I have network device connected to Ethernet port of RK3399. This is recognized as primary network connection and it disables WiFi on RK3399. As soon as I disconnect network device from LAN ports the WiFI connection is available again. I would like to use both Ethernet and WiFi connections at the same time on Android on RK3399.
Please, let me know if it's possible and which configuration or changes required.
Thanks a lot in advance.
