EDIT: One of these is now dead and the other runs so hot in the case it overheats. The cooling solution for this device is unacceptable.
I ordered 2 of these units and both came with heatsink installation issues. The studs for the heatsink mount are not fully seated on the board so the thermal pad didn't contact the chip.
Re-soldering the studs completely seated on the board fixes the alignment issue, but these guys still run hot. A little tip, after you remove the heatsink, put the screws back in the studs to re-solder so you don't get it on the threads.
Very pleased with this unit, given that it's targeted at tinkerers. Not really acceptable for general consumers though. Still. Up and running without a hitch for a couple days now.
