Hi guys,
I have initially installed Debian Jessie with OMV from image (http://wiki.friendlyarm.com/wiki/index. ... _NAS_Image)
It works in 1-bay NAS Dock v1.2 for NanoPi NEO/NEO2.
Yesterday I have upgraded OMV to Arrakis 4 from Erasmus 3. With the upgrade process also Debian was upgraded to 9.4 stretch (I think that the kernel was also changed during the process)
Now I have a problem with watchdog service.
Actually there are two failed units:
● watchdog.service loaded failed failed watchdog daemon
● wd_keepalive.service loaded failed failed watchdog keepalive daemon
As far I can tell it is caused by:
modprobe: FATAL: Module softdog not found in directory /lib/modules/4.11.2
Do you know how to add that module in an easy way? Is there any way to maybe build that module ?
Or maybe there is any other "easy" solution?
I do not want to install everything from scratch
