Hi Folks,
Per the instructions on the wiki, I've tried burning the rk3328-sd-debian-bullseye-core-5.15-arm64-20230529.img to an SD and booting it on a new R2C+. I've been able to successfully write and boot the eflasher version, but not this image.
I've used dd and win32diskimager and different SD cards to no avail. From the debug output it looks like the device is seeing the SDcard but is unable to read the kernel:
## Booting Rockchip Format Image
Failed to read kernel image, ret=6
mmc_init: -95, time 1802
switch to partitions #0, OK
mmc0(part 0) is current device
Failed to mount ext2 filesystem...
** Unrecognized filesystem type **
Here's the debug output from the RC2+:
DDR version 1.16 20190528
In
DDR4
333MHz
Bus Width=32 Col=10 Bank=4 Bank Group=2 Row=15 CS=1 Die Bus-Width=16 Size=1024MB
ddrconfig:14
OUT
Boot1 Release Time: May 13 2019 17:34:36, version: 2.50
ChipType = 0x11, 247
mmc2:cmd19,100
SdmmcInit=2 0
BootCapSize=2000
UserCapSize=7456MB
FwPartOffset=2000 , 2000
mmc0:cmd5,20
SdmmcInit=0 0
BootCapSize=0
UserCapSize=60874MB
FwPartOffset=2000 , 0
run on sd0
StorageInit ok = 123742
Raw SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
atags_set_bootdev: ret:(0)
GPT part: 0, name: uboot, start:0x4000, size:0x2000
GPT part: 1, name: trust, start:0x6000, size:0x2000
GPT part: 2, name: misc, start:0x8000, size:0x2000
GPT part: 3, name: dtbo, start:0xa000, size:0x2000
GPT part: 4, name: resource, start:0xc000, size:0x8000
GPT part: 5, name: kernel, start:0x14000, size:0x14000
GPT part: 6, name: boot, start:0x28000, size:0x18000
GPT part: 7, name: rootfs, start:0x40000, size:0x280000
GPT part: 8, name: userdata, start:0x2c0000, size:0xbc7525
find part:uboot OK. first_lba:0x4000.
find part:trust OK. first_lba:0x6000.
LoadTrust Addr:0x6000
No find bl30.bin
Load uboot, ReadLba = 4000
Load OK, addr=0x200000, size=0xeabf8
RunBL31 0x40000
NOTICE: BL31: v1.3(release):734d842
NOTICE: BL31: Built : 15:29:53, Dec 26 2019
NOTICE: BL31:Rockchip release version: v1.3
INFO: ARM GICv2 driver initialized
INFO: Using opteed sec cpu_context!
INFO: boot cpu mask: 1
INFO: plat_rockchip_pmu_init: pd status 0xe
INFO: BL31: Initializing runtime services
INFO: BL31: Initializing BL32
INF [0x0] TEE-CORE:init_primary_helper:337: Initializing (1.1.0-235-g3b0152ca #231 Fri Mar 13 02:01:39 UTC 2020 aarch64)
INF [0x0] TEE-CORE:init_primary_helper:338: Release version: 1.4
INFO: BL31: Preparing for EL3 exit to normal world
INFO: Entry point address = 0x200000
INFO: SPSR = 0x3c9
U-Boot 2017.09-g43267f9286-200623 #root (Jul 07 2021 - 16:49:31 +0800)
Board: FriendlyELEC RK3328 board
PreSerial: 2
DRAM: 992 MiB
Sysmem: init
Relocation Offset: 3dbd8000, fdt: 3bdcd838
Using default environment
no mmc device at slot 1
Found IDB in SDcard
mmc@ff500000: 1 (SD), mmc@ff520000: 0
Bootdev(atags): mmc 1
MMC1: Legacy, 50Mhz
PartType: EFI
boot mode: None
Found DTB in resource part
DTB: rk3328-nanopi-r2-rev22.dtb (64797)
ANDROID: fdt overlay OK
I2c1 speed: 400000Hz
PMIC: RK8050 (on=0x40, off=0x00)
vdd_logic init 1075000 uV
vdd_arm init 1225000 uV
I2c0 speed: 200000Hz
CLK: (sync kernel. arm: enter 600000 KHz, init 600000 KHz, kernel 0N/A)
apll 400000 KHz
dpll 664000 KHz
cpll 1200000 KHz
gpll 491009 KHz
npll 600000 KHz
armclk 600000 KHz
aclk_bus 150000 KHz
hclk_bus 75000 KHz
pclk_bus 75000 KHz
aclk_peri 150000 KHz
hclk_peri 75000 KHz
pclk_peri 75000 KHz
Net: eth0: ethernet@ff540000
Hit key to stop autoboot('CTRL+C'): 0
failed to read ca head from misc
starting USB...
Bus usb@ff580000: Bus usb@ff5c0000: USB EHCI 1.00
Bus usb@ff5d0000: USB OHCI 1.0
Bus dwc3@ff600000: usb maximum-speed not found
Failed to get USB PHY0 for dwc3@ff600000
Port not available.
scanning bus usb@ff580000 for devices... 1 USB Device(s) found
scanning bus usb@ff5c0000 for devices... 1 USB Device(s) found
scanning bus usb@ff5d0000 for devices... 1 USB Device(s) found
scanning usb for storage devices... 0 Storage Device(s) found
Device 0: unknown device
DMA reset timeout
missing environment variable: pxeuuid
missing environment variable: bootfile
Retrieving file: pxelinux.cfg/01-e6-a0-48-f5-b3-b1
DMA reset timeout
Retrieving file: pxelinux.cfg/00000000
DMA reset timeout
DMA reset timeout
DMA reset timeout
DMA reset timeout
DMA reset timeout
DMA reset timeout
DMA reset timeout
DMA reset timeout
Retrieving file: pxelinux.cfg/default-arm-rockchip
DMA reset timeout
DMA reset timeout
DMA reset timeout
Config file not found
DMA reset timeout
DMA reset timeout
nanopi-r2#
Has anyone burned and booted the debian core image successfully?
Any thoughts, pointers, etc. would be much appreciated.
Thanks,
-Mike
In
DDR4
333MHz
ddrconfig:14
OUT
mmc2:cmd19,100
SdmmcInit=2 0
BootCapSize=2000
UserCapSize=7456MB
mmc0:cmd5,20
SdmmcInit=0 0
BootCapSize=0
UserCapSize=60874MB
run on sd0
Raw SecureMode = 0
No find bl30.bin
RunBL31 0x40000
INFO: SPSR = 0x3c9
PreSerial: 2
DRAM: 992 MiB
Sysmem: init
Found IDB in SDcard
MMC1: Legacy, 50Mhz
PartType: EFI
boot mode: None
apll 400000 KHz
dpll 664000 KHz
cpll 1200000 KHz
gpll 491009 KHz
npll 600000 KHz
armclk 600000 KHz
aclk_bus 150000 KHz
hclk_bus 75000 KHz
pclk_bus 75000 KHz
hclk_peri 75000 KHz
pclk_peri 75000 KHz
starting USB...
Port not available.
DMA reset timeout
DMA reset timeout
DMA reset timeout
DMA reset timeout
DMA reset timeout
DMA reset timeout
DMA reset timeout
DMA reset timeout
DMA reset timeout
DMA reset timeout
DMA reset timeout
DMA reset timeout
DMA reset timeout
DMA reset timeout
DMA reset timeout
nanopi-r2#
Thanks,
-Mike
