Compile FriendlyWrt hangs
https://wiki.friendlyarm.com/wiki/index.php/NanoPi_R2S#Compile_FriendlyWrt
jaap@jaap:~/friendlywrt/friendlywrt-rk3328$ repo init -u https://github.com/friendlyarm/friendlywrt_manifests -b master-v19.07.5 -m rk3328.xml --repo-url=https://github.com/friendlyarm/repo  --no-clone-bundle
Downloading Repo source from https://github.com/friendlyarm/repo
remote: Enumerating objects: 4162, done.
remote: Total 4162 (delta 0), reused 0 (delta 0), pack-reused 4162
/home/jaap/friendlywrt/friendlywrt-rk3328/.repo/repo/main.py:19: DeprecationWarning: the imp module is deprecated in favour of importlib; see the module's documentation for alternative uses
  import imp
Get https://github.com/friendlyarm/friendlywrt_manifests
remote: Enumerating objects: 39, done.
remote: Counting objects: 100% (39/39), done.
remote: Compressing objects: 100% (28/28), done.
remote: Total 96 (delta 15), reused 32 (delta 8), pack-reused 57
From https://github.com/friendlyarm/friendlywrt_manifests
 * [new branch]      master          -> origin/master
 * [new branch]      master-v18.06.1 -> origin/master-v18.06.1
 * [new branch]      master-v19.07.1 -> origin/master-v19.07.1
 * [new branch]      master-v19.07.4 -> origin/master-v19.07.4
 * [new branch]      master-v19.07.5 -> origin/master-v19.07.5
[Hangs]
I tried it again and the situation got worse:
fatal: unable to access 'https://github.com/friendlyarm/repo/': Failed sending HTTP2 data
repo: error: "git" failed with exit status 128
  cwd: /home/jaap/friendlywrt/friendlywrt-rk3328/.repo/repo
  cmd: ['git', 'fetch', '--quiet', '--progress', 'origin', '+refs/heads/*:refs/remotes/origin/*', '+refs/tags/*:refs/tags/*']
fatal: cloning the git-repo repository failed, will remove '.repo/repo'
Please let the package maintainers answer my questions
