I installed the OMV official image form FriendlyELEC in an SD to eMMC without any problem... but OMV has a lot of problems. I'd like to install DietPi image in a TF/SD card, for example, and then a clean OMV over this OS.
My problem is my CM3588 now always start from the eMMC but not form a TF card. I tried using the MASK button with the new S.O in the TF/SD card but not appears nothing in the HDMI. Also, I cleared the loader of the eMMC but nothing appear: not start from eMMC but not start from the TF card with the DietPi image
4.5 The Boot order between eMMC and SD card
By default, the system will be booted from the TF card first, but this is not the case under all conditions. This section will explain all situations in detail;
Refer to rockchip official document [1], there are two types of loader program:
1) U-Boot TPL/SPL (i.e. upsream U-Boot, also called mainline U-Boot)
2) Rockchip MiniLoader
Things to note:
1) FriendlyELEC's image uses Rockchip MiniLoader
2) The third-party image usually uses U-Boot TPL/SPL
The following situations will always start from eMMC:
If the system in the eMMC, or the system in the TF card uses the first Loader type U-Boot TPL/SPL, it will always boot from the eMMC;
If you want to boot from the TF card, there are the following methods:
Method 1: Clear the Loader on the eMMC, the clearing method is as follows, after starting from the eMMC, enter the following command on the command line to clear the Loader on the eMMC:
dd if=/dev/zero of=/dev/mmcblk2 bs=8M count=1
Method 2: Insert the TF card, Press Maskrom Key (or short-circuit the Maskrom contacts) and then power on (need to keep the short-circuit for about 3 seconds), it will start from the TF card
Thank you in advance
