I recently received a NanoPi R2S w/ Metal Case and grabbed the rk3328-sd-friendlycore-bionic-5.4-arm64-20200904.img.zip, verified the md5sum of the archive, extracted the archive, and wrote the uncompressed image to a micro SD card.
Attempting to boot the NanoPi R2S with this micro SD card results in a flashing SYS led (two pulsing flashes, approximately 1 second delay, repeat).
To diagnose this, I needed to access the UART, meaning I needed to remove the warranty sticker from at least one of the units.
With access to the UART, I was able to captured the attached output for the boot session. The end of which is copied below.
Loading, please wait...
starting version 237
[ 2.660289] usb 5-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
[ 2.681172] usb 5-1: New USB device found, idVendor=0bda, idProduct=8153, bcdDevice=31.00
[ 2.681931] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=6
[ 2.682564] usb 5-1: Product: USB 10/100/1000 LAN
[ 2.682984] usb 5-1: Manufacturer: Realtek
[ 2.683357] usb 5-1: SerialNumber: 000000000000
[ 8.352257] phy phy-ff450000.syscon:usb2-phy@100.0: charger = USB_DCP_CHARGER
Begin: Waiting for root file system ... Begin: Running /scripts/local-block ... done.
done.
Gave up waiting for root file system device. Common problems:
- Boot args (cat /proc/cmdline)
- Check rootdelay= (did the system wait long enough?)
- Missing modules (cat /proc/modules; ls /dev)
ALERT! /dev/mmcblk0p1 does not exist. Dropping to a shell!
BusyBox v1.27.2 (Ubuntu 1:1.27.2-2ubuntu3.2) built-in shell (ash)
Enter 'help' for a list of built-in commands.
(initramfs) [ 44.447235] mmc0: error -110 whilst initialising SD card
[ 44.467866] mmc_host mmc0: Bus speed (slot 0) = 300000Hz (slot req 300000Hz, actual 300000HZ div = 0)
[ 45.841873] mmc0: card never left busy state
[ 45.842307] mmc0: error -110 whilst initialising SD card
[ 45.858086] mmc_host mmc0: Bus speed (slot 0) = 200000Hz (slot req 200000Hz, actual 200000HZ div = 0)
[ 47.277997] mmc0: card never left busy state
[ 47.278430] mmc0: error -110 whilst initialising SD card
[ 47.294718] mmc_host mmc0: Bus speed (slot 0) = 100000Hz (slot req 100000Hz, actual 100000HZ div = 0)
[ 48.843109] mmc0: card never left busy state
[ 48.843547] mmc0: error -110 whilst initialising SD card
