': No such file or directory
[ 2.616352] init: processing action (early-init) from (/init.rc:14)
[ 2.620105] init: starting service 'ueventd'...
[ 2.620780] cgroup: init (1) created nested cgroup for controller "memory" which has incomplete hierarchy support. Nested cgroups may chang.
[ 2.620804] cgroup: "memory" requires setting use_hierarchy to 1 on the root
[ 2.621737] init: processing action (early-init) from (init.rockchip.rc:5)
[ 2.625572] ueventd: ueventd started!
[ 2.625711] ueventd: Parsing file /ueventd.rc...
[ 2.627319] ueventd: Parsing file /vendor/ueventd.rc...
[ 2.627400] ueventd: Unable to open '/vendor/ueventd.rc': No such file or directory
[ 2.627492] ueventd: Parsing file /odm/ueventd.rc...
[ 2.627573] ueventd: Unable to open '/odm/ueventd.rc': No such file or directory
[ 2.627763] ueventd: Parsing file /ueventd.rk30board.rc...
[ 2.629047] ueventd: /ueventd.rk30board.rc: 56: invalid gid 'net_bt_stack'
[ 2.629132] ueventd: /ueventd.rk30board.rc: 57: invalid gid 'net_bt_stack'
[ 2.629209] ueventd: /ueventd.rk30board.rc: 58: invalid gid 'net_bt_stack'
[ 2.629266] ueventd: /ueventd.rk30board.rc: 60: invalid gid 'net_bt_stack'
[ 2.629709] ueventd: /ueventd.rk30board.rc: 117: invalid gid 'trace'
[ 2.637970] selinux: SELinux: Loaded file_contexts
[ 2.637970]
[ 2.639075] init: processing action (wait_for_coldboot_done) from (<Builtin Action>:0)
[ 2.674258] fusb302 4-0022: CC connected in CC1 as UFP
[ 2.675329] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn
[ 2.770965] fusb302 4-0022: connection has disconnected
[ 2.773748] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn
[ 2.774424] selinux: SELinux: Loaded file_contexts
[ 0.368183]
[ 2.546483]
[ 2.552176]
[ 2.563783]
[ 2.564388]
[ 2.637970]
