I'd like to use NanoPi M4 with SATA hat for my project, but is very limited height-wise. Can I use these short ribbons (the second one will be cut to 24pins) to connect NanoPi M4 to the SATA hat, or will the signal degrade too much? If these ribbons are not acceptable for the task, is there some other solution to mount the SATA hat side-by-side with the SBC?
