How to modify touch panel drivers
Posted: Mon Apr 20, 2020 12:15 pm
Hi everyone,
I am using Nano Pi M4 v2 with AM-1280800P3TZQW-00H-AMPI display and Fujitsu NC01152-T101 restive touch panel with NC01850-B045RS dual touch control board (sunreadable display and resistive touch are due to application). The issue that the touch panel active area is bigger (and ofset) than the display active area and the touch punkt coordinates does not mach the display coordinates. It is more dramatic in landscape configuration when after using the Screen Zoom tool, the picture area was reduced on both directions (and it is not possible to zoom it in)... I have read something about simply editing the code that refers to x and y touch coordinates. Worth to try, but I could not find any way co access the Android files. I was trying to work with ADB but it is only asking for next dll lib.. My question is: how to access and navigate through the Android code on my device? Any tutorial "from zero to hero" would be welcome. I have the eMMC to SD card adapter and the serial to USB wire, may it be useful?
I was also trying to solve the touch panel issue with "calibration app" but what the calibration apps makes is for sure not calibrating the touch punkt coordinates...
In future I will try to connect to this device external sensors like MS5611 (I2C) and probably free access to the system may help to make it work...
Thank you for your support!
