How to flip the camera image?
Using the SOM-RK3399 and 2 Mipi-Camera test,
There are different view orientation between 2 camera.
One camera has mirrored image and the other camera has normal image.
as like below image.
I want to make same orientation image.
Which files Could be modified in the source code?
Thank you.
I am not sure how to do this but as I see you are using Android, it is likely a setting in the camera app as it is likely that the OS is taking the 2 camera inputs as front and rear. The front by default flips the image on most mobile devices.
