Armbian Bionic or Stretch for T3/T3+/M3/Fire3
+ kernel 4.14.39
+ 2GB memory support
+ ethermet works
+ wlan works
+ desktop works
+ mali works
+ cpu scaling works
+ docker support
- eMMC install fails (T3+), BT does not work yet
- power off reboots the board
Images
https://www.armbian.com/download/?tx_soc=s5p-6818
Nice ! :D
Maybe we'll get somewhere with this !
Thanks Igorp ! ♥
Updated images, more recent kernel, support for 2Gb boards
what is not working with Bluetooth? the stack cannot be installed? The Fire3 doesn't even have it however it seems that it shouldn't be that difficult to bake the stack in?
I flashed the last recent Armbian Bionic (desktop mainline kernel 4.14.y) dated on 22.08.2018.
I2C is available:
# fdtget /boot/dtb/nexell/s5p6818-nanopi-fire3.dtb i2c0 status
okay
# ls -la /dev/i2c*
crw------- 1 root root 89, 0 Sep  2 09:15 /dev/i2c-0
crw------- 1 root root 89, 1 Sep  2 09:15 /dev/i2c-1
crw------- 1 root root 89, 2 Sep  2 09:15 /dev/i2c-2
crw------- 1 root root 89, 3 Sep  2 09:15 /dev/i2c-3
But SPI is not available
# fdtget /boot/dtb/nexell/s5p6818-nanopi-fire3.dtb spi0 status        disable
# ls -la /dev/spi*
ls: cannot access '/dev/spi*': No such file or directory
I compared the DTB from the running Armbian Bionic (kernel 4.14) system (dtc -I fs /sys/firmware/devicetree/base) with the DTS from FriendlyArm (kernel 4.4) (https://github.com/friendlyarm/linux/blob/nanopi2-v4.4.y/arch/arm64/boot/dts/nexell/s5p6818-nanopi3-common.dtsi)
They are very different. Especially there is no `spidev`
There is no forum from Armbian that I can ask question on Fire3. So I ask my questions here.
How can I hack on the Armbian kernel for Fire3 (modify device tree, merge touch screen support from FriendlyArm kernel 4.4, etc.)
Thanks,
Andreas
Thanks,
Andreas
SPI bits exits in the common include file arch/arm64/boot/dts/nexell/s5p6818.dtsi and probably works ... so you just need to enabled them. A touchscreen will be a bit more challenging but it should be doable. Try to port bits from 4.4.y kernel and check if there is any special driver for it. And port that too.
We provide Fire3/T3+ images but we can't afford to provide end user support because only one person is working on it. That is too little and below support rules threshold. We have a special part of the forum for older or non-supported boards: https://forum.armbian.com/forum/25-peer ... l-support/
But nevertheless, we are still improving overall support.
https://twitter.com/armbian/status/1038146549124083715
Relevant commits, the first one is included in the image you are running, second not:
https://github.com/armbian/build/commit ... 2875ac2436
https://github.com/armbian/build/commit ... 935bf095f9
Thanks,
Andreas
Other supported boards
Odroid XU3/XU4/HC1, Nanopi Fire3, Nanopc T3/T3'+
https://forum.armbian.com/forum/11-othe ... ed-boards/
igorp wrote:
Other supported boards Torrent TurboTax Gogoanime
cool
iTunes Mobdro TutuApp
Thanks,
Andreas
I2C is available:
okay
# ls -la /dev/i2c*
# ls -la /dev/spi*
Thanks,
Andreas
Sarkari Result iTunes Notepad++
Thanks,
There is. Here:
Another update! Download new image or via apt update ; apt upgrade
Kernel update to 4.14.116
More info:
https://twitter.com/armbian/status/1124592076962836480
Added Debian Buster images with many small fixes on kernel level and:
- kernel 4.14.131
- added wireless drivers for 88x2bu
- updated wireless drivers for Realtek 8811, 8812, 8814 and 8821
- updated wireless drivers for rtl8188eus & rtl8188eu & rtl8188etv
- added latest Wireguard driver
- kernel 4.14.131
ah finally the update is out
I am hopeful it will fix all the issues!
v20.08
- kernel 4.14.y
- improved 1st login with location based semi automated language / locales detection
- Ubuntu Bionic/Focal or Debian Buster/Bullseye
- compiled with GCC 9.2
- upgraded download infrastructure (still a bit in works)
Download:
https://www.armbian.com/download/?tx_maker=friendlyelec
How to build from sources?
git clone https://github.com/armbian/build
cd build
./compile.sh
https://twitter.com/armbian/status/1296687681037107200
Thanks,
Andreas
SPI bits exits in the common include file arch/arm64/boot/dts/nexell/s5p6818.dtsi and probably works ... so you just need to enabled them. A touchscreen will be a bit more challenging but it should be doable. Try to port bits from 4.4.y kernel and check ogwhatsapp if there is any special driver for it. And port that too.
Thank you very much for your job. What about this problem Nano T3+:. Devices, which memory number begins with SEC710 K4B4G16 images does not work.
I think Armbian Bionic is much much better than other options.
Armbian Bionic is the best of the options I've used, anyone else have an opinion?
Thanks,
Andreas
SPI bits exits in the common include file arch/arm64/boot/dts/nexell/s5p6818.dtsi and probably works ... so you just need to enabled them. A touchscreen will be a bit more challenging but it should be doable. Try to port bits from 4.4.y kernel and check ig if there is any special driver for it. And port that too.
this is how i solved this problem.
